Tubliss Long Term Review
Discussion in 'Equipment' started by n16ht5, Oct 5, 2012.
  1. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    18,612
    Tucson, AZ
    A good option is a pump like this
    http://www.ebay.com/itm/Shock-Pump-...sure_Cycling_BikeLocks_SR&hash=item20cba4896e
    It's small and you can isolate the valve so you don't loose any pressure when disconnecting. Have to pump it more due to its low volume but for topping off works fine. I've got one if you want to try it out but they are pretty cheap.
    #61
  2. PhiSig1071
    PhiSig1071 What's ******width?
    Apr 9, 2008
    2,763
    Tucson, AZ
    I'll check it out. I bought one locally that said it went up to 125, but I couldn't get it to pump over 80 when I actually tried it. It's good to hear from people who have and use them already.
    That's pretty cool. I like that I don't have to worry about losing pressure when I remove it. I will definitely find a pump that has that feature. The tubliss tubes are so small even a split second can drop the pressure down 20psi. However, I think I'll try to find one for sale in the US, as shipping from the UK would cost more then the pump itself! :lol3
    #62
  3. swimmer
    Oct 9, 2007
    18,612
    Tucson, AZ
    Yes, of course, that was just first one that came up on the eBay search. Should be able to find one in the US for about $20.
    #63
  4. PhiSig1071
    Apr 9, 2008
    2,763
    Tucson, AZ
    I appreciate the info, it's good to know what to look for. Apparently that's a feature on hand pumps used for air forks/shocks. Which should work perfectly. I'd like to see the one you've got, but I work midnights Wed-Sun, so I rarely ever make it to the RG or the weekend rides.
    #64
  5. kdennan
    kdennan Been here awhile
    May 6, 2010
    649
    Vermont, USA
    If I run rim weights, how many oz. up front? Rear?
    #65
    generikal likes this.
  6. BajaRat
    BajaRat Been here awhile
    Sep 11, 2005
    711
    The USSA - Köln, Germany
    I have 4oz. front and rear on a KTM 530. (I think)
    You can get a cheapie wheel balancer that works dandy for dirt duty from HF.
    #66
  7. n16ht5
    n16ht5 ride the night
    May 6, 2010
    2,782
    nowhere, wa
    <iframe width="853" height="480" src="//www.youtube.com/embed/hkEHWsialVM?rel=0" frameborder="0" allowfullscreen></iframe>
    The tire... after 25mi, up to 65mph
    #67
  8. FamilyRider
    FamilyRider Been here awhile
    Dec 16, 2012
    631
    Salt Lake City, UT
    I run TUbliss on all of my bikes and love the system. However, on a recent 6-day adventure ride in Colorado I had a high pressure tube failure on the second day. I was really bummed out because I was the only one in the group with TUbliss and was confident that I would not be the one getting a flat. It turns out that I had a faulty tube. The stem did not properly mesh with the tube during installation.
    Jeff at Nuetech validated that it was a faulty tube and replaced my entire setup and gave me spare tubes to carry in the future. His service was excellent.
    Lesson learned - carry a spare high pressure tube on long journeys. (they are way smaller than a standard tube)
    #68
    snare likes this.
  9. gen
    gen Been here awhile
    Mar 28, 2002
    809
    Asia
    So... you took out the Tubliss and replaced it with a regular tube?
    #69
  10. PhiSig1071
    Apr 9, 2008
    2,763
    Tucson, AZ
    I've been running it on my DRZ for over a year now and I love it.
    #70
  11. FamilyRider
    Dec 16, 2012
    631
    Salt Lake City, UT
    Yes - I installed my buddies 17" tube for his KLR. I had to run higher pressure since I no longer had a rim lock.
    I was missing that TUbliss the rest of the week - especially when I hit a nail on the pavement at 50 mph and got a second flat. Scared me to death. Luckily I was able to keep the bike up and I was within 100 yards of the truck at the very end of our trip.
    I also learned that you really want to use tires with a stiff sidewall with the TUbliss system. I had a Kenda Trakmaster II on the rear. I liked the tread pattern, but it was really soft and flimsy when it went flat. I was really lucky it didn't come off the rim when I hit the nail. If I still had the TUbliss in place, that wouldn't have been an issue.
    #71
  12. gen
    Mar 28, 2002
    809
    Asia
    Interesting. So no MX tires then? You'd want like a D908RR or a Mitas E09 Dakar or something similar?
    With a heavier sidewall tire, you lose the weight benefit of the tubliss...
    #72
  13. PhiSig1071
    Apr 9, 2008
    2,763
    Tucson, AZ
    I have a D739 rear and a hard terrain MX front on my DRZ. The D739 is a desert racing tire, and it's a very hard tire, both sidewall and knobs. I can run it at a lower pressure for great traction, but still get good tread life. I used to use the Trakmaster, but it wore out in something like 400 miles of mixed use. I have 500 miles of DS use on the 739, including a trip to Baja, and it still looks almost brand new.
    Results may vary if you're in a state that's a stickler for DOT approved tires on the street.
    #73
  14. FamilyRider
    Dec 16, 2012
    631
    Salt Lake City, UT
    If you are only doing day rides and never stray too far from the truck, so softer tie may be fine. You can either limp back to the truck or send a buddy back for repair gear.
    But if you do longer adventure rides or dual sport, then a stiffer carcass would be good insurance. The videos in this thread with the holes cut in the tire show what is possible with a flat tire that has a stiff carcass.
    I know a lot of people like the Pirelli MT43 trials tire. It works great in the dirt at 5-8 psi and handles pavement pretty well at >10 psi. Jeff Slavens is now recommending the Sedona MX907. That looks like a very interesting tire to me.
    For my case I need DOT, so that limits my options. My next tire is a MotoZ Tractionator Enduro I/T. It is much stiffer than the Trackmaster II, so hopefully it will work out well.
    #74
  15. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,988
    Golden CO
    It also depends a lot on weight. MX tires have very stiff sidewalls relative to MX bike weights. For reference I once got a rear flat on the first lap of a MX race. I finished the race in 5th place (full gate of 40 at Budd's Creek). Still cleared all the jumps, etc. It was squirly on hard pack corners and reacted badly to bumps, but otherwise worked almost as well as normal. Rim wasn't even damaged very badly. :deal That was a 190lbs bike with a 160lbs rider. Double both and it's a whole different story!
    #75
  16. Petrolburner
    Petrolburner Noise Maker
    Apr 7, 2010
    713
    Redmond, OR
    Freakin' awesome! :clap
    I bought a used Tubliss system off craigslist 2 years ago, finally installed it on my new to me XR650R. Racing at Eddieville this weekend, can't wait to try it out with the brand new Dunlop 606 front and rear.
    #76
  17. GI_JO_NATHAN
    GI_JO_NATHAN Long timer
    Sep 23, 2010
    2,665
    Middle GA .....Aparently....
    I've got my system ready to install. Just can't make up my mind about using slime or not.
    #77
  18. Albie
    Albie Kool Aid poisoner
    Mar 31, 2004
    16,002
    NWA
    I'd skip it. Slime is just so damn messy. Besides, you can still ride with a completely flat tire using the Tubliss system. I even did 40+ miles at highway speeds on a flat tire before with it. :clap
    #78
  19. telejojo
    telejojo Long timer
    Feb 2, 2010
    1,420
    Huntsville Ala. foothills of the Smokey's
    I had one on the front of my KLR and the small red inside tire went flat and I like to have never got it off so I could put a regular tube in to get me home.They (cycle gear) gave me a new one and it has been hanging in my shop for 2 years.
    #79
  20. GI_JO_NATHAN
    Sep 23, 2010
    2,665
    Ok cool. That's what I was thinking.
    Was that the first gen?
    Inner liner black inside?
    #80
