1. eNewsletter Sign Up
Underseat tank for HP2
Discussion in 'Vendors' started by bavarian, Apr 14, 2008.
  1. Ray R
    Ray R Long timer Supporter
    Dec 27, 2006
    3,007
    Canby, OR
    I ran into an issue while installing the electrical system for my tank. I wired the switch and pump per the instructions. Once I had all the electrical connections done, I turned on the key for the bike to check that everything would work properly. As soon as I turned the key on, the pump started pumping. I tried pushing the button, but could not get the pump to stop. Finally, I had to disconnect the battery to get the pump to stop.
    I double checked and I did connect the orange wire to the red/green of the accessory outlet per the instructions. The other connections were pretty obvious.
    Any ideas what might be wrong?
  2. Ray R
    Dec 27, 2006
    3,007
    Canby, OR
    I already received a response from Markus on my issue. It seems the XRay equipment used to scan overseas shipments likely messed up the electronic switch. He's sending me a new one right away. Great service, Markus!!! Thank you!!!
  3. bavarian_markus
    bavarian_markus Been here awhile
    Apr 13, 2008
    166
    Garmisch-Partenkirchen Germany
    that's my aftersales service :wink:
    Markus
  4. configurationspace
    configurationspace delooper
    Jan 26, 2003
    12,005
    Kanadia
    Interesting. I had a similar problem though it was more intermittant. Some days the switch worked, some days not. At present I have a non-timed switch replacement.
  5. gkaan
    gkaan Bikes on the Brain
    Jul 19, 2004
    658
    Doylestown
    Hi Markus- what is the lead time on these tanks? I am planning on taking my HP2 on the alcan 5000 next summer and would be looking to install extra fuel tank this winter.
    thanks!
  6. bavarian_markus
    Apr 13, 2008
    166
    I'm planning to make a batch of the tanks in one week.
    If there is an interest, contact me.
    Kind regards from Bavaria,
    Markus
  7. gkaan
    Jul 19, 2004
    658
    Doylestown
    markus - have you had any customers that ran their HP2 with your tank in the alcan 5000?
  8. vince taylor
    vince taylor Been here awhile Supporter
    Aug 18, 2004
    110
    Sequim, Wa
    I may need another tank, I recently acquired a Megamoto and need a little more range, any idea when the new tanks will be done and what they will cost shipped to the USA (west coast). Thank's
    Vince.
  9. ztrab
    ztrab Long timer
    Jan 13, 2006
    1,211
    Tucson, Az
    Hi Markus/. The dealer in Tucson wants one. He said he emailed you but never heard back. I may have given him than old email?? I will pm you with his email. Still loving the tank. Did a Baja run in September and used in many times. I am going to replace the breather hose, mine is showing symptoms of rot, may be due to overfilling it ? A minor detail. Damn fine addition! Mike
  10. bavarian_markus
    Apr 13, 2008
    166
    got an email from him - sorry!
    Please try again, I will answer at once!
  11. ztrab
    ztrab Long timer
    Jan 13, 2006
    1,211
    Tucson, Az
    No problem - he is technically challenged. He is out of town this week but asked me to find out how much for the tank and cross bar so he can send you the $. Ill have the shop or John take care of payment. Just PM or email the particulars my email is ztrab@earthlink.net
    Thanks Markus
    Mike
  12. Steady
    Steady Flogster
    Sep 5, 2006
    281
    Johannesburg South Africa
    Hi Markus
    Looking to buy a black tank to fit with stock and Ohlins shock, no pumps and a KTM rear footrest system.
    Many thanks.
    Steady
  13. bavarian_markus
    Apr 13, 2008
    166
    No problem,
    my new batch is ready! email me :1drink
    Kind regards, Markus
  14. WarthogARJ
    WarthogARJ Warthog
    Apr 21, 2009
    39
    Sheffield, UK
    Guys,
    I'm looking for a place to buy a Facet Fuel Pump but NOT the common types.
    I'm struggling.
    Can be in Europe or North America.
    I want Positive Shutoff as well as a Check Valve.
    And more than 12" dry lift.
    I want one of these:
    40257 (preferred) 40176, 40177 or 40178.
    I have one of Markus's tanks.
    Markus provided 40185 which has only the check valve.
    It works, but I want to completely isolate the tank (I get a bit of flow both ways).
    I mounted mine as suggested next to the top frame bar and that means it's about 12" high.
    So that means Model 40171 isn't a good choice: Max Dry Lift of 12".
    I tested my setup and fuel can flow INTO the tank as well as OUT of it (even with a check valve).
    I want to know that the tank stays full (or empty) as my choice.
    I realize I can add a manual valve, but that's last resort.
    I could also move the pump down and put by the airbox/behind alternator to reduce the dry lift height: but I want to use that space for something else.
    So if you know of a good distributor I can try.
    I've tried a few already and they cannot help.
    Thanks,
    Alan
  15. ztrab
    ztrab Long timer
    Jan 13, 2006
    1,211
    Tucson, Az
    www.aircraftspruce.com
    40171 Facet pump with check valve is part # 05-40171 paid $44.30 usd 9/08
    filter # is 479735
    Don't know about the positive shut off valve model, but they stock a lot of Facet fuel pumps.
    Mike
  16. alpineride
    alpineride wanna-venture
    Jan 27, 2007
    175
    salt lake city
    pm ed markus have not heard back anyone got an email for him. Hey Markus if your out there email me at leeballantyne1@gmail.com I want to get this project done while there is snow om the ground
  17. K u r t
    K u r t Been here awhile
    Aug 19, 2004
    258
    Occidental, CA
    Markus-
    I see on your website http://www.gs-equipment.de/page8.php you have pictures of your machine with a fill spout located at the rear fender, aft seat. Do you sell the tank with this configuration? Looks very nice. Thanks in advance.
    Apologies if this has been covered before - 30 pages of thread too much to comb!!
    Kurt
  18. bavarian_markus
    Apr 13, 2008
    166
    this version is not for sold! Its only one for me :evil
    But I have a batch of tanks ready to supply - I think one of my last batches :cry
    But no time in the future for tanks :eek1
    Greetings, Markus
  19. Bake
    Bake adventurer
    May 15, 2005
    10,751
    Just following along here for the read. The product is AWESOME! well done. Particularly like the 2nd BMW filler on your personal ride. Outstanding.
  20. K u r t
    Aug 19, 2004
    258
    Occidental, CA
    I want one, please!
    Thank you, Markus!
    Kurt
