1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Ural dishes the dirt...3 wheel drive
Discussion in 'Hacks' started by outfit, Jan 18, 2011.
  1. Agent Wayward
    Agent Wayward 2 wheels good, 3 wheels better!
    Mar 30, 2009
    433
    Croatia
    I agree with Mr Windmill's thoughts entirely. :)
    Sadly, I don't have video evidence, but then again, I didn't set out to show off my 3wd skills to the world. Oddly enough when I go off road, I don't often have a camerman following me and it's really quite tricky to video yourself when riding, don't you think?
    I've got some good still shots of myself on a 1WD Ural at over 2000m altitude on snow in the alps, if you're interested? And I believe their is a video on Utube of me riding through a huge water filled bombhole in a forest. Filled the carbs with water on that one. :)
    Nice to see that Dutchmen still love their chips, even if they do keep them on their shoulders. :rofl
    #21
  2. Agent Wayward
    Mar 30, 2009
    433
    Croatia
    No trailer, pulling one offroad isn't really my idea of fun, though I do pull one on the road. ;)
    OBVIOUSLY, I was poking a bit of fun at our Russian comrade.
    I do apreciate the engineering as I said.
    However, had he aproached the situation differently, he would not have got stuck, I reckon that is pretty obvious too.
    #22
  3. Sidecarjohn
    Sidecarjohn SidecarJohn Supporter
    Aug 29, 2008
    1,267
    Yorkshire, England
    "I've been through worse situations than that on a standard single wheel drive Ural with a knobbly on the back."
    Evidence please, Agent Wayward ?
    Whatever else, it seems that most of those who have looked at these latest videos are reasonably impressed.
    #23
  4. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    Looks like he could use the driven trailer wheel option.
    #24
  5. USMCG_Spyder
    USMCG_Spyder RPOC pilot
    Jul 11, 2006
    5,137
    Texas
    :nod
    #25
  6. ivara
    ivara Been here awhile
    Feb 18, 2010
    327
    Norway
    I found out that with almost 20 year old tires on snow, the Dnepr MT-16 2WD did not help me much at all. I struggled on flat ground :D
    But then, I'm a total novice at this stuff..
    Some model "Ivan" snow chains helped a lot, but I had to put them on the hach wheel too.
    #26
  7. Agent Wayward
    Mar 30, 2009
    433
    Croatia
    Sorry, I hadn't realised we were in court. :D
    If I can refer you, honorable Sidecarjohn, to my response above, m'lud, I'm afraid that there I shall have to rest my case.
    Once again, I'm impressed too, by the build and the rustic engineering, just not by the riding.
    #27
  8. dillon
    dillon Low Speed, High Drag
    Mar 29, 2006
    1,676
    Spokavegas, WA.
    A friend of mine that I whent through diesel school with and I were talking about Urals the other day. After a few beers we started talking about taking a variable displacement hydraulic pump right off the engine, then run it to variable displacement hydraulic motors on each wheel. Once you got it synced up, you could run fast, and have good torque and have 3 wheel drive. We also started thinking about replacing the Ural engine with a small diesel. Both of us really want to do this.
    #28
  9. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    8,124
    Aspen Colorado
    Be sure You do a Build report. I wanna see this beast
    #29
  10. outfit
    outfit Been here awhile
    Jul 23, 2008
    684
    Orkney Isles
    Being unfamiliar with all round drive, is there some sort of ratio applied to the different wheel's, or is it the same ratio all round?
    #30
  11. ivara
    Feb 18, 2010
    327
    Norway
    you mean power distribution?
    On my my 90's Dnepr with 2WD, there's a regular differential, meaning that it'll spin the tire without traction.
    From what I understand, 2WD Urals is a part-time system with no differential...?
    #31
  12. USMCG_Spyder
    Jul 11, 2006
    5,137
    Texas
    Correct; it is selectable direct-drive.
    #32
  13. dillon
    Mar 29, 2006
    1,676
    Spokavegas, WA.
    Only thing that really stopped us was how to keep the tires from "scrubbing" on pavement. I would think I would just make it so on pavement your just running the tractor rear, then run solonoid controlled valves to allow fluid to the other two wheels. It would be stupid expensive, and way cool.
    #33
  14. SamM
    SamM Jeep Overlander
    Nov 1, 2004
    1,478
    West Virginia
    There is already something very similar to this. It's build on a Rokon and is called the Sumac MT. The MT means motorcycle tractor. I don't think it's possible to move enough fluid to get road speeds out of it though. Topspeed on the Sumac MT is about 25mph. I'd love to see someone figure it out! You diesel guys could do it.
    SamM
    #34
  15. USMCG_Spyder
    Jul 11, 2006
    5,137
    Texas
    Interesting...
    #35
  16. SamM
    Nov 1, 2004
    1,478
    West Virginia
    The 3 wheeled configuration is very different. The rear wheels run on outriggers. The outrigger units lift the single rear wheel off the ground, as it is no longer powered when the outrigger wheels are installed. This is what makes it a tractor. It uses a small Honda gasoline engine that drives the hydraulic pump, each wheel then has a gerator that drives the wheel. You can run any hydraulic powered accessory made with this setup. From posthole diggers to chainsaws. The gentleman that built this uses it to dredge for gold.
    I could see myself towing a mower to cut my very large lawn. He declined my offer to build a second one for me!
    SamM
    #36
  17. ivara
    Feb 18, 2010
    327
    Norway
    a friend of my dad, that had worked as a mechanic all his life got partially disabled after gettin struck by lightning. H then set out to build a kind of vehicle that allowed him to enjoy the nature as before.
    The vehicle could best be classified as a small buggy, tube frame , aircooled VW engine driving a hydraulic pump - and hyd.motors on each wheel. Not sure if he ever got it finished... Sorry, no pics available
    Then, many years later, I got aware of this awesome "wheelchair":
    14HP, 4 Mph
    options include snow plow, winch, canvas top etc. And more than one moose has been pulled out of the woods with one of these
    #37
  18. bk brkr baker
    bk brkr baker Long timer Supporter
    Jul 19, 2006
    11,732
    The Bluegrass
    I saw this at the Barber Vintage Festival in '08. The fellow had a handout sheet to explain how it worked. Diesel power ,variable speed pumps,reverse!, Air adjustable ride height etc.
    The frame and forks are aluminum, so the weight is much less than it appears. The front and rear swingarms are single sided for easy wheel changes.
    While the appearance is agricultural that works for me, as I farm. I think this has good potential as a base for a three wheel drive sidecar.
    The guy also said he'd had it up past 60mph.
    #38
  19. dirtydeeds
    dirtydeeds I'm alive.
    Jul 15, 2004
    2,827
    Calgary, AB, Can
    :rofl
    I'm learning. Would it be
    "Вы берете водку"
    #39
  20. eastbloc
    eastbloc comprador bourgeois
    Jun 27, 2003
    1,498
    Somerset County, NJ
    I'm surprised that guy was clumsily using his hand to shift into and out of reverse.
    It's much easier and faster to do with a boot heel.
    #40
