Tubliss Long Term Review
Discussion in 'Equipment' started by n16ht5, Oct 5, 2012.
  1. MadM
    MadM Dreamer Supporter
    Jun 12, 2008
    1,130
    Slovenia
    Thanks :thumb Hopefully it will work on my DS and rally training rides :ricky
  2. Granitic
    Granitic Backcountry rider
    Oct 10, 2014
    972
    New Mexico, USA
    MadM and trc.rhubarb like this.
  3. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,698
    Reno, NV
    Seems to cover it pretty well. I travel light: CO/2 inflator, tire plug kit.. and hand pump capable of 120PSI. I'm running some pretty stiff tires, in the unlikely event the main bladder blows out I'm riding it out.
    Granitic likes this.
  4. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,673
    denver
    HI
    Just got back from 10 days and 1800 miles of baja.
    Rear tubliss on day 2 low pressure chamber refused to hold air.
    Had to replace with on trail with tube.
    That' the 3rd time I have had a trail problem with tubliss and need a real tube.
    3 strikes and your out ! !
    No more tubliss for me ... going back to tubes.
    Scott
  5. braindead0
    Oct 4, 2007
    1,698
    Reno, NV
    What tire? What rim? What PSI was in the high pressure bladder? Were you running any sealant? Details would be nice.
    trc.rhubarb likes this.
  6. FlyFishJeff
    FlyFishJeff Gimme Three Steps
    Jul 12, 2010
    330
    Columbus, OH
    Front or back tire?
  7. shrederscott
    Mar 19, 2014
    2,673
    denver
    HI
    Tire .... maxis desert IT
    Rim ... stock 14 ktm 350 six days
    High pressure ... 105 psi
    Sealant .... stans
    Would also note that my front low pressure chamber was also a problem .... had to add air every day sometimes multiple times in a day
    Front tire was a Moto IT
    Rim ... 14 ktm 350 stock
    High pressure 105 psi
    Details are important....any other ?
    Scott
  8. mslow
    mslow Faccia Brutta
    Jun 24, 2011
    2,865
    Pennsylvania
    fwiw, i'm on my fourth season with the same tubliss kit on my woods bike.
    haven't had to replace anything on it and hasn't failed me yet.
    should also add that i believe that tube-tires will leak air where tubless tires will not (as fast).
    something to do with the inner carcass of the tube-tire allows air to seep through the pores in the rubber, especially with tires that have high natural rubber content. The tubless tires have an additional coating on the inside that seals the inside of the tire better.
    some tube-tires, like the pirelli mt-16, will actually delaminate on the inside and you'll see the cords all along the inner sidewall. they aren't designed to run at pressures down to 6psi and lower.
  9. braindead0
    Oct 4, 2007
    1,698
    Reno, NV
    Is the rear rim width within the 'approved' width for tubliss?
    Was the tire installed new with tubliss?
    I find it interesting that stans sealant wasn't keeping the air in, where did it leak from?
  10. Granitic
    Oct 10, 2014
    972
    New Mexico, USA
    Interesting data, thanks for sharing.
    We are putting very different demands on Tubliss so I wonder if that can explain different results.
    Today I replaced my TR011R trials rear. Even with 15 "fast" Baja rides, this tire had 1564 miles and 133 hrs in 7 mos. The tread was quite worn out and it had one plug in it.
    There was a good 12 oz of HTS (homemade Stans) in it. Last one lasted almost exactly the same miles and hours.
    That works out to 11 miles per hour. I ride 12 inch singletrack 90% of hours ridden. Yes, I occasionally hit 55 on pavement but it is rare and brief.
    Typically I put 5 lbs in the bladders each morning and either add or release a couple pounds to stay at 6 psi in the tires.
    I rode a new KTM 500 6 days for a few miles in Baja. I would speculate that bikes and riding like yours put huge torques and heating effects into the system that my little CRF230F does not.
    For me a great day is 25 miles in 4 hrs and my armor is soaked with sweat. That means I have spent most of the time creeping along tight stuff at 3 mph. Tubliss seems to do well for this kind of riding.
  11. braindead0
    Oct 4, 2007
    1,698
    Reno, NV
    Or an old man on a XRL (me ;-). I ride 99% off road, and typically average about 20-30mph.. 6psi front and rear. So far tubliss has performed well for my riding.
  12. shrederscott
    Mar 19, 2014
    2,673
    denver
    HI
    Rear rim with ... I have no idea ... factory ktm rim.
    Yes it was a brand new tire front and rear
    Scott
  13. goyko
    goyko Been here awhile
    May 21, 2016
    416
    Dallas, TX
    Have the tubliss in my husky te300 for 2 years. Not a single problem. I ride my bike 2-3 times per week at least. Really really low psi. Doing mostly really ruff technical stuff.
    SFC_Ren likes this.
  14. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    35,417
    Pittsburgh PA
    How old were the bladders? I have found I need to chang the bladder every once and a while.
  15. shrederscott
    Mar 19, 2014
    2,673
    denver
    The inner bladder held air just fine
  16. Yinzer Moto
    Jun 13, 2008
    35,417
    Pittsburgh PA
    Sorry, I misread your first post. That is odd that Stan’s did not fix the problem or you did not see a large hole in the tire.
  17. Yard Sale
    Yard Sale let's be bad guys
    Jan 17, 2008
    3,832
    Northern Nevada
    I have a Shinko 546F I installed (new of course) with front Tubliss using Armor All for the liner then soapy water for the tire. I struggled mightily getting the tire on the rim, as I'm the world's worst tire changer. I'm wondering if I tore the bead because the tire has a leak. It is always flat when I check it for a ride. This weekend I rode both days and it went from 9.5 psi to 5.5 psi in 24 hours. There's no way that's just rubber permeability.
  18. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,206
    USA
    I had a similar result on my first installation. I pulled the wheel, aired down both high and low, did the bounce and rotate to re-seat, then reinflated. After that the leak was diminished to almost zero, but I wanted zero. Last step was Slime, did the air down and back thing - it's been great for a year since.
    kenstone likes this.
  19. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    777
    Loomis, CA (Sacramento area)
    Stock rims have 2.15" rim width. Tubliss also works just fine with a 2.50'' rim width.
  20. zoltan
    zoltan Been here awhile
    Sep 4, 2006
    457
    NOCO
    Why 6psi up front? I've tried low pressure in my Starcross 5 Hard front tires (beefy stiff carcass) and it feels mushy/rolly in corners
    ChasM likes this.
