Ultra rugged Kyocera phones,GPS smartphones ..my guide
Discussion in 'GPS 101 - Which GPS For Me' started by PDX Alamo, Feb 19, 2017.
  1. CapeMan
    CapeMan Dirt Duffer
    Sep 29, 2012
    342
    Prescott, AZ
    Check this: https://advrider.com/index.php?thre...phones-my-guide.1206076/page-49#post-34043678
    E-Tape as shim stock is still working -- no more spontaneous reboots (YEAH!!!)
    JagLite likes this.
  2. jmcmotorsports162
    jmcmotorsports162 Adventurer
    Feb 27, 2010
    84
    downingtown, pa
    Just wanted to say, i found this thread after researching which GPS unit forever. Eventually decided to try out a kyocera brigadier from ebay for 50$ and that was the best decision. It works great with free offline maps apps, GPXviewer and other mapping apps. Much cheaper than a standalone GPS, and as much, if not more functionality. Still learning it but has been working great so far. Also it is water and shock resistant as well as has QI charging capabilities. I plan to add QI charger to my hondo perfect squeeze for a fully weather proof set up. Thanks to everyone for your knowledge.
    Cheers
    BLucare likes this.
  3. fritzthecat
    fritzthecat Been here awhile
    Jul 22, 2006
    111
    Virginia Beach
    I soldered on a 4in long JST connector pigtail over a year ago. Some good electrical tape to strain relief the wires and seal the pinholes. A little dilectric grease in the connector.
    Peel off the tape and I can still open the back by sliding the 4in wires through the holes.
    If it breaks I can plug in the USB.
    Fritz
    ohgood, WECSOG and Nesbocaj like this.
  4. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    1,323
    Just past the pavement's end in North Alabama
    Sounds good. I like the new avatar, btw.
    Wait a minute... I'm confusing you with a cat of the same name on the Weapons Guild. :shoot
  5. dflow
    dflow Been here awhile
    May 28, 2007
    706
    SW of STL
    Does it start rebooting when the battery charge is very low or even when the charge % is high? That would indicate whether it is charger/cable or battery/phone related. It could be the cable you are using is not cutting it. Another possibility is the plug/interface between the cord and phone is not supported well and vibs are causing a poor/intermittent connection. Try routing the cord so that it loops back under the phone (thereby becoming clamped in place) so it does not move independently from the phone.
  6. levain
    levain STILL Jim Williams
    Oct 29, 2005
    9,437
    Providence, RI
    It does seem like it happens more when the battery charge is lower.
    For the hard restart, I never plug in until I'm at about 25%, so that would naturally be after the battery has discharged a bit.
  7. cplus
    cplus Been here awhile
    Jan 17, 2011
    433
    The Town of Friendy People, YFFs
    Like many here, I didn't want to spend $400+ for a dedicated GPS and looking for alternatives. After reading the this, i decided to take the plunge and bought a DFP on eBay.
    It arrived Friday. So far, so good. Updated the OS to 7.1.2 even without a SIM card and GPS works in airplane mode. I'm a street rider so I installed Osmand, Waze, CoPilot and Google maps to see which I prefer. The big challenge is getting my head wrapped around Android after using iOS devices for many years.
    Many thanks to everyone who contributedbto this thread!
    TonyKZ1, petieboy and JagLite like this.
  8. slartidbartfast
    slartidbartfast Love those blue pipes
    Dec 23, 2003
    8,810
    Southern Louisiana or Southern England or ...
    Read the file with instructions how to manage
    It's a steep learning curve initially - but well worth the effort. I just used my DF XD for a 12,500 mile trip to/from Alaska. It stayed on the handlebars through some truly awful weather, logged every twist and turn, and provided spoken directions (when needed - navigation in Alaska and Yukon is hardly complicated) through BT to my helmet communicator. I dealt with two "issues" along the way:
    1. In very heavy rain, drops would occasionally act like screen touches and bring up the home screen or something like that. It happened a few times and was irritating but ultimately harmless; and
    2. At one point it quit charging (I had it connected to a charger all the time.) I found a small bit of blue corrosion gunge in the USB port and scraped it out with a fingernail. That and a quick squirt of silicone spray into the end of the USB cable solved the problem. Obviously a small amount of water had wicked its way in around the plug. A small dob of silicone grease would have prevented it.
    JagLite likes this.
  9. RonSJC
    RonSJC Been here awhile
    Nov 1, 2012
    772
    SoCal
    Hey all, the slipgrip pro seems like a great mount. Snaps in tightly yet easy to remove.[​IMG]
  10. Tabbi
    Tabbi Adventurer
    Jan 22, 2014
    47
    Germany
    HOW could you update the DFpro to Android 7.1.2? Which carrier do you have? My AT&T won´t update it is still Android 6.
  11. Nesbocaj
    Nesbocaj Earth, we're #1
    Jul 15, 2006
    1,497
    Westchester NY
    Must be a Verizon phone, they put out an update. Sprint and AT&T phones did not get the update.
  12. cplus
    Jan 17, 2011
    433
    Yes, it’s Verizon. I went for a Verizon phone because they’re my carrier so I can pop a SIM card in and use the DFP or add it as a new device.
  13. rarepartbuilder
    rarepartbuilder redemption gypsy
    May 23, 2014
    2,010
    New Brunswick Canada
    I have a verizon with a bad mepi for nav that got the latest up date and also an AT&T as my everyday without the update... be cool if one phone could download the operating system to the other but i guess maybe that would be getting into what rooting a device is about.....
  14. Got_Carbs?
    Got_Carbs? Been here awhile
    Oct 7, 2017
    240
    NYC
    Can't flash Verizon operating system on ATT.
    This is why I love Google phones. Didn't receive the update OTA yet, they probably have it posted on their images page. Easy to flash without even unlocking the bootloader or rooting.
  15. RonSJC
    Nov 1, 2012
    772
    SoCal
    I purchased a AT&T DFP before realizing it was not Qi. How did you set up the pogo pin option?
    Sent from my Nexus 7 using Tapatalk
  16. EZ300
    EZ300 Just wanna ride my motorsickle
    Jul 8, 2007
    1,838
    ARIDZONA
    Can somebody just buy one of these and set it up for me so it works perfectly and I don't have to figure it all out? :thumb
  17. JagLite
    JagLite Long timer
    Jun 17, 2010
    5,908
    Anchorage Alaska
    What an excellent idea!
    Although I would probably need a tutor to teach me how to use it too.
    Preferably young, female, and cute. :D
    TonyKZ1, Snake Oiler and Shawnee Bill like this.
  18. ohgood
    Sep 21, 2010
    7,809
    alabama
    pm me
  19. v4play
    v4play Throttlephile
    Apr 9, 2013
    232
    Traverse City, Michigan
    So...I received my Verizon DuraForce Pro today and loaded Sygic for road use GPS. I'm going to use a modified Ram mount with pogo pin charging. GPS works fine on airplane mode. My questions are: In airplane mode will the phone still hunt for cell towers draining the battery? If I shut off the cell antenna will that effect Wifi? Sorry if these questios are redundant but I'm a Techno-tard!
  20. ohgood
    Sep 21, 2010
    7,809
    alabama
    airplane mode= all antennas turn off
    but
    you can turn on Bluetooth/WiFi/etc as needed whole in airplane mode
    no, airplane mode does not allow cellular searching/connecting.
    TonyKZ1, Eatmore Mudd and v4play like this.
