Tubliss Long Term Review
Discussion in 'Equipment' started by n16ht5, Oct 5, 2012.
  1. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,586
    Bridge over Troubled Water
    delete...sorry
  2. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    32,078
    Pittsburgh PA
    I have run similar distances on flats when I put big cuts in tires. I run the Stan’s sealant, based on your explanation, that must be why I never experienced and bad effects from running flat.
  3. Ptjeep
    Ptjeep Adventurer
    Aug 27, 2013
    67
    That’s good to know that it works, I’ve often wondered. Thanks for posting.
  4. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,124
    Aberdeen, MD
    Installed Tubliss F and R on my 701 (wider rims than it's made for, same as 690) when I installed new GT 723 tires. Rear went fine, got it first time. Front wasn't sealing, did reset, still not sealing, took front off and put back on (then off and on again after I realized I reversed tire), I think it wasn't sealing because I had pulled some of the rim tape up onto shoulder with spoons, cleaned that up while tire was off and it's holding now. No sealant used, just lots of soapy water. Armor-All all over the inside/out of red liner. Used spoke weights to balance.
    Ran a few hundred miles in VT ATV/snowmobile trails, gravel, etc at 15/15psi. Just did TWVT at same 15/15. Had a great time, no issues with tires at all. I pumped everything up before I left, aired down tire chamber once I got out to the route then aired back up the night before finishing and heading home, didn't appear to lose any pressure in the tire chamber, didn't touch the high pressure chamber. Am looking forward to airing down even lower for the sand in the Pine Barrens in NJ. So far so good, no regrets and I haven't even lowered pressures more than I would with just tubes...
    SmittyBlackstone and SFC_Ren like this.
  5. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    455
    NZ
    Just wait till you try <10psi off road. That's where the magic really starts and you have to question whether you are actually cheating :nod
    Yinzer Moto likes this.
  6. ONandOFF
    ONandOFF more off than on
    Aug 8, 2009
    18,014
    The Shenandoah valley of Virginia
    Coincidental, though. Rim tape has nothing to do with sealing. It protects the inner bladder from abrading on the the nipples.
    Yard Sale, Yinzer Moto and braindead0 like this.
  7. shiftymike
    shiftymike Hooligan Schmooligan
    Jul 27, 2008
    321
    Van down by the river!!
    Well shucks after 3+ weeks and 1200+ miles of Tublissfull riding I have been snake bitten. Took a short ride on pavement only to find my tire getting squirmy. Noticed it was low arriving at a friends. Went inside to 10 minutes and asked to use a pump. When I went back out I noticed the tire looking completely flat. Rode gingerly around the block to the garage. Found that the high pressure chamber was completely flat. Pumped up 105, took a lot of muscle to get past 80. Pumped outer chamber bead would not seat. Figured I needed a compressor but when I checked the high pressure again it was 0. Pumping it again it would not hold air. I just took back to Woody's to remove.
    From my previous experience it's likely going to be a separation of the valve stem from the tube. Watched the install video last night. The knurled valve stem nut was run down to the rim, rather than snugged up to air cap. Must have been stressed when tire went completely flat. Wish I had caught that detail when I brought wheel back to be balanced after initial ride!
  8. Yinzer Moto
    Jun 13, 2008
    32,078
    Pittsburgh PA
    I have had a maybe 2 per year fail at the stem. I don’t tighten the nut down, it stays up against the cap and I never notice the stem being angled. I have started replacing the inner bladder every 6 months or so. That reminds me, that is something that I should add to my maintenance log.
  9. goyko
    goyko Been here awhile
    May 21, 2016
    401
    Dallas, TX
    I’ve had mine for about two years. Not a single problem. But again, I’m using them only for dirt technical riding. No pavement or long stretches of high speed
  10. Yinzer Moto
    Jun 13, 2008
    32,078
    Pittsburgh PA
    I have 2 bikes with them, I also go through a lot of tires, maybe 2 tires per month average for the year. 20+ per year. My theory is that is where the valve stem sees the most abuse, when changing the tire. I have gotten more careful and change the inner bladder more frequently and have not see an issue recently.
  11. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,697
    Reno, NV
    2 seasons here as well, on second set of tires (about to be third)... 99% dirt. I'd suspect that a lot of street, on powerful dirt bike may stress things a bit more.
    goyko likes this.
  12. whizzer929
    whizzer929 Adventurer
    Apr 11, 2017
    14
    How often do you guys check the pressure of the inner tube (high pressure)? Also tips on what gauge or procedure used to check it? It always seems like I let a lot of air out when I check mine. Also, Also, what are the long term maintenance items? Relube, re Armor All, etc etc.
  13. braindead0
    Oct 4, 2007
    1,697
    Reno, NV
    I mostly do day rides, often via the back of my truck. I top up mine to 110psi before every ride, typically they don't lose much unless I haven't ridden for 2+ weeks. I haven't done anything maintenance beyond air, I'm only getting a season/season and half out of the tires so new tires I'll slather the liner with armorall and tube/low pressure area with soapy water during install.
  14. Yinzer Moto
    Jun 13, 2008
    32,078
    Pittsburgh PA
    On my dirt bike, I turn my air compressor on, and stop it at 110, then I just hit the tubes real quick before a ride. If it takes more than a millisecond before I hear the air to quit going in, I consider changing the bladder.
    On my dual sport, I have the Red/Green pressure caps, I have gone for month long rides and never needed to add any air.
    braindead0, Tipmethewink and Lutz like this.
  15. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,092
    Marseille, France
    Time has come to replace my first set of tire, which were used with the tubliss on the wrr.
    They were both mt43, "trial style" with tubliss. I'm pretty happy with them and already bought a replacement rear. The front is still "okish" but as i have a planned multi-day ride which may be a bit hard for me and could feature a bit of sticky mud/ruts between a lot of rocky stuff, I'm looking for that trial "feel" with the low pressure cheat from the tulliss+ still some decent street capability (and wear with appropriate pressure) but with a bit more lateral grip for the front.
    So i'm considering Motoz mountain hybrid or extrem hybrid. Was thinking the first one which should be closer to the mt43? If i understand it right only the thread differs (more agressive on the extrem), so the other difference with the mt43 will be a stiffer sidewall?
  16. EP Chris
    EP Chris Been here awhile
    Apr 4, 2017
    103
    NoVA
    Been running tubliss a few months now on a plated DRZ400E with Rideon motorcycle sealant. At first the front tire would lose air over the course of a week, but that has since stopped. Now the back looses air over the course of a week... Minor annoyance, still much better than running tubes out here where the thorns are an inch and a half long should you venture off the beaten path, as often happens unintentionally...
    I was running the 110 PSI red/green caps but I had one fail. It was letting air leak out. Noticed when I got home from work the red was showing, took it off and checked pressure, 40 psi. Tire was at 0 psi. Amazingly I still rode home just fine without the bead coming unseated. When I put the cap back on it started spewing air, so it is now retired on my shelf. I check the high pressure tube each morning before ridding and top off if its below 90 psi. I just turn on my compressor and let it get to 110, then hit both the bladders.
  17. Oddfellow
    Oddfellow Beasty Rider Supporter
    Aug 26, 2002
    832
    Austin, Texas
    This, I've gone plenty long without needing to top off. I usually make sure they are at 110psi when I leave on a trip and then only top them off if it the caps start showing red. I carry a Fox Mt Bike Suspension pump for topping up but I have never had to use it during a trip. I have confirmed the pump will pump them all the way up and the valve fitting is set up so you don't lose any pressure when disconnecting.
  18. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,124
    Aberdeen, MD
    Just swapped rear tire for first time after initial install. Was surprisingly easy with no tube :).
    What tire irons are you guys using? (Hopefully this isn't an oil thread type of topic.) I bought a set of these from amazon a while back: https://smile.amazon.com/gp/product/B01DK2VOS6/ and while they work, I feel it's pretty hard to keep them from sticking in too far and grabbing things they shouldn't.
    I'm looking at these motionpro ones that appear to have smaller lips:
    https://www.motionpro.com/product/08-0006
    or
    https://www.motionpro.com/product/08-0051
    or like this: https://smile.amazon.com//dp/B00RKXO43O/ Seems like this would hook on and barely stick past edge of rim.
    Any ideas?
  19. Aviatordoc
    Aviatordoc BMW R1200 GSA LC and S1000XR rider Supporter
    Dec 25, 2008
    1,144
    Chattanooga, TN
    DSTuTz, the ones in your first link for 10$ are the bomb. I have 4 of them on the bike always and use them to change tires.
  20. goyko
    May 21, 2016
    401
    Dallas, TX
    I use these and love them.
    https://www.revzilla.com/motorcycle/motion-pro-extra-long-steel-tire-iron
    trc.rhubarb likes this.
