(Updated 2.25.18)Machined some fork guard brackets today
Discussion in 'Hard. Core. (1090/1190/1290)' started by MVmann, Jun 27, 2016.
  1. MVmann
    MVmann Made In America (with German parts)
    Aug 14, 2015
    135
    Loveland Colorado
    I did the high mount fender a few months ago and finally got around to machining some brackets today. I don't really care for the zip tie on the forks guards so.....
    don't mind the hardware holding them onto the forks (stole some off the bodywork) haven't had a chance to go to the hardware store.
    Unfortunately the way the fork bottom itself is cast it makes it hard to get them much tighter (closer) to the fork. Ver 2.0 I can move closer by approx .25
    The right side guard sits a little further away than the left as it was designed for clearance to the disk brake. I will compensate for that on the next set, and also offset the flat in the first picture back as much as I can to get the guards closer. The guards are from a KTM SX85. Brackets are Aluminum 6061 T651. Let me know what you think.
    MJSfoto1956, Hopey, bavbas and 9 others like this.
  2. Lutarious
    Lutarious Renaissance Man
    Dec 28, 2013
    383
    Oakland
    Ill buy a set of those right away. Paypal okay?
    Hopey likes this.
  3. MX Engineer
    MX Engineer MX Racer
    Dec 22, 2015
    1,350
    Ann Arbor, MI; Lake Havasu City, AZ
    Awesome! I want a set too!
    Do they make white fork guards for this KTM85?
  4. Barekat
    Barekat Looking to get dirty Supporter
    Jul 28, 2013
    3,897
    North of Toronto
    Looks interesting for a mount. I'd be concerned a hard hit would push that aluminum bracket right into the fork tube. :arg
    sieg likes this.
  5. MX Engineer
    Dec 22, 2015
    1,350
    This hard of a hit would first have to bend the cast bracket on the "knuckle". Then we will have much bigger problems!
  6. Barekat
    Jul 28, 2013
    3,897
    North of Toronto
    Good point. I like the clean look of the high fender.
    MX Engineer likes this.
  7. Duane1969
    Duane1969 Been here awhile
    Jan 7, 2008
    420
    Little Rock, AR USA
    Very...........very nice! I'd like a set too when available! :thumbup:beer
  8. MX Engineer
    Dec 22, 2015
    1,350
    I have bought a high fender kit, and I am just waiting to find a solution for the fork guards before I bolt it on. Can't wait!
    I have a question that I need to resolve in my head though. I've been curious if high fenders have some sort of a disadvantage. Will I ever come to miss the low fender, like on a rainy day, for example? Perhaps my worries would only apply if I had no windshield...
    #8
    alfonso_antelo likes this.
  9. MVmann
    Aug 14, 2015
    135
    Loveland Colorado
    I will be changing a few things this weekend to get a slightly better fit. I have to order some more material and figure out a price, I will keep everyone up to date.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    #9
    Johno33772, jengel451 and MX Engineer like this.
  10. Duane1969
    Jan 7, 2008
    420
    Little Rock, AR USA
    #10
  11. sati8d
    sati8d REALLY?? Supporter
    Mar 19, 2011
    1,219
    New Bern, NC
    Me too
    Sent from my SM-G935V using Tapatalk
    #11
  12. Lutarious
    Dec 28, 2013
    383
    Oakland
    Seems like you could move them in to center properly on the fork tubes and maybe cut away a little bit of the plastic to make it clear the brake disk. Anyway, I really like this approach. Hope you get some done in time for our big trip to South Dakota this summer.
    #12
  13. fishrman
    fishrman Been here awhile
    Aug 8, 2011
    130
    Western Colorado
    I'm in :y0!
    #13
  14. MVmann
    Aug 14, 2015
    135
    Loveland Colorado
    Update:
    I had some time this afternoon and machined Ver.2.0 I wanted to get the guards to center better on the forks and also move them back around the forks further. Here is what I have so far.. Ver.2.0 on the right
    The left fork guard will require slight trimming of approx. 1/8 of an inch to clear the disk bolts. The right side guard is already trimmed to clear the brakes on the KTM SX85.
    This side pic is of the original design, you can see how far the fork guard is away from the fork.
    This pic is from Ver 2.0 it wraps around the fork better but still not as closely as I would like. Unfortunately this is as far back as I can get it, the design of the fork makes it difficult.
    I have a little more work to do on the design, just some more clearance on the back side where it contacts the cast "fingers" for the original fender.
    I should be able to make some changes this weekend and hopefully post up with a final product. I am thinking of $50 per set shipped to conus, this will include 4 socket cap or button head Allen bolts to mount the brackets to the bike. I am still trying to source some bolts for the fork guards themselves (69008021160 SPECIAL SCREW M5X12) as KTM wants $$ as does most other places $2.69 a piece. The easiest thing to do would be to use the existing shoulder bolts that came off of the original fender (you should have 6 of them).
    The brackets will come in the raw as I don't have access to anodizing. They are made from 6061 T651 which is very corrosion resistant and would be fine un-coated in most environments.
    #14
    Hopey, fir_chan, michdave and 6 others like this.
  15. MVmann
    Aug 14, 2015
    135
    Loveland Colorado
    Final Ver.2.1 is complete! bolts right up with no fitment issues.
    Looking down onto the fork guards.
    I am waiting on material now, hopefully middle of next week. I should be able to start running them next weekend. I will be doing twenty sets for the first run. I will keep everyone posted.
    #15
  16. michdave
    michdave Been here awhile
    Apr 13, 2014
    473
    La Plata, MD
    Thank you for building those. I haven't committed to a high fender yet, but seeing so many folks zip-tying those things in place made me cringe. LOL.
    That's a nice finished look now. Well done! If I end up going that route, I'll definitely be contacting you if you choose to make more and sell them.
    Nice work and thanks for sharing!
    #16
    Tomdog and MVmann like this.
  17. sati8d
    Mar 19, 2011
    1,219
    New Bern, NC
    Dude that is really nice work!
    Sent from my SM-P550 using Tapatalk
    #17
  18. Duane1969
    Jan 7, 2008
    420
    Little Rock, AR USA
    What he said!!!!!:thumbup
    #18
  19. Dirtroadsinms
    Dirtroadsinms Been here awhile
    Jan 29, 2013
    156
    Brandon Miss.
    I'm in for a set too, just let me know when. Excellent craftsmanship
    #19
  20. TDye82
    TDye82 Adventurer
    Apr 3, 2016
    86
    KCMO
    Nice work! I would like to put my name on the list for a set.
    #20
