Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. flamingm0e
    flamingm0e Long timer
    Feb 21, 2017
    1,948
    Oklahoma
    I have a pretty elaborate network setup at home. I found that if I connected to a 2.4ghz ONLY network that it stays running just fine. If I try to connect to a 5ghz network, I get random wifi problems. Is the iPhone only supplying a 5ghz hotspot? Anyone know?
  2. lvscrvs
    lvscrvs Long timer Supporter
    Jan 5, 2010
    1,664
    norcal
    Locus Knowledge Base... https://docs.locusmap.eu/doku.php?id=main
  3. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,710
    Central Ohio
    Tap and hold the point on the map.
    Tap the " > " on the side of the popup.
    Tap the " i " for details.
    Tap the " + " in a shield at the bottom.
    Edit as desired, tap SAVE.
    This may not be the easiest way, but should always work without modifying menus.
    twan40, Eatmore Mudd and AdvNener like this.
  4. ohgood
    Sep 21, 2010
    10,095
    alabama
    pm me with your email address and I'll send you a zip you can import to locus with a bunch of settings that may help you
    Oddball, twan40 and Eatmore Mudd like this.
  5. Josh69
    Josh69 Uhhh
    Dec 3, 2007
    639
    Euroland
    I'm going to get a rugged Android smartphone for GPS use but would like to hear how the touchscreens work with:
    - gloves
    - when wet
    I've looked at the CAT and Land Rover Explore phones. They say they work when wet and with gloves. They are a bit expensive and the specs are 2 or so years behind.
    I've looked at Chinese phones such as Ulefone and Doogee; they are vague on if they work with gloves. These are cheaper and have better tech specs than CAT or Land Rover while still being IP and MIL-SPEC rated.
  6. Nostromdumbass
    Nostromdumbass a duck is a fowl. a duc is often afoul of the law
    Feb 20, 2014
    262
    doh-SEKY
    One of the best tips in this thread is to get a retractable lanyard and attach a touch screen stylus to it.
  7. meteorite
    meteorite MoreDust
    Oct 25, 2009
    45
    Panama SA
    Finally. Now I can upgrade (?!) my old and trustworthy Michelin folding weatherproof paper map series. Can use them as blankets now.
  8. sati8d
    sati8d REALLY?? Eh! Oh! ca va pas non??? Supporter
    Mar 19, 2011
    1,366
    New Bern, NC
    I bought the Kyocera Pro2 and it's not going to work for me....my Samsung 9 is much bigger and waterproof too...
    Somebody interested in a phone for sale - $120 with OsmAnd, Rever and several other apps already downloaded.
  9. flamingm0e
    Feb 21, 2017
    1,948
    Oklahoma
    Unless you give them your Gmail account it doesn't matter what is already downloaded on it
  10. twan40
    twan40 Adventurer
    Feb 9, 2020
    15
    philadelphia
    Thanks everyone. I been playing around with it and starting to get the feel for it. Did the point thing and worked. That was the main part for me just to find my way back. Thanks
  11. twan40
    twan40 Adventurer
    Feb 9, 2020
    15
    philadelphia
    I send me email....thanks
    ohgood likes this.
  12. Josh69
    Josh69 Uhhh
    Dec 3, 2007
    639
    Euroland
    Well I bought a Ulefone Armor X7 Pro rugged Android phone to try out as a navigation device. Was pretty cheap. Infact it was about 1/10th the cost of my iPhone. Will see how that goes once it arrives. I also re-mounted my Garmin Zumo 660 on the bike, but have realised it's not really what I'm looking for now due to no internet connection and an outdated map which I'd have to pay to update. It does have the collection of music I loaded on it about 8 years ago though.
    ohgood likes this.
  13. amgems
    amgems Adventurer
    Sep 5, 2014
    31
    Camp Verde, AZ
    I bought these https://www.glovetacts.com/ They work with a DuraForce Pro
    Josh69 and ohgood like this.
  14. sati8d
    Mar 19, 2011
    1,366
    New Bern, NC
    Lucked out - the place off Ebay will take it back....saves me a buck 50
  15. 12Bong13
    12Bong13 Been here awhile
    Jan 7, 2010
    241
    Rouyn-Noranda, Qc
    I cannot find the answer, but I guess one of you guys will know. I live in Canada and I was wondering if I buy a phone from the us, will it work here if I only use it with wifi? I will not get a data or voice plan, as I have another phone that I keep in my pocket.
    The Kyocera will only be used for my bike.
    Thanks for the help.
  16. Jamie Z
    Jamie Z I'm serious. Supporter
    Oct 17, 2006
    10,832
    Around Denver
    It'll work fine. Doesn't matter where you are.
  17. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    7,419
    Maine, USA
    What @Jamie Z said.
    There are different radio protocols for phones in different places. Canada uses GSM while some US carriers use GSM and others use CDMA.
    But wifi is the same everywhere. There ARE different frequencies, but they are usually adopted everywhere at about the same rate (or in populous areas first then more rural areas).
    If you're getting a Kyocera, there is a difference between phones offered by different carriers. An ATT phone, for example, leaves the phone antenna turned on when in Airplane mode, so it will still use power. Verizon's phone is much handier for use as a GPS unit.
    WECSOG likes this.
  18. meteorite
    meteorite MoreDust
    Oct 25, 2009
    45
    Panama SA
    Riders. My question. I am looking at the Ulefone Armor 8. Looks good on paper. But, will this type of phone work in remote areas. No internet, wifi or network? I am solely interested in its navigation functions. My iPhone will be the backup. A yes or no will do. Then I shall invest the time to read through this nice thread.
  19. Grinnin
    Dec 10, 2005
    7,419
    Maine, USA
    Yes, the GPS and navigation functions will work with no wifi or network connection.
    You will need a wifi connection at some time to load the apps and maps.
    Some apps work better with no connection than others. Some will only download a limited area of maps. Some provide better routing with a connection than they do without. In spite of these limitations to some apps, other apps work great when away from data connections.
    Sorry. Didn't just give only yes or no, but the answer is more nuanced than the question was.
  20. meteorite
    meteorite MoreDust
    Oct 25, 2009
    45
    Panama SA
    Go
    Good deed mate. Accepted as intended. Many thanks.
