1. eNewsletter Sign Up
Tubliss Long Term Review
Discussion in 'Equipment' started by n16ht5, Oct 5, 2012.
  1. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,051
    USA
    Reverse image search on Google will find about anything pictured, but the answer is sometimes unsatisfying....
  2. Tizzle
    Tizzle Workin' on it...
    Oct 28, 2007
    87
    Andorra
    Actually that should be perfect! I’m located in Andorra so as long as they ship there or Spain I should be golden! Thanks!!
  3. Tizzle
    Oct 28, 2007
    87
    Andorra
    Good tip! Thanks!!
  4. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,156
    Marseille, France
    Haha yes, but i went back to my emails to find my order.. back to 2015 :)
  5. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,179
    Aberdeen, MD
    Welp...I found out who makes them. They're Italian, Buzzetti Pro tyre levers. Closest thing to me (USA) I can find for purchasing is Adventure Spec in the UK: https://www.adventure-spec.com/default/tyre-tools-buzzetti-professional-tyre-lever.html
    Says they're made for changing Michelin desert tires and mouses.
    Hrm...Any idea on these? "Ballards Ultimate Tyre Levers"
    They've got wrench ends (dubious usefulness) and seem small enough for easy tool carrying on a trip. Small little end that won't go in too far.
    Also, from my limited research, seems the curved ones are specifically for when you have a mouse.
  6. BornAgain
    BornAgain Been here awhile
    Aug 31, 2008
    800
    Rosenberg, TX
  7. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,179
    Aberdeen, MD
  8. Granitic
    Granitic Backcountry rider
    Oct 10, 2014
    949
    New Mexico, USA
    I've spent the day with Tubliss and as usual learned a few more tricks.
    These are documented in my notebook: http://bit.ly/2Ry7zAL
    Tizzle likes this.
  9. whizzer929
    whizzer929 Adventurer
    Apr 11, 2017
    14
    I had this same tear happen this week. What's more weird is that it happened while sitting in my garage. Luckily it didn't happen while riding. I've reached out to Nuetech but have not heard back yet.
  10. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,156
    Marseille, France
    No fraying of the material on the inside of the red liner at that location?
  11. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    33,576
    Pittsburgh PA
    I have had that happen a lot. It appears that it is the valve stem base material coming unglued from the tube. I always had it happen if the tube was more than a year old. I started changing my tubes yearly. How old is yours?
    sED8frog likes this.
  12. whizzer929
    Apr 11, 2017
    14
    Oh really?? They're about 10 months old. It does look like a seam that's split open. I guess I'll need to start replacing mine as well.
    Yinzer Moto likes this.
  13. worncog
    worncog YBNormal Supporter
    Oct 19, 2011
    1,037
    Florida Panhandle
  14. whizzer929
    Apr 11, 2017
    14
    What the hell?? Put in a new bladder, and the same thing happened after 5 days sitting in my garage. Obviously there is something wrong but I can't figure out what. I think I'm done with Tubliss. The gains are not worth the risks or trouble.
  15. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,179
    Aberdeen, MD
    Been meaning to do an update. I've got 11 months and 5500 miles (178 hrs) on my setup in non-recommended size rims (1.85 F / 2.50 R) and I've been super happy. I've done single digit pressures putting around slowly in rocks/clay mud/log terrain, week-long trips at 15PSI, multiple hour long stretches at 80mph (at street pressures). No issues with sealing, my high pressure bladders don't seem to lose air. I'm on my second front and third rear tire since installing. I never used sealant. Just armor-all at first install and lots of soapy water to do tires. No regrets. Will probably pick up 2 new high pressure bladders and swap them out the next time I change tires as others have mentioned for PM purposes. I've been running GoldenTyre GT723 and GT723Rs.
    Antikid, worncog, braindead0 and 3 others like this.
  16. darkhelmetnl
    darkhelmetnl Been here awhile
    Apr 1, 2010
    358
    I also want to contribute with my experience.
    Have had a tubliss setup on my WR250R. Had 0 issues during my 25.000 km trip through the Americas.
    I changed tires 5 times. Still on the first set of liner tubes. They lost pressure very slowly. Over 3 weeks I had to top them up from about 90psi.
    Installs were always easy, the seating of the bead was the key, depending on the tire
    Used them with sealant, which I recommend. Have used Slime and Ride-on.
    I used Slime as a test and because I couldn't find ride-on in Mexico. Slime did seal a leak that ride-on didn't.
    Would definitely recommend them.
  17. SHEP_5
    SHEP_5 Been here awhile
    Jan 11, 2014
    961
    Western NY, somewhere between Buffalo & Rochester
    exact same thing just happened to me, mpunted up a tire, went fine, it sat for 2 weeks in garage and now its flat. the tube had seperation at the valve stem patch, I will admit its probably 2 or more years old and lots of miles on it
  18. Yinzer Moto
    Jun 13, 2008
    33,576
    Pittsburgh PA
    What is dis
    I have had a lot of their tubes do that to me. 2 bikes running their system for the past 6 years or so. I try to change the tubes yearly. My buddy just had it happen on a 2 week old install.
  19. Bob
    Bob Formerly H20Pumper
    Sep 25, 2002
    3,446
    Corral de Tierra CA, Ketchum ID
    Anybody with ideas how this happens? Anybody ask Tubliss?
  20. worncog
    Oct 19, 2011
    1,037
    Florida Panhandle
    More than likely a cut initiated by the edge of the valve stem assembly. Mine, and all the pics I've seen are all demonstrating a similar pattern. Rubber is very forgiving... till you cut and/or exceed it's bending radius.
    Gentler handling during assembly is necessary, especially around the valve disc area.
