Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. BaddAndy
    BaddAndy Been here awhile
    Oct 8, 2006
    263
    Spanaway, WA
    I mounted a Cycle Gear USB charger to both of my Husky's. I also ordered some short 90° cables, but the 2ft long one I have now wraps inside the cradle nicely.
    JagLite likes this.
  2. marret
    marret Transient
    Jul 7, 2009
    682
    FL and VA
    Luckily the GoPro remote cable worked fine for my DFP. The pins weren't exactly centered as you can see by the marks, but it was good enough. I was going to buy pogo pins and glue them in if needed...Drill a right-sized hole and glue/epoxy the pins into the back of a case I bought from amazon. I just chose a case I thought would work best on amazon. I also removed material from the sides of the case I bought. The linked post I made showed what I did.
    It would be interesting to solder the power leads to the contact and then secure with JB Weld, Sugru or something similar. I don't think anyone has done that yet. If you did that you wouldn't need a phone case.
  3. dr350maniac
    dr350maniac Been here awhile
    Jun 12, 2006
    226
    Spokane, WA
    I ordered essentially the same USB port from Amazon last week while I was camping somewhere.
  4. Northern_Rider777
    Northern_Rider777 Been here awhile
    Jul 30, 2018
    161
    Ontario
    I am looking on eBay and I can't seem to find BaddyAndy's mount, anyone know the model name or have a link?
  5. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,175
    Portugal
  6. Northern_Rider777
    Jul 30, 2018
    161
    Ontario
  7. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,071
    East Med, Greece
    In order to secure the pongo contacts, I used plastic bolts and nuts M5. I drilled the bolts carefully and inserted 3mm pongo pins, where cables have been soldered. It is tricky to manage to get the position of the pongo pins right.
    Cheers
    Eatmore Mudd likes this.
  8. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,378
    Seattle area
    Hi guys, after about 25k miles my Garmin 650T started to acting up. Randomly shuting down, restarting and displaying the battery is not Garmin (it is)...
    I can replace it with a refurbished unit from Garmin for $200, but before I do that I wanted to ask few questions:
    1) Can the ATT or Verizon versions of Kyocera Duraforce PRO 2 run with GPS enabled in airplane mode?
    2) Do you experience power connector/battery failures due to the vibrations?
    3) What software most of you use with the Kyocera? I have invested into USA and Canada Topo maps and City navigator for the Garmin - need to cost analyses on maps if I would switch. Need to be able load GPX tracks, edit and prepare GPS tracks, routing and good topo details - i.e. stream and Mt names, trails and logging routes
    Thank you
  9. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,704
    Central Ohio
    Does anyone actually read the thread before asking a question that has been answered multiple times?
    WECSOG, ohgood and ThomasD like this.
  10. Kelsen
    Kelsen n00b
    Jun 16, 2019
    7
    bozeman, mt
    I cannot tell you that; I would imagine so, but manufacturers do make changes for no sensible reason. My Duraforce Pro (Verizon version) works very well with GPS enabled in airplane mode. I can think of only one reason to get a Pro 2 rather than a Pro, and that is that the battery ("not replaceable"...) would be newer in a newer model, hence more time and use before it begins to require recharging on a shorter cycle.
    RFT!!!
    Dave Kelsen
    "No one gets to live or love without feeling pain, sure, but no one gets to live or love without causing pain, either." -- Kelly Sue DeConnick
  11. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    12,233
    Southern Louisiana or Southern England or ...
    1) Not sure about the Pro. My ATT XD can run with only the GPS on (not the cellular transciever) but my T-mobile phone usually will not (I'm convinced I have got it to do so before but can't always get it to cooperate.)
    2) Battery connection issues are very rare on the Kyocera phones. If you use a magnetic power connector (power only, swivel connector) and a bit of dielectric grease you won't have trouble with the micro USB connector either. If you use regular micro USB cables, you might (although mine survived 12,500 miles to/through/from Alaska including rough roads, dust and rain but that was on my big KTM which actually doesn't vibrate too much.)
    3) The entire thread is packed with information about software. There is a strong focus on Locus (which most seem to prefer) and Osmand but many others are discussed too.
    ohgood likes this.
  12. Kelsen
    Kelsen n00b
    Jun 16, 2019
    7
    bozeman, mt
    I myself took the time to read the entire thread; but I surely don't have it memorized. It is 158 pages, after all.
    RFT!!!
    Dave Kelsen
    I always try to be modest; I'm very proud of that.
    Eatmore Mudd, Davidprej and JagLite like this.
  13. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,911
    Anchorage Alaska
    I can't remember what I posted on any thread a few days before let alone what everyone else has posted. :fpalm
    Eatmore Mudd and Davidprej like this.
  14. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    8,765
    Washington, DC
    Anyone have the screen auto rotate stop working on their DF? I've googled solutions but nothing fixes it. Seems like it stopped after a ride I did that was very rough so lots of vibes may have worked their way to the bars and phone, but I thought these phones were supposed to be pretty rugged and vibe resistant.
  15. BaddAndy
    Oct 8, 2006
    263
    Spanaway, WA
    Have you checked your screen settings?
    ohgood likes this.
  16. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,809
    Wet side of WA.
    Sounds like vibration might have taken out the gyros. These phones are toughened MIL STD 805G or better but the gyros in all phones can be killed by vibes.
  17. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,297
    Missouri USA
    Haven't heard in this forum about any problem like that with the Kyocera. Might just try turning it all the way off then back on.
    ohgood likes this.
  18. DCrider
    May 7, 2008
    8,765
    Washington, DC
    Tried all the above, but looking like it's just the standard Sprint android photo Gallery app that's the problem, apparently it's been know to do this. Will try a different app.
    Laconic likes this.
  19. abramsgunner
    abramsgunner Long timer
    Oct 14, 2006
    1,085
    Lower Alabama
    Picked up one of the $39 fleabay Sprint DFPs, loaded up Locus Pro and slapped on a cheap matte screen protector. I already had the $16 Ram mount (spring loaded curve claws) and a usb charging socket... may have to do some research on the pogo pins. I was running an older K Hydro and the DFP blows it out of the water.
    Short and sweet review => Two thumbs up! :D
    Dread, ohgood and Eatmore Mudd like this.
  20. DirtRider....
    DirtRider.... Wandering Turtle
    Nov 19, 2008
    341
    Southern California
    Ok all... i'm leaving in 2 days to ride the Continental Divide... i picked up a DF Pro off ebay... i've been reading as much as i can in this thread and over on the Locus thread. downloaded maps and locus and playing around with it at the house.
    My latest issue is "no internet connection found" when i try to navigate using Locus. The maps come up and i can select my destination but it will not navigate.
    Yes I'm positive the answer has already been posted in the 159 pages above but I just dont have the time to re-read them due to time constraints. Can someone point to a page in this thread or PDF manual or some other source that will help me set up the DF Pro to use offline as a navigation device?
