1. eNewsletter Sign Up
Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. Got_Carbs?
    Got_Carbs? Been here awhile
    Oct 7, 2017
    706
    NYC
    I'm already familiar with the rooting situation of this phone. You'll see 1 or 2 reports of root via shady apps, nothing substantiated.
  2. Jamie Z
    Jamie Z I'm serious. Supporter
    Oct 17, 2006
    10,191
    Around Denver
    Right here:
    From this screen, you can create folders, sub-folders, etc. Save whatever files you want. It’s a little clunkier than using Windows or Mac, but the functionality is there. You can manipulate all your files, rename them, move them to new folders or an external device, send them by email or messenger.
    Jamie
    flamingm0e likes this.
  3. flamingm0e
    flamingm0e Been here awhile
    Feb 21, 2017
    980
    Oklahoma
    Thanks. That definitely doesn't look like it did when I tried (admittedly only once) to do it. Like I said, I will give it a shot.
  4. Got_Carbs?
    Oct 7, 2017
    706
    NYC
    It's too bad iOS is so restrictive that SyncThing can't be developed for it. That app is badass. Syncs select folders between my laptop and Android phone when on the same WiFi network. Doesn't use any servers.
  5. Jamie Z
    Oct 17, 2006
    10,191
    Around Denver
    Here’s what it looks like with an external storage device connected:
  6. Jamie Z
    Oct 17, 2006
    10,191
    Around Denver
    Oh yeah, you can even connect a USB hub and connect more than one external device. In my case, my USB SD card reader has two slots:
  7. Jamie Z
    Oct 17, 2006
    10,191
    Around Denver
    Yay! So I wasn't the only one who had this problem?
    Oddfellow likes this.
  8. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    6,519
    Maine
    Has anyone noticed that you can see the charging contacts of a Kyocera Duraforce Pro through the hole at the bottom of the RAM "Quick Grip" phone holder (standard size).
    You can fix that by filling that cavity full of epoxy. I used clear tape to make a flat surface on the phone side and make a hopper on the back. That way I could cast epoxy with the holder standing up.
    Then use care and a hacksaw to chop it off flush. I also used 4 layers of masking tape on the RAM mount to keep the hacksaw from chewing it up.
    THEN you can drill through the clear epoxy to install spring-loaded contact probes (colloquially known as pogo pins). I used what seems to be a "standard" 1.4mm stroke.
    https://www.mouser.com/ProductDetail/Mill-Max/0901-0-15-20-75-14-11-0?qs=/ha2pyFaduj0Lfs89g6pzzuK46L7tscCQJC7HGIIu1/xIUeFULH7bgeN8caWK38v
    Somehow it functions although this piece of plywood may smash around and vibrate less than a dual-sport.
    So here's the ugly underbelly. While not pretty, the wires are protected and the inner layers of the shielded cable are anchored in the epoxy. There are 2 layers of shrink on there with different lengths to serve as strain relief. Pro tip: if you're going to drill holes for cable ties in the side of a cavity that you're going to fill with epoxy, fill the holes or you'll be scooping epoxy off the outside of the cavity for a half-hour. DAMHIK.
    The front side looks better if you're OK with the generally spiky appearance of the Quick Grip.
    This isn't the first in this thread and probably won't be the last. I didn't like the PMA coils I found for wireless charging (ATT) and I understand that pushing current through those coils of small-diameter wire causes a good bit of heat. So here's my solution for charging with the USB port covered.
    https://www.rockymountainatvmc.com/parts/ram-mounts-universal-quick-grip-phone-holder-p
    jhat, ohgood, boulet_boulet and 10 others like this.
  9. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    11,235
    Southern Louisiana or Southern England or ...
    Nice job!
    Grinnin likes this.
  10. Nostromdumbass
    Nostromdumbass a duck is a fowl. a duc is often afoul of the law
    Feb 20, 2014
    108
    doh-SEKY
    outside of the box! Nice!
    Grinnin likes this.
  11. flamingm0e
    Feb 21, 2017
    980
    Oklahoma
    Nice. I was working on a 3d printed version until I had to replace my dfp.
    Yours seems simpler and less math. Lol
    Grinnin and Eatmore Mudd like this.
  12. ThomasD
    ThomasD Been here awhile
    Jul 9, 2004
    136
    Bonn, Germany
    Of course - just to remember the @spokedoc solution :
    https://advrider.com/f/threads/ultr...phones-my-guide.1206076/page-35#post-33410260
    and mine (inspired from spokedoc):
    https://advrider.com/f/threads/ultr...phones-my-guide.1206076/page-57#post-34326982
    Both just a bit cleaner on the backside.
    Grinnin and Sonny S. like this.
  13. ohgood
    Sep 21, 2010
    9,762
    alabama
    flipping sweet!
    and very well done! thanks for the pictures!
  14. Addapost
    Addapost Been here awhile
    Jun 20, 2016
    479
    Massachusetts
    Anyone have problems with the KDFP failing due to internal hardware problems? Is that a common thing? Thanks
  15. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,531
    Wet side of WA.
    If yours did then it'd be the first one we ever heard of.
  16. Addapost
    Jun 20, 2016
    479
    Massachusetts
    Nope. Not mine. Someone on a FB group was spewing shit about them. I just wanted to come here to confirm. Thanks.
    Eatmore Mudd likes this.
  17. slartidbartfast
    Dec 23, 2003
    11,235
    The reason for this thread is specifically because the Kyocera DuraForce phones are especially rugged and reliable.
    Addapost and Eatmore Mudd like this.
  18. Eatmore Mudd
    May 28, 2012
    3,531
    Wet side of WA.
    Thank you for sharing that info. Every bit is important.
    Addapost likes this.
  19. ohgood
    Sep 21, 2010
    9,762
    alabama
    if you replace the battery make sure you replace all the rubber o rings around the screws. I didn't, mine soaked water into its board after i fell on it in a creek. to its credit, I had fallen on it in a creek before and it was fine, but after the battery replacement, not so much.
    fwiw it will withstand about 6-7 drops from 6 feet, screen down, onto a gravel road. it was already water damaged so I figured what the heck.
    Addapost and RustySpokes like this.
  20. Vanilo Petrucci
    Vanilo Petrucci Adventurer
    May 31, 2019
    33
    Belgium
    Since the Kyocera is not sold in the EU (to my knowledge), anyone have an idea what the best alternative is we can get over here quality wise?
    We have Ulefone, Doogee, Blackview and Cubot on the Amazons, but hard to find any decent adventure riders reviews...
    hellsbuddha likes this.
