1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Understanding the Modes on the 790 Adventure R
Discussion in 'Parallel World (790/890)' started by Jarrett2, Jan 29, 2020.
  1. Jarrett2
    Jarrett2 Been here awhile
    Apr 11, 2018
    650
    New Braunfels
    Just got the bike and trying to get an understanding on the different modes. The manual says:
    Street:
    Homologated Performance with Balanced Response
    Normal Slip
    Anti-Wheelie Active
    Rain:
    Reduced Homologated Performance for Better Rideability
    Normal Slip
    Anti-Wheelie Active
    Offroad:
    High Slip
    Anti-Wheelie Deactivated
    Does this mean Rain and Offroad mode have the same throttle response profile different only by the MTC and Anti-Wheelie settings?
    When you go from Street/Rain to Offload mode, does that switch it to Offroad ABS mode as well or do you have to set that separately?
    Rally:
    Throttle Response Options:
    Street - Balanced Response
    Offroad - Very Direct Response
    Rally - Extremely Direct Response​
    Does Rally mode change ABS? Or does ABS have to be manually adjusted in every ride mode?
    Finally, what settings do you use on and off pavement?
  2. Jarrett2
    Apr 11, 2018
    650
    New Braunfels
    Just called KTM support and they didn't have great info.
    Did hear that the lean angle stuff deactivates in Offroad mode.
    And they said the quickshifter is NOT enabled by default, but mine seems to be?
  3. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    1,926
    Upstate NY
    I believe so, but since I rely on Rally Mode, I've forgotten
    ABS is on both wheels by default in all modes. You can set this separately in the ABS menu. Each time the ignition is cycled, it resets to full ABS
    See above...
    I use Rally mode all of the time with throttle set to offroad - rally throttle is too jerky in 1&2 gears for me.
    For on road I leave ABS on both wheels and set TC to 6-7. If its wet, I'll blip it up accordingly. I haven't ridden in a full rainstorm yet, but that might be the time I switch out of Rally and into Rain using those presets. Essentially just Rally with full ABS, TC at 9, and throttle at street.
    For off road I set ABS to offroad, TC to 3-4 and change on the fly as conditions change.
    Here is a summary I wrote for another post...
    In Rally mode you can set throttle level and TC independently from each other, essentially allowing you to replicate all of the other modes while staying in Rally mode. In the other "preset" modes, the throttle response and traction control are pre-determined. ABS is on both wheels by default in all modes.
    In addition, you can turn on/off TC in the MTC menu, but you cannot change the preset TC level for each mode. That can only be done in Rally mode.
    Likewise in the ABS menu you can toggle ABS between both/front/none.
    So if you choose a ride mode other than Rally, you will set the throttle response and the TC level to some pre-determined values, then you can turn off TC completely, and toggle ABS as you choose, but you can't change the TC level or modify the throttle response. Once the key is turned off, the ABS and TC reset themselves, while the ride mode is remembered.​
  4. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,173
    FIN
    Abs stays on offroad more during ign off and it does remember tc setting (rally mode) but if abs set to off or tc off - it will be back on after restart.
    Abs is set separately from drive modes.
    Edit. If I recall correctly Offroad has more power than rain mode. Those both are survival modes and if planning to actually ride offroad, rally is the best choice.
    DRglidarn, TrailTrauma and EvilSteve like this.
  5. Beeners
    Beeners Adventurer
    Apr 14, 2014
    74
    Placitas, NM
    Just to clarify, in Rally Mode, the ABS and TC do not reset themselves once the key is turned off -- Correct?
  6. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    313
    Southeast Kansas
    Mine stays at the setting i choose for ABS and TC, though sometimes (not always) when in rally mode the throttle response setting will change after power cycling. I frequently use offroad throttle in rally mode to get rid of the twitchy rally reaponse, but set TC lower.
  7. EvilSteve
    EvilSteve Not so evil, not so Steve.
    Jun 30, 2008
    903
    SoCal
    I actually don't know the answer to this. I thought it kept whatever mode you were in but I'd need to confirm. Meaning, if you set your ABS mode to offroad in offroad mode and then switched to Rally mode, you'd be in offroad ABS mode but I'm not sure.
    On road: Rally mode, street throttle, road abs
    Off road: Rally mode, street throttle, offroad abs (I also play with TC and ABS off entirely)
    I *thought* Offroad throttle mode was softer than street throttle mode?
  8. EvilSteve
    Jun 30, 2008
    903
    SoCal
    When in Rally mode, if you have any TC or ABS setting *other than* off, those settings are retained on turning the key off and on again. If you have either (or both) set to off, turning the bike off and on again resets those to "default". I've seen my TC go back to whatever it was in Rally mode (level 3 or 5 or whatever) and ABS goes back to Road.
    Very important to keep an eye on this if you're TC/ABS off riding offroad and your bike has a nap. :-)
    #8
    TrailTrauma, ramirin and kubcat like this.
  9. kubcat
    Sep 22, 2016
    1,926
    Upstate NY
    Throttle mode sensitivity while in Rally mode is Rally->Offroad->street
    I do not know if the corresponding ride mode throttle settings are the same, nor do I know of any way to check or confirm.
    #9
    EvilSteve likes this.
  10. Jarrett2
    Apr 11, 2018
    650
    New Braunfels
    Thanks for all the good info so far. Trying to absorb.
    Is throttle response separate from power output?
    Meaning, the manual says Offroad mode has reduced power overall, but the throttle is more sensitive/jerky?
    Or put another way, if you were going to drag race, what settings you use to make you had all the performance you could get?
    #10
  11. kubcat
    Sep 22, 2016
    1,926
    Upstate NY
    no; power out = throttle response
    #11
  12. Jarrett2
    Apr 11, 2018
    650
    New Braunfels
    This is where I get confused.
    In the "static" modes, the manual says:
    Street = homologated performance with balanced response
    Offroad = Reduced homologated performance for better ridability
    In Rally mode, manual says:
    Street = balanced response
    Rally = extremely direct response
    Offroad = very direct response
    I take that to mean that Offroad has less power than Street in the static modes. But not sure if it is consistent when going into Rally modes.
    Could it mean that Offroad is more jerky but less powerful than Street in both static and Rally modes?
    #12
    EvilSteve and Beeners like this.
  13. kzeb
    kzeb Been here quite some time
    Oct 22, 2006
    334
    Scandinavia
    My head hurts :lurk
    #13
  14. kubcat
    Sep 22, 2016
    1,926
    Upstate NY
    From the many posts that I have read, a lot have people have come to the same conclusion, but I don't see any way to confirm or deny those conclusions that compare throttle responses by various modes, other than by the seat of the pants. Since I prefer to leave it in Rally mode all the time so I can change TC on the fly, getting an answer to that question just isn't relevant to me. I no longer concern myself with which ride mode throttle is quicker/more
    responsive.
    What is relevant, that I have observed and others have confirmed, is that while in Rally mode;
    • Rally Throttle is very twitchy and really requires an "all-out" riding style of a pro-level rider;
    • Offroad Throttle is pretty snappy and allows a pretty quick response, but still lets you roll-on more gradually than Rally Throttle
    • Street Throttle is noticably less responsive than offroad
    #14
    EvilSteve and Jarrett2 like this.
  15. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,635
    Finally made it to Fruita!
    Interesting, this is not my experience with Rally mode throttle settings.
    Rally- Hits hard off-idle, very abrupt response, full power in higher rev range.
    Street- Smooth response off-idle, spools up quickly, full power in higher rev range.
    Offroad- Very smooth response at all rpm, doesn't feel a strong in higher rev range.
    #15
    DRglidarn, nibby, TrailTrauma and 4 others like this.
  16. kubcat
    Sep 22, 2016
    1,926
    Upstate NY
    From my seat-o-pants dyno, the rollon from stopped is sharper in offroad than in street. As for high rpm response, I am not an aggressive offroader, so I tend to keep it in the 4500-6000 RPM range and tool along. When I'm on the street I will wind it out, but I have never thought to compare top-end throttle response, since the bottom end differences were so obviously different to me. With all of that said, you may well be correct at the higher RPMs. What is your observation of the differences at bottom-end reponse, or do you twist right past those rpm ranges:gdog
    Boy, I sure wish someone would crack the ECU maps - thats where all the answers lie.
    #16
  17. ramirin
    Mar 25, 2008
    1,173
    FIN
    I think I agree with @AdvRonski
    I quickly tried offroad modes and didn't like since they took away the snappy wheelies needed to go over sudden rocks.
    After playing around with modes I set abs to offroad, it has stayed there ever since. Then I put rally mode on and only change between throttle response rally when in mood for active riding and street when just riding.
    If in soft sand then tc completely off (it will come automatically back on), otherwise active riding no. 1 and just riding play with numbers 1-9 depending on mood.
    #17
    kzeb and TrailTrauma like this.
  18. kubcat
    Sep 22, 2016
    1,926
    Upstate NY
    Do you mean Offroad Ride Mode, or OffRoad Throttle setting in Rally Ride Mode? I notice Street Ride Mode is quicker than Offroad Ride Mode, but still stand by my experience of low-end throttle responses in Rally Ride Mode
    #18
  19. AdvRonski
    Feb 4, 2007
    1,635
    The difference that I notice is that the initial response feels very similar between Offroad and Street throttle modes, but instead of the spool-up power of Street, Offroad doesn't ramp up at all, just staying very linear as it revs. This is good for very technical or low-traction situations, as you don't have to rely on the TC as much, but I prefer Street throttle for the majority of my riding as the smooth initial response doesn't upset the chassis, but the generous horsepower is just a second or 2 away.
    #19
  20. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    6,038
    Ontario .. Superior
    I've never tried street ThR offroad. I'm going to try that next season. I found Rally ThR too off/on for my neuropathy, so I dropped into Offroad ThR and never looked back, and never even thought to explore how Street ThR felt offroad.
    Good discussion.
    #20
    kubcat likes this.
