1. eNewsletter Sign Up
TY250 project
Discussion in 'Trials' started by Junglejeff1, Nov 1, 2018.
  1. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,357
    Upper Michigan
    The drum does not look worn.Considering the pads do not actually span the whole thing i would think there would be a ridge in there if they were.It works decent now but i think it can be better.
  2. Portlandtyist
    Portlandtyist Been here awhile
    May 10, 2014
    131
    Portland Oregon
    Excellent project.
    I am trying to time my 250A after new points mounted. But my dial Indicator will not function due to frame.
    Any ideas on a bracket (as in TY250A’s shop manual) to use having removed the head?
    Or, perhaps knowledge of a smaller dial indicator that will work through spark plug hole?
    Thank you sirs.
  3. Twin-shocker
    Twin-shocker Long timer
    Jan 28, 2012
    1,779
    Take the head off measure piston position with digital vernier, put timing marks on flywheel and time with strobe light. This is worth doing to any points trials bike, not quite as accurate as a dial gauge but fast and easy and fine for trials motors.
    Junglejeff1 likes this.
  4. Junglejeff1
    Oct 20, 2016
    4,357
    Upper Michigan
    Late update.Installed electronic ignition.Found timing light pretty useless with stock timing mark.Ended up adjusting by how well it would run (just a wee bit advanced of center of slot).Also could not get front brake working to my liking even matching pads to drum.Installed a 77 tt500 wheel with a 1980 yz front twin leading brake.Stops much better now but took a lot of messing around.I had to tig weld a lug on left fork and machine about 1/2" Off axle lug.I am finding oko carb a little bit finicky to weather but not terribly bad.Bike runs great and got its 1st reward taking 3rd at smagical rock.Only 4 vintage riders all. 20190822_121916.jpg 20190824_221058.jpg 20190818_140129.jpg
    slicktop, yamty175, Huzband and 3 others like this.
  5. Junglejeff1
    Oct 20, 2016
    4,357
    Upper Michigan
    Also on the lower coil there is a metal pointer that you line up with mark on flywheel. Out of 3 ty,s I have adjusted that pointer was about spot on.Can use a multi meter,buzz box or timing light.
  6. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    389
    Michigan
    In the past , I found that a longer rod for the dial indicator was required and removal of the exhaust and 2 motor mount bolts ( front and top rear ) allowing the motor to tilt down allowing access without full removal . Last time I set it with the head off and magnetic base indicator and confirmed pointer location .
    Getting it set as close as possible to its 3.4 mm btdc gives it the best overall performance .
    BTW Jeff , how are the emulators performing ?
  7. Junglejeff1
    Oct 20, 2016
    4,357
    Upper Michigan
    I have not installed yet and may not bother.Between the new aftermarket springs and type f tranny oil(about 10 wt) they work well for trials riding.
    Brewtus likes this.
  8. lineaway
    lineaway Long timer
    Oct 1, 2011
    10,713
    nm
  9. Junglejeff1
    Oct 20, 2016
    4,357
    Upper Michigan
