Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. TripleTriples
    TripleTriples Been here awhile
    Feb 6, 2019
    443
    OH
    Good question. You may want to try disabling wifi, Bluetooth and mobile data instead of turning on airplane mode. Same effect.
  2. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    808
    Missouri USA
    Just for kicks, I turned on Airplane Mode and this was it's affects on the apps I have installed:
    Guru Maps Pro - no impact
    TomTom Go - no impact
    CoPilot - app can not find satellites.
    I never run in Airplane Mode, so it doesn't concern me. But if one were trying to conserve every milliamp possible, good to know.
    TheRealKnobbytracks likes this.
  3. flamingm0e
    flamingm0e Been here awhile
    Feb 21, 2017
    431
    Oklahoma
    Turn on airplane mode. Then turn on GPS.
  4. scootertrog
    Mar 26, 2011
    808
    Missouri USA
    Tried that. I was in error in my above post, NIETHER CoPilot or TomTom GO work in Airplane Mode. Guru Maps does work. Interesting that the two auto-routing apps are affected and not Guru. I don't know what it is about the Airplane Mode, I'm suspecting it may be a "location" thing. As said before, it doesn't matter to me, I just leave it in Airplane Mode.
  5. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    390
    Livingston TN
    I believe early in this thread that it was determined that the ATT model, which I have will not work in Airplane mode. The Verison version I believe will.
  6. scootertrog
    Mar 26, 2011
    808
    Missouri USA
    Ah..... I do indeed have the AT&T version. :)
  7. TheRealKnobbytracks
    TheRealKnobbytracks Adventurer
    Aug 13, 2018
    11
    Casper, WY
    The OP posted this at the very bottom of said post:
    "OK, you want the maximum battery life and to disable the cellular antenna completely but still use the gps antenna?
    Open the phone (dialer app) and type this:
    *#*#info#*#*
    OR
    *#*#4636#*#*
    When you press the last * it will open this info section. If you scroll down a little you will see "turn off radio". Once you touch that , the cellular radio (and ONLY the cellular radio) is disabled. This will not effect any other antenna. You can turn off other antennas in the regular android settings."
    Octopodes, mouthfulloflake and ohgood like this.
  8. Loadtoad101
    Feb 28, 2017
    390
    Livingston TN
    I don't worry about battery life, I'm plugged into my electrical system and the phone stays at 100%. That's with full power on screen.
  9. scootertrog
    Mar 26, 2011
    808
    Missouri USA
    ^ Yeah, not worried either. I get several good hours of use at full brightness. It's easy to plug in if needed. I do think I'll pick up one of those trick magnetic port connectors though, if nothing else, that'll make for a quick charge connection.
  10. Loadtoad101
    Feb 28, 2017
    390
    Livingston TN
    I just got one of those also, only used it once but it worked great. I like it.
  11. ThomasD
    ThomasD Been here awhile
    Jul 9, 2004
    116
    Bonn, Germany
    My SPRINT DF Pro runs in airplane mode only. I can activate GPS, BT, WiFi as I need them and they stay turned on.
    ohgood likes this.
  12. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    30,138
    The Berkeley of Arkansas
    even plugged in, why waste the energy?
    I always turn the cell radio off, even if you are getting hours with it on, you will get a LOT more with it off.
    and your charger gizmo will likely last longer and run cooler, since its not having to work as hard.
  13. gonzomup
    gonzomup ChainGang Recidivist Supporter
    May 7, 2007
    1,454
    Minneapolis -- or something like that...
    I'm late coming to this party, got here because my really old GPSMap60CS (note, no 'x') is becoming near-impossible to support anymore. I'm a bit tired of the Garmin games and am looking for alternatives. This certainly has my attention. Going to sit back and read through 140-some pages of posts over the next few days. All I'll say for now is @PDX Alamo ... :bow for that first post alone!
    Eatmore Mudd, flamingm0e and ohgood like this.
  14. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,051
    Wet side of WA.
    Completely agree.
    Additional bonuses: besides being kick ass GPS the DfPro has an awesome action cam and it ROCKS as a phone.
    ohgood likes this.
  15. gonzomup
    May 7, 2007
    1,454
    Man...I'm only on page 8 or something like that! You're spoiling the end! :lol3
    Chipk, Davidprej and Eatmore Mudd like this.
  16. lotecredneck
    lotecredneck Been here awhile
    Feb 8, 2007
    124
    Texarkana, TX - Glenwood, AR
    I got my DFPro Verizon in and it seems to do fine, BUT when I purchased Locus Pro it found my location. Now when I downloaded the Texas map it no longer is able to locate my location. I get a nag screen that says the gps is turned off in settings, but it shows to be on! Any suggestions? The gps works fine in Google Earth and Tom Tom as well as OsmAnd. Also, typing in the code to turn off radios does nothing on mine.
    ~Tony
  17. slartidbartfast
    slartidbartfast Love those blue pipes Supporter
    Dec 23, 2003
    10,062
    Southern Louisiana or Southern England or ...
    Sometimes, if the phone is in airplane mode, the GPS doesn't work even when the software says it's on. Try turning airplane mode off.
  18. lotecredneck
    Feb 8, 2007
    124
    I found the issue... The difference in OS between iOS and Android is large!
  19. ohgood
    Sep 21, 2010
    9,007
    alabama
    Kyoceras generally disable ALL antennas when airplane mode is enabled, Ave do not allow any to be turned on again besides bluetooth/wifi.
    getting around that is easy by installing Radio Switcher and turning off JUST cellular via that application.
  20. lotecredneck
    Feb 8, 2007
    124
    I just loaded that app and it doesn't appear to work! Tap the icon and nothing, tap it again and I get a screen refresh.
    ~Tony
