Understanding KTM 690 FI error codes
Discussion in 'Thumpers' started by Singletrack_mind, Jun 24, 2012.
  1. Singletrack_mind
    Singletrack_mind Cave Man
    Aug 29, 2008
    502
    Northern New Mexico
    I have recently bought a 2008 690, and am getting to know the bike. One thing I can't figure out: The Fuel Injection (FI) light appears to be trying to tell me something but I can't translate it's code. When running, and in neutral, it will flash a sequence of 8 flashes, then pause, then 8, then pause, and continue until I put the bike in gear. Then it goes solid and stays on until the next time I shift back into neutral, then it reverts to flashing.
    8 flashes I can find in the owner's manual, but nowhere can I find a reference to what it means when the lamp remains steadily lit. Anyone know?
    Bike runs fine, gives no other sign anything is wrong. This pattern has not happened every time I've ridden the bike, but probably 75% of the time over three weeks or so.
  2. Singletrack_mind
    Aug 29, 2008
    502
    Northern New Mexico
    Rarely is the ADV so completely silent . . . I'm wondering if I'm asking this question in the wrong place?
  3. tonykof
    tonykof Dinosaur Tamer
    May 10, 2010
    173
    Northern MN (BISF area)
  4. MookieBlaylock
    MookieBlaylock Long timer
    Feb 29, 2004
    2,584
    IntheeaglewingpalaceoftheQueenChinee
    have you tried "#8-check throttle grip sensor"? where"input signal from throttle grip too high or low"whatever that means, maybe one of the adjusters is too loose/tight
  5. Singletrack_mind
    Aug 29, 2008
    502
    Northern New Mexico
    Yeah, 8 flashes would indicate the throttle sensor. Nothing seems wrong with the throttle sensor & it's connections. Friends who have these bikes tell me random error codes are quite often the result of contact issues, and as I've gone over the bike for one thing and another, I've separated, cleaned and greased a lot of connectors, but it hasn't changed this behavior. ("greased" meaning with dielectric grease)
  6. Singletrack_mind
    Aug 29, 2008
    502
    Northern New Mexico
  7. Night Falcon
    Night Falcon Structural Failure
    Dec 25, 2008
    9,308
    New Zealand
    I think the FI light stays lit when the bike is in gear and there is an error somewhere in the electrics. To find the error code the bike needs to be in neautral.
    but dont quote me on that :D
  8. shank
    shank Shank950
    Nov 7, 2006
    942
    Diddillibah, Qld, Australia
    G'day.
    Can someone please help me out with a
    "BLINK CODE" Issue.
    9 Long and 4 Short Blinks.
    Manual states - DBW Stopping, Control A
    I get DBW is Drive By Wire. as for how to fix or what to look for, I am at a lose. any help great fully accepted.
    Shank
    #8
