    Dismiss Notice
triumph tiger 800 - fuel consumption
Discussion in 'Triumph Tigers' started by Mr noname, May 15, 2011.
  1. AwDang
    AwDang Enabler
    Sep 1, 2014
    3,421
    MABDR mile post 0
    If that version of stock is 16/50. Your odo is way off.
    Do you have a way to verify your traveled distance by gps?
  2. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    I do and will verify it tomorrow.
  3. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    Ran a tank thru today with the panniers off and its back to normal mileage so it's those boxy cans. A guy here at the Iron Horse Resort has a Givi rack from his old Tiger I can get for cheap. Think I'll just use my NR soft bags from now on and sell these panniers.
  4. AwDang
    AwDang Enabler
    Sep 1, 2014
    3,421
    MABDR mile post 0
    Did you run the gps mileage?
    I have 8” Jessies that never come off. I was seeing 180 range estimate consistently with the 16/50. But went an actual 257 on a tank. Now that I’m 17/43 my trip and fuel remaining match my gps odo.
  5. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    My comparison was odo miles, doesn't really matter if the odo matches the gps. Without panniers I get x miles, with I get x minus miles. Anyone want to buy OEM panniers cheap?
  6. mylastbike
    mylastbike Long timer
    Feb 28, 2014
    1,047
    Savannah, GA
    2012 Roadie with Arrow exhaust, Givi windshield, no side luggage, hybrid map, 15 tooth front sprocket I get 42mpg average. Was down in the mid 30s when I had the Arrow map.
    My MPG goes down a good bit when I add side luggage. The MPGs with the Arrow map were not acceptable to me.
  7. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    On twisty WV roads today I still had a bar left and filled at 165, better than all the other tanks. I was actually running 87 octane on that tank since that's all they had.
  8. AloneInTheHills
    AloneInTheHills Been here awhile
    Apr 23, 2019
    677
    Nevada, USA
    If you do apple to apples with and without luggage it does have an impact, but I find tire pressure to be a big impact too. I run 50/50 tires and I'm usually running 30 psi. Below that it will drop quite a bit and I almost never run above 33 psi, but that improves mpg.
    Also, grade of fuel matters less than ethanol content a lot of the time. Low or non-ethanol gas will yield better mpg than 10% ethanol and unless you're buying non-ethanol or filling back to back at the same station you don't really know the content.
  9. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    I'm sure all of those variables add up. I'm running an almost bald Shinko 805 rear now. I was glad to see it back to normal without the panniers. I think the design is poor. Triumph never put much thought into their luggage.
