UA...UnderArmor
Discussion in 'Equipment' started by canyncarvr, Jan 4, 2020.
  1. canyncarvr
    canyncarvr Been here awhile
    Apr 7, 2005
    112
    I have some years old UA baselayer stuff. It works well, but it gets to stink after only a day of riding.
    Has that changed? Does UA underlayer clothing still have the tendency to foul-out in short order?
    I gave up on polyester myself when I 'discovered' Merino wool. Still, at around half the price of merino, I might give it another try...if it isn't so awful on the smell.
    Thanks for any input.
  2. canyncarvr
    Apr 7, 2005
    112
    If you haven't tried merino (no blend...all merino) fabric, you will be happy you did if you do. It's not 'resistant' to smelling unpleasant. It just doesn't. Like bamboo (rayon from) socks don't!
  3. yobuddy
    yobuddy Been here awhile
    Aug 3, 2008
    611
    Central Cal.
    Merino wool is the only way to go. Ice Breaker is good stuff but pricey and well worth it!
  4. szurszewski
    szurszewski Long timer
    May 26, 2010
    2,920
    Olympia, WA
    I don’t know about under armor specifically, but synthetic fabrics that incorporate antimicrobial treatments do work much better than the old plain polyester stuff. I still have some high end branded base layers from the mid 90s that work well but get stinky as soon as I sweat a bit (and have since new), but I also have newer stuff that specifically says it’s antimicrobial that works well and I can get a few days wear out of even in polite company.
    Turbocat likes this.
  5. RJ44
    RJ44 Been here awhile
    Mar 7, 2015
    311
    Thunder Bay, Ontario
    Stick with 100% merino. Even at a higher price point, it is well worth it.
    My favourite for the cost is Minus33.
    https://www.minus33.com/
    Rob
  6. Bill Lumberg
    Bill Lumberg Been here awhile
    Nov 7, 2017
    105
    America/North Georgia
    Underarmor or similar quality synthetics don’t stink. For me. Any smell comes from the user. Liberal application of mineral rock deodorant to the pit And Chest Area, and I have never had an odor problem out of underarmor. In the hottest, sweatiest conditions. And I frequently wear it under body armor. I’m around a lot of folks who wear UA daily, and odor simply isn’t a problem.
  7. BruceWayne
    BruceWayne Been here awhile
    Jul 30, 2017
    134
    I wear merino or UA depending on the conditions. It seems to be impossible to make merino stink. If you can do it, you're a smellier human than I. UA will get a bit on the nose after a long day in the heat but definitely nothing bad. The benefit is that it's more comfortable than merino in the high temps.
  8. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,261
    I wear cotton. Wear one, wash one. I stink, but the clothing doesn't. I also use %70 alcohol as a pre-deoderant deodorant. Knocks down bacteria on the skin.
    #8
  9. Peanut_Buttery
    Peanut_Buttery Adventurer
    Oct 20, 2019
    81
    United Kingdom
    #9
  10. DSquared
    DSquared Dilly Dilly! Supporter
    Mar 13, 2015
    1,871
    Burlington WI
    I buy cheap Poly-whatever shirts and shorts for the gym and they would get damn stinky. Some googling determined that my detergent needed an upgrade. This stuff works great
    #10
  11. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    1,683
    Denver, CO
    The mineral rock deodorant just makes it so you can't tell how bad you stink :brow
    #11
  12. Hollywood D
    Hollywood D Been here awhile
    May 24, 2018
    236
    Colorado
    I think UA is overrated. I used to wear their cold weather stuff in the winter but found cotton or actual wool to be superior. Once that synthetic stuff gets funky you can never get it out.
    #12
    racer1735 likes this.
  13. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    1,765
    New Hampshire
    Wool is superior but cotton is not, leave the cotton at home! Cotton has no real insulative value when dry, but when wet it dont dry and pulls heat from your body. Cotton kills!
    #13
    Bill Lumberg likes this.
  14. Bill Lumberg
    Nov 7, 2017
    105
    If your synthetic is stinking, it’s you, not the garment. The bacteria that causes most body odor doesn’t just live in the armpits, it often propagates across the chest. Consider broader application of deodorant. I don’t know anyone who has an odor problem from UA, and that’s with close fit body armor and/or LBV’s. But everyone’s body is different, and there are certainly other base layer options.
    And cotton does kill. I prefer cotton against my skin over anything else. But you won’t catch me wearing it where cold and wet may happen at the same time.
    #14
    Bultaco206 likes this.
  15. Hockley Boy
    Hockley Boy Been here awhile
    Apr 15, 2008
    223
    Essex UK
    Have a look at some bamboo base layers, bamboo has antibacterial properties which definitely helps keep the smell down it also has most of the benefits of merino but at a much lower price.
    #15
  16. kruzuki
    kruzuki Gear in the Machine
    Apr 2, 2008
    1,022
    Toronto, ON
    I wear UA Base 2.0 for cold weather riding and skiing, or UA Base 3.0, when it's really f-n cold, for skiing. I haven't had any problems with odours.
    #16
  17. Mr. B
    Mr. B Slowpoke
    Oct 19, 2004
    2,457
    Minneapolis
    So...who has cotton killed? Cotton has been around a long time and it doesn't deserve the bashing it gets. I have active wear for riding, cycling, yoga, pickleball--some synthetic, some merino wool and some regular old cotton. The wool doesn't smell, but it's pricey and needs special care. The synthetic shirts will smell after a few hours of activity. The cotton shirts don't smell all day. BTW, I've been pretty miserable wearing wool or synthetic shirts under my riding jacket in hot weather. Sure, the shirts will dry quicker once I take the jacket off, but I'm pretty hot and sticky while riding in the heat.
    However, I admit that a pair of wicking long underwear is way more comfortable under overpants than denim jeans.
    To me, the best use of wicking/quick-drying shirts is for travel, so you can wash them in the evening and have them dry overnight.
    #17
  18. Mountainhound
    Sep 25, 2015
    1,765
    New Hampshire
    Not going to argue with you wear whatever you want.
    #18
    Bultaco206 and Bill Lumberg like this.
