Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. n6dlh
    n6dlh Adventurer Supporter
    Aug 19, 2019
    62
    Smithfield VIrginia
    Well it looks like the Active 2 are reasonably priced in the used market and they make a powered ram mount for them.
    AugustFalcon likes this.
  2. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,741
    Just bought my second Kyocera phone today ( duraforce pro) I was using locus on the first one,what other apps are easy to use and import tracks to ??.
    Eatmore Mudd likes this.
  3. flamingm0e
    flamingm0e Long timer
    Feb 21, 2017
    1,687
    Oklahoma
    Guru
    GPX Viewer Pro
    Oruxmaps
    OsmAnd
    BigFatAl likes this.
  4. ohgood
    Sep 21, 2010
    10,022
    alabama
    apn settings for att on Verizon dfpro
    if you zoom in to the notification bar you can see i have 4g/lte working on this Verizon model, with an Att sim card.
    it had a Verizon sim card in it when i purchased it, and i used that to get past the setup wizard that requires a sim card. my android version is 7.x
    gps works in airplane mode
    accuracy is lower (4 meters) than my att device ( 3 metres) but it's fine for single track.
    Emgo and Sonny S. like this.
  5. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,247
    SW. Wa. state
    Thanks for getting back to me ohgood. I have a Cricket sim card and I used those apn settings. Would it work better if I used the AT&T ones you posted ?
    Eatmore Mudd and ohgood like this.
  6. TheRealKnobbytracks
    TheRealKnobbytracks Adventurer
    Aug 13, 2018
    21
    Casper, WY
    I went this route for my DFP and not only is it cheap but it works great. My only wish is that the arm holding the phone be longer.
    Prior to this mount, I used an RAM mount but didn't like how tall it was nor the position of the phone.
  7. Cyclepath
    Mar 17, 2006
    2,247
    SW. Wa. state
    Thanks for the feed back. It looks like it holds the phone toward the bottom half and I was wondering if they contacted the buttons .
    they make it with short legs and longer legs.
  8. ohgood
    Sep 21, 2010
    10,022
    alabama
    i just googled the APN each time I've changed cards.
    Cyclepath likes this.
  9. TheRealKnobbytracks
    Aug 13, 2018
    21
    Casper, WY
    Sorry Cyclepath, this is the one I have. Note that there are no leg at the bottom so you can position the phone where you need it.
    https://www.amazon.com/gp/product/B072DSRF3J/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    I position the top left leg between the 2 buttons on the left side of the phone.
  10. Cyclepath
    Mar 17, 2006
    2,247
    SW. Wa. state
    Yeah, the one I was looking at is a bit different then the one you have. It also says it fits phones from 4" to 6.5" and the kyocera is only about 3and7/8"so not sure it would work.
    TheRealKnobbytracks likes this.
  11. Oh2RideMore
    Oh2RideMore Long timer
    Oct 26, 2007
    1,730
    St Louis MO
    Taking my first cross country trip Friday since switching to a duraforce xd from a garmin 60. Have the maps downloaded, and will be using locus solely for navigation and planning. Might use it for tracks just for later reference. Does recording tracks keep track of average speed, distance, time on road and such like the garmins did? Anywhere I can find that info?
  12. ohgood
    Sep 21, 2010
    10,022
    alabama
    if you're setting out on your first use of locus...
    have you installed and used brouter for route planning ?
    do you have maps installed of all the areas you plan to visit ?
    i would suggest doing some short trips (as a passenger ( thanks @KMM696 ! ) to familiarize yourself. there are a lot of features and a steep learning curve.
    the track recording display shows up to twelve info buttons, iirc, you just have to press the record button again to see it.
    Eatmore Mudd and MAXVERT like this.
  13. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    637
    Livingston TN
    You also need to open brouter and download the areas you want to navigate in. Won't work without doing that.
  14. KMM696
    KMM696 Devout Agnostic
    Jan 10, 2007
    149
    W. Mass
    I went through that learning curve, and agree that it's steep and worth it. What I would recommend, (because it worked for me) is to do some short trips as a passenger so you can work with Locus without distractions like safety and not colliding with hard objects. The first couple times I tried using it were complete failures on my part. 45 minutes in the back seat and it all started to make sense.
    JagLite, cyberdos and ohgood like this.
  15. ohgood
    Sep 21, 2010
    10,022
    alabama
    edited my post, i forgot about that, thanks !
  16. Oh2RideMore
    Oct 26, 2007
    1,730
    St Louis MO
    Have not used brouter nor installed it. Have been using locus pro for small trips and tend to just route manually or follow tracks. Works well this far. Have all is maps loaded so should be good. What is brouter?
    WPG likes this.
  17. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    48,517
    Queen Creek, AZ
    Brouter is the underlying architecture to make your routing actually work. Without it, you just have a graphic map and no way to actually create routes over roads. I assume that when you say "just route manually" you're actually going in an drawing straight lines at each and every turn which is a PIA to do if you don't have Brouter or Graphopper installed.
  18. sjc56
    sjc56 Long timer
    Oct 26, 2006
    2,167
    Broad Brook CT USA
    Okay after reading all these post I'm about to pull the trigger on a PRO. the only thing holding me back is that right now I'm using a non service iPhone 6 in a waterproof case and in daylight you just can't see the screen. Is the Pro bright enough to see with the sun on it? Some people say yes others no. Or just it depend on what GPS you are using and how their maps look?
  19. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,741
    I just bought a PRO on eBay for $55 shipped.
  20. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    12,101
    Southern Louisiana or Southern England or ...
    Depends more on the angle it's at (and angle of the sun, of course). My XD has some angles it's not very visible. New to me Galaxy Tab Active has a much bigger, brighter screen but I haven't been home long enough to try and mount it yet. I plan on getting some thin plastic to make a sun shield - maybe find a small plastic bowl the right size that can be cut up. I've also used the cover of a cheap binder to make sunshades.
