1. eNewsletter Sign Up
Tubliss Long Term Review
Discussion in 'Equipment' started by n16ht5, Oct 5, 2012.
  1. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,697
    Reno, NV
    Kenda Parker DT tires are really stiff, even with the heavy bike and my 280# on it, 6 psi provides a nice contact patch and gobs of traction. So far it's been the best compromise in the sand and rocks in the desert. I don't ride terribly fast, lots of loose rocky single track stuff at 10-20mph. Front end feel good to me, even higher speed sliding the rear around turns.
    I landed on 6ish PSI by trial and error, running less didn't provide any perceived benefit. I'll often run 10psi if I'm likely to end up on any pavement or long stretches of 50+ MPH dirt roads.
    trc.rhubarb likes this.
  2. BaldKnob
    BaldKnob I Wanna Ride
    Jun 3, 2013
    1,724
    SENC
    I've been using the system on 3 bikes for the last 8 years and have never had a high pressure failure. I did swap bladders recently in the 1st Gen but probably didn't need to. Just be careful with the red liner during install, tire changes and when repairing a flat...don't bugger it up reaming the hole for the plug!!!
    trc.rhubarb and braindead0 like this.
  3. bpeterson
    bpeterson no other way to say it
    May 25, 2003
    1,106
    NJ
    I need to do the same - did you do anything w/the previous soapy water (or Armor All) that was previously used to seal the bead, or just air down and add slime to main chamber?
  4. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,066
    USA
    Nothing. I think they recommend that you either Slime OR the other method, but I definitely did Armor-All then Slime. And I'm not stingy with the Armor-All either, I spray that shit like it's free.
    bpeterson likes this.
  5. trc.rhubarb
    trc.rhubarb ZoomSplat!
    Nov 15, 2011
    8,471
    Concord, CA
    Even when I was 320lbs, I ran my Michelin Desert Race front at 8psi on tubes. No Tubliss yet but that's where the tire felt great, especially in sand. Some tires just seem better suited for very low pressures.
    Rogue_Ryder likes this.
  6. braindead0
    Oct 4, 2007
    1,697
    Reno, NV
    There are 2 different lube 'processes'. The AA is for installing the high pressure tube, the soapy water is for installing the tire. Two completely different purposes. Tire sealant is only used in place of the soapy water, not AA (or other similar lube) for the high pressure tube.
  7. MFGamesta
    MFGamesta Been here awhile
    Oct 28, 2014
    571
    San Clemente, CA, USA
    I use AA for the whole install. 3 bikes. No leaks unless sitting for a few days. Armor All all over myself, garage, dog.... No leaks during long weekend rides. 1 roadside puncture repaired on trail with plug and plugged tire lasted a few more hundred miles on it with plug sticking way out.
    NoelJ likes this.
  8. kwb377
    kwb377 It's All In The Reflexes...
    Dec 2, 2012
    731
    B'ham, AL
    I've installed four sets of Tubliss and have only used lots of soapy water for install, no ArmorAll...never had any issue with sealing. Not sure if it's talent or luck.
  9. darkhelmetnl
    darkhelmetnl Been here awhile
    Apr 1, 2010
    358
    I have installed tubliss on my WR250R. Installation is definitely something to get used to. Lots of lube is the answer (like always).
    I also used Ride-on sealant for balancing, lubing and obviously, sealing a puncture.
    I left the bike for more then two months and the bladder pressure was still around 95psi. I haven't ridden of road yet, but that will come soon.
    Monday the bike will fly to Canada, so time will tell if they can stand up to that as well
  10. Snks
    Snks Been here awhile
    Feb 4, 2014
    557
    From what I was told and did, I sprayed armor all on the inner bladder and then put 6-8 oz. of slime in the tire. Armor all and slime are ok together but not soap and armor all.
  11. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,066
    USA
    I slimed and AA'd too and all seems fine months and years later.
  12. braindead0
    Oct 4, 2007
    1,697
    Reno, NV
    The AA and soapy water aren't in the same process. AA is to lubricate the high pressure bladder and where it touches the rim and liner. Soapy water lubricates the tire and where it meets the outside of the liner. Installation instructions call for AA and soapy water, the soapy water is not used if you are using sealant in the low pressure side.. Not sure where you think I said to mix soap and AA?
  13. worncog
    worncog YBNormal Supporter
    Oct 19, 2011
    1,042
    Florida Panhandle
    I used AA for HPB and then Stans for tire mounting lube and for sealant. No problems so far and pressure holds well.
  14. VonBiker
    VonBiker Work sucks and then you RIDE! Supporter
    Mar 13, 2014
    1,266
    Lakewood, CO
    Any recommendations on a tire puncture kit? Going through my tool kit this weekend and realized that i dont have one. Installed the tubliss last year and have not had any problems Happy with it so far!
  15. goyko
    goyko Been here awhile
    May 21, 2016
    415
    Dallas, TX
    You don’t need one. Even if you loose all air, bead still can’t be broken. So you can just ride back.
  16. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    33,745
    Pittsburgh PA
    Regular car tire plug kit with a couple CO2 cartridges. I prefer the plug kits that have a screwdriver type handle instead of the T handle. I also put rubber tubing over the tools to keep them from puncturing me, during a crash.
  17. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    758
    Loomis, CA (Sacramento area)
    I don't agree.
    A plug kit plus CO2 or a small pump is lightweight and easy to carry, plus some tires do not like to be run flat.
    Yard Sale likes this.
  18. Yard Sale
    Yard Sale let's be bad guys
    Jan 17, 2008
    3,763
    Northern Nevada
    Yeah, people have ruined their Tubliss red liners by running on flat tires. Carry a plug kit and small hand pump.
    ChasM likes this.
  19. darkhelmetnl
    Apr 1, 2010
    358
    So far the stats in my tubliss:
    Done about 2500 miles. They're doing great.
    The tubliss bladder doesn't lose much pressure at all.
    The tires neither.
    It also survived a plane transport
    Yinzer Moto and SFC_Ren like this.
  20. Ptjeep
    Ptjeep Adventurer
    Aug 27, 2013
    70
    Have tubliss on a few bikes and love it. Rear only so far.
    As for the comment about not needing a plug kit and riding it flat, you can and I did for 35 miles back to the truck. No issues at all. But like stated above, the red liner will be trashed when you get back if you ride far enough. Mine was so I called tubliss just to get some advice on how to prevent that from happening again and they told me that some slime in the tire keeps the rim lock lubricated enough that when it makes contact with the tire(every rotation), there is no friction which is what ruins the red liner.
    I had plugs but the tire was cut in a way that it couldn’t be plugged.
    Yinzer Moto likes this.
