1. eNewsletter Sign Up
TripleClamp Moto: Born in a Garage. Raised on the Trails.
Discussion in 'Vendors' started by alongat, Feb 18, 2017.
  1. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    Windsor, United Kingdom
    image.jpeg image.jpeg Tripleclamp Moto sale is on for 690/701 engine cover sets. Please visit our site www.tripleclampmoto.com and use discount code: 690701group to enjoy 25% off until the end of January.
  2. Shawnee Bill
    Shawnee Bill Long timer Supporter
    Feb 25, 2006
    4,857
    Oklahoma
    Is it possible to just buy the right side (clutch side) cover for the 701? I broke one of the "ears" of trying to get mine to fit because it was so tight.
    alvincullumyork and alongat like this.
  3. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    Really? That’s a first...email me at info@tripleclampmoto.com and I’ll take care of you right away.
    alvincullumyork likes this.
  4. PYG RYDR
    PYG RYDR Adventure-Dual Sport
    Sep 26, 2010
    644
    Southern VA
    701-My order arrived in 2 days! Very fast service! Thanks!
    On install on the right side, a quick look gives me the impression that the brake and foot-peg assembly is removed.
    Correct?
    TIA
    alvincullumyork, keener and alongat like this.
  5. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    There’s actually no need to remove anything. On that side, you’ll notice that there is a protrusion at the back. Sneak that between the clutch cover and brake lever into place and then insert its bolt without tightening it. Using force, press the front section over the clutch cover into place and then punch the cover right on all the way. Torque the bolts to factory spec (10nm) and then you’re done. I generally recommend using a bit of grease on inside of the covers to keep water and dirt from entering in. They’re super tight for that reason but the grease helps and also helps install them.
    alvincullumyork and PYG RYDR like this.
  6. Shawnee Bill
    Feb 25, 2006
    4,857
    Oklahoma
    email sent.
    As stated in the email I didn't actually break the ear off but wallowed or deformed the hole so much trying to force the cover on that the screw head now just slips through the hole so that mounting ear is useless. My memory mistake, I just put it on the shelf that day and was going to do something about it later.
    I feel it was my fault for forcing so much trying to get the screws in so I am just wanting to buy a new cover.
    Edit: reading the post above I see I should have lubed the cover up to help it slip on, it is a really tight fit.
  7. Shawnee Bill
    Feb 25, 2006
    4,857
    Oklahoma
    I'm going to post here that my problem has been resolved quickly in private emails. Super customer service beyond what I expected or deserved.
    I'm very glad to do business with Triple Clamp Moto.
    Thank you!
    alvincullumyork, PYG RYDR and alongat like this.
  8. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    Thanks for the support Bill :)
  9. PYG RYDR
    Sep 26, 2010
    644
    Southern VA
    Alon,
    Thanks for the install advice. I erred on my first look and was looking at the wrong bolt. Easy peasy!
    Galen
  10. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
  11. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    image.jpeg Thank you everyone for your great support with the 690/701 engine cover set promotion. We've now. Rested the same promotion for HDPE engine cover sets for the 1050/1090/1190/1290 bikes: 25% discount using promotion code 1090frame
    All details available on our site at www.tripleclampmoto.com
  12. b0yjeenyus
    b0yjeenyus Been here awhile
    Jan 23, 2015
    138
    MINNESNOWTA
    Thanks for the testimony. Just ordered a set myself based on this - always try to support the good guys and when they throw up a coupon I can't go wrong.
  13. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    Much much much appreciated guys :)
    Your order ships tomorrow
  14. b0yjeenyus
    Jan 23, 2015
    138
    MINNESNOWTA
    No rush, there will be some combination of ice/snow/salt on the roads until late March around here ...
  15. Shawnee Bill
    Feb 25, 2006
    4,857
    Oklahoma
    I received a replacement for the right side engine cover a couple of days go but just today had the time to fit the new one. It went on with very little effort, couple of good slaps with the palm of my hand and I was able to start both screws that hold it on. I don't think it fit as tight as the first cover I had.
    But all is well now thanks to TripleClamps great customer service. And they look good on the bike! :thumbup
    Thanks again!
  16. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    Thank you!!!
  17. Need For Speed
    Need For Speed Is that a cop?????
    Apr 24, 2012
    657
    Pacific North Wet
    I just placed my order, thanks for offering the discount! Looking forward to installing your awesome products on my 701.
    keener and alvincullumyork like this.
  18. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,945
    For those of you with Ktm 1050/1090/1190/1290, we have just launched our HeadStraight and damper mount kit. The only 2in1 solution available that addresses both the headlight mount breakage issue and provides a steering damper mount with NO disassembly of the bike front, NO drilling or clamping into the frame trellis and uses the industry leading Scotts damper. Introductory discount pricing details are in the product description. Please have a look and share:
    https://www.tripleclampmoto.com/pro...d-headlight-brace-for-ktm-1050-1190-1290-1090
  19. dino702
    dino702 OFF2BFE
    Jun 14, 2014
    775
    Las Vegas, NV
    Any word on a production date for the 9X0 Baja Designs lighting mounts for the stock cowling on the Adventures?
  20. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,613
    Payson AZ
    ^^^^ yeah, and the water pump upgrade? and the new air filter setup?
    nk14zp likes this.
