    Dismiss Notice
Triumph Scrambler
Discussion in 'Triumph Tigers' started by danger_dave, May 29, 2006.
  1. plodalong
    plodalong Now if we just.....
    Jun 29, 2007
    822
    griffith NSW
    Have you checked out the TEC baffles. https://www.tecbikeparts.com/produc...-models/scrambler-900/exhausts-scrambler-900/ They sell baffles and cutdown baffles for their exhausts (arrow copies). Dia is 49mm which may be slightly loose but a bit of exhaust assembly paste would sort that out.
  2. skimch
    skimch Oh feck all Supporter
    Jun 15, 2006
    73
    Phx, Az
    Shoot, they are hella loose in their pipes. I've tried everything to keep it from rattling. I ended up just taken it out.
  3. plodalong
    Jun 29, 2007
    822
    griffith NSW
    Heard that but both the origional and the larger bore baffle I got recently fit fine in my tracker exhaust. luck of the draw I guess.
    I've used this assembly paste in the past and it may cure the rattling baffle. You put it on while assembling exhausts and mufflers and it sets. When the exhaust gets hot it expands and sets hard making for a leak proof seal. Need to be careful with it though as it's a pain to clean off if it gets where you don't want.
    skimch likes this.
  4. googlemeier
    googlemeier Adventurer
    Mar 28, 2010
    11
    Nuremberg, Germany
    Hi, hope you can help me with a special question.
    I'm going to sell my Scrambler 08 EFI, fitted with a ZARD exhaust. As I understand, it needs a special mapping software, which unfortunately doesn't match German emission regulations.
    Now, with the standard vanilla programming for the stock exhaust, so the dealer told me, the engine on one hand would meet emission regulations, but on the other hand would soon overheat.
    Would you agree?
  5. George Hanson
    George Hanson Been here awhile
    Feb 4, 2016
    945
    PA
    It would run lean, yes, which means it would run hot.
    googlemeier likes this.
  6. 250
    250 Adventurer
    Nov 23, 2013
    92
    West of the Sierras
    Is is required to meet 2008 or 2020 emissions requirements?
  7. googlemeier
    Mar 28, 2010
    11
    Nuremberg, Germany
    The newest (2020), I suppose... the German biannual technical inspections are thorough.
  8. 250
    250 Adventurer
    Nov 23, 2013
    92
    West of the Sierras
    If it was mine, I would spend a little time to answer that question. I suspect that requirement are stiffer now than twelve years ago. Do you know what map was flashed onto the ECU? Any other hardware changes (such as AI delete)? If you're passing the biannuals, why wouldn't you be able to sell as is?
  9. googlemeier
    Mar 28, 2010
    11
    Nuremberg, Germany
    The original one, I think.
    Not that I know of.
    I'm in a tight corner here.
    After passing the test, I would certainly be able to sell, but the new owner has to look for a Triumph dealer, who basically cheats the officials by uploading the orig. software and after the test reloading the illegal ZARD ECU. Or stop every 10 km to let the engine cool down.
    And since the Triumph dealer closed, we don't have another one in the area here, so this is kind of a disadvantage.
  10. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,600
    Middletown, PA
    VW of America got into huge trouble in the USA doing this with their diesel engines.
  11. googlemeier
    Mar 28, 2010
    11
    Nuremberg, Germany
    More or less a similar case here... both, omitting emissions and increase in fuel consumation.
    But you don't have to fit the bike with a ZARD exhaust, though.
  12. 250
    250 Adventurer
    Nov 23, 2013
    92
    West of the Sierras
    I guess I'm a little slow with what you're trying to explain to me googlemeier. Anyways, when I put the Arrow exhaust on I don't remember a reflash being required, however the TTP remap I put on has been satisfactory. While I wouldn't choose to run a couple hundred miles with a mismatched tune/exhaust, I wouldn't hesitate to deal with the emissions stuff first with them mismatched. I don't think 10 miles will be a problem. YMMV. I did the remap myself, initially with the exhaust and again when the dealer reflashed it back to stock at 12,000 miles. Do you have the ability/desire to remap it yourself?
    Another option would be to sell it as is, with full disclosure to the buyer of the potential emissions complication.
  13. TriumphRTO
    TriumphRTO Been here awhile
    Oct 14, 2014
    359
    Ohio
    Rosie is in the midst of some major upgrades. I've installed 385mm shocks and the +30mm travel extenders in the front forks. I'll post details as soon as I get everything sorted.
    In the meantime, Can folks tell me what they've done to extend kick-stands and whatnot? I am debating bolting a 1" block of steel to the bottom of this kickstand. It will stand up just fine even sitting 1" taller, BUT I would like to reduce the lean a little (and get it closer to stock).
  14. George Hanson
    Feb 4, 2016
    945
    PA
    Thinking the stock kickstand spring might be too weak to support the additional weight of that much steel.
    TriumphRTO likes this.
  15. TriumphRTO
    Oct 14, 2014
    359
    Ohio
    FWIW, I debated 3D printing a part but also concerned it may not last. Perhaps I should carve a solution from Delrin.
    LordMorgan likes this.
  16. Kiwi Mo
    Kiwi Mo Long timer
    Aug 11, 2013
    1,467
    Te Ika-a-Māui Aotearoa New Zealand
    If it was my ride..
    I don't think I would be inclined to add a block to the bottom.
    I would obtain another stock sidestand.
    Work out just how much longer it needs to be.
    As I am a crap welder I would hand it to a mate who is an engineer and ask him to cut and weld a extension to the shaft, ensuring the cut is below the sidestand spring mount.
  17. jwaller
    jwaller Been here awhile
    Aug 23, 2011
    854
    New Braunfels, TX
    I took these pics on the 4th of July, 2013. I had just moved and couldn't find the cables to hook to my digital computer. Packing up our house to move again, I found the cable from the last move and found these pictures from out around Leakey, TX. My Scrambler's looking pretty rough now, not so nice and shiny any more.
  18. RedMenace
    RedMenace Adventure Sidecar
    Dec 22, 2001
    5,529
    GoodLiver,Oregon,USA
  19. 250
    250 Adventurer
    Nov 23, 2013
    92
    West of the Sierras
    On a bit of a whim at the end of last week I picked up a day pass for Yosemite since Tioga road was suppose to be opening today. After booking, my wife reminded me of my dental appointment mid afternoon. :doh
    Well, better get a move on them. I motored up hwy 120 from Sonora to the park, a bit cold but little traffic. Construction is still going on, but at 0600, I only lost a couple minutes to traffic control. The gal at the park gate we pleasant, and getting in with the pass was easy. I stopped at one of the major Yosemite falls viewing areas as you head in valley for a morning snack and enjoyed the view. There was parking everywhere! I'll probably never again see it that empty. I wish I had all day, but I didn't so time to keep moving.
    The triumph, as we all know, doesn't have the longest legs when it comes to gas. And I don't carry any extra. But, there happens to be gas at the turn off to Tuolumne Meadows so I top off. I continue on up into the high country resisting the urge to stop at all the good vista points. You can't resist Olmstead point though, with its different view of the iconic Half Dome. Some more easy parking, jaw jacked a little with an older couple for a few minutes before the mosquitoes found me.
    Last photo op before deciding I really did need to keep moving. And I saw the van that I had be stuck behind coming up Tioga road and I didn't want to do that again.
    A beautiful ride up to Tioga Pass and out of the park. There was an impressive line up for people coming in, 75+ cars easy. I had to wait less than a minute for the 1 car in front of me earlier that morning. Back down to hwy 395, head north, top off the tank and head up Sonora Pass. Climbed to the summit without catching a single car. And then back down to home. Had a big duromax what ever truck try and beat me off the line to the end of the short passing lane. The triumph may not be the fastest thing in town, but come on, lets not be silly...
    Anyways, a great use of a morning and few bucks in gas.
  20. 250
    250 Adventurer
    Nov 23, 2013
    92
    West of the Sierras
    For some reason the first photo refuses to display. Here it is again so you don't have to click on anything. IMG_3560.jpeg
