Ural Survey: Which steering damper do you use and why?
Discussion in 'Hacks' started by TripleDaddy, Aug 13, 2017.
Which steering damper do you use, and why?
  1. Stock friction damper. I've never seen the need to upgrade.
    16 vote(s)
    38.1%
  2. Ural hydraulic damper that came stock on my bike
    7 vote(s)
    16.7%
  3. Ural hydraulic damper that I added to my bike
    6 vote(s)
    14.3%
  4. Sean's R3W Steering Damper Kit
    13 vote(s)
    31.0%
  5. Some VW damper contraption that I made
    4 vote(s)
    9.5%
  6. Other
    1 vote(s)
    2.4%
Multiple votes are allowed.
  1. TripleDaddy
    TripleDaddy Hoping my skills exceed my horsepower
    Aug 31, 2010
    1,502
    Westfield, IN by US 32 and Shady Nook
    Hi Ural folks,
    I am posting this to help me make an educated decision on my 2013 Ural Tourist, and to hopefully help others who are considering replacing the friction based steering dampener on the older model rigs. If you've done this and can take the time to vote and give a sentence or two on why you picked what you picked, I'd really appreciate it.
    Here are the damper that I know of:
    Ural add on damper kit, ~$260
    Sean's R3W Steering Damper, ~$140:
    Thanks,
    Chuck
  2. TurTal
    TurTal Been here awhile
    Jul 30, 2015
    796
    Easy
    If you don't like spending money...keep the friction dampener
    If you're super thrifty...or just don't have a lot of it laying around....build your own....under $50.00
    If you don't mind a contraption hanging off your rig the VW dampener and brackets work just fine.....
    they've been on hacks for along time
    I've built quite a few of them and given them away...fixed rate...no adjustability...bulky and in the way
    Got money ? buy the Ural dampener....adjustable...small...out of the way...aesthetically pleasing...bolt on application
    http://advrider.com/index.php?threads/2014-steering-damper-retrofit-kit.962968/
    https://uralportland.com/accessories/ural-accessories/hydraulic-steering-damper-mounting-kit/
    Cheers!
  3. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,200
    Scottsdale, AZ
    When I had a -11 I did install the new Ural one: great an no prob! In my 15 the stock one does not leak and works as intended! I already have the ugly VW on a couple of sc and its more than enough!!
  4. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,200
    Scottsdale, AZ
    Ural one
  5. Kruzof
    Kruzof independently poor
    Apr 22, 2015
    3,563
    Alaska's drippy nose
    I installed the hydraulic retrofit on my '12 Retro.
    I liked it mostly but decided to change to heavier fluid.
    Got in trouble with reassembly--started running with no damper.
    Still running damperless with no big problem--including full loads and as much speed as possible.
  6. TripleDaddy
    Aug 31, 2010
    1,502
    Any reason that you went with the Ural version instead of the Sean's R3W version? Sean's version seems more robust, and is cheaper too. It's the one I'm most likely to pick at this stage, but I want to see how people vote, and learn more before buying one.
  7. Andrew
    Andrew Optimus Primer Super Moderator
    Sep 25, 2001
    20,491
    Eastbania
    <klay>
    Damper
    <\klay>
    DRONE likes this.
  8. TurTal
    Jul 30, 2015
    796
    #8
  9. TurTal
    Jul 30, 2015
    796
    What trouble did you run into....their easy to fix
    #9
  10. TripleDaddy
    Aug 31, 2010
    1,502
    Please make sure you vote! I made it so you should be able to pick multiple options, or change your vote in the future, if desired.
    #10
  11. Bar None
    Bar None Old School Dude
    Mar 2, 2007
    10,782
    WNC SWFL
    I left the
    Ural hydraulic dampener that came stock on my bike
    on my 2015 Ural cT but dialed it down to no resistance so I could go back to it later if I wanted to.
    Installed
    Sean's R3W Steering Dampener Kit
    It seems to work just fine but no scientific proof from me that it is better than the stock one.
    #11
  12. TripleDaddy
    Aug 31, 2010
    1,502
    If you were upgrading from a friction version, would you buy Sean's R3W, or would you spend more on the Ural version? From everything I'm reading, it seems like the performance is similar, but Sean's R3W is about half the price of the Ural version.
    #12
  13. Bar None
    Mar 2, 2007
    10,782
    WNC SWFL
    I think I would go with Sean's version. Some have had problems with the Ural one leaking although mine has never leaked.
    #13
  14. Kruzof
    Apr 22, 2015
    3,563
    IIRC, the main problem is how to screw the cap down on the cylinder without getting a hydraulic lock.
    It would be so much easier if the cylinder had a bleeder screw.
    I suppose that if there was bleeder, it wouldn't even be necessary to remove the damper to change the oil.
    #14
  15. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,200
    Scottsdale, AZ
    As I said I have a couple of VW on other sidecars and do not like them: too heavy oil in there, take too many much space and ugly as hell. I am currently looking at replace these with ones made for bikes such as rotary ones or small ones à la 916 Ducati.
    If you look for the cheapest one the "Sean" solution is the best for sure.
    Sent from my iPad using Tapatalk
    #15
  16. Strong Bad
    Strong Bad Former World's Foremost Authority
    Oct 29, 2007
    9,062
    Omicron Persei 8
    Damper, dampener
    Damper is only a noun. It refers to (1) something that deadens, restrains, or depresses, (2) an adjustable plate for controlling a draft, and (3) one that deadens vibrations.1 Damper‘s corresponding verb is dampen, which means to deaden, restrain, or depress.
    A dampener is someone or something that dampens.3 So damper and dampener can both refer to one that deadens sound vibrations.
    I never had the need to change the old school stock Ural friction damper on my 07 Tourist. My Ural NEVER showed any indication that it would have even the slightest head shake.
    #16
    moffit virtue likes this.
  17. Andrew
    Sep 25, 2001
    20,491
    Eastbania
    ^^^ Just saying, when you search for the part, it's called a Steering Damper.
    Not a Steering Dampener.
    #17
  18. TripleDaddy
    Aug 31, 2010
    1,502
    Well, I learn something every day. Thanks for pointing this out, I will change it in the OP. I tried changing it in the poll, but the software won't let me.
    #18
    Andrew likes this.
  19. cateyetech
    cateyetech Honky Cat
    Feb 4, 2014
    172
    Arkansas
    Stock friction damper for us.
    We run it with no tension and the rig tracks straight with no head shake :-)
    #19
    gobium and Strong Bad like this.
  20. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,195
    Chambers Bay, WA
    I use a dampener when I'm ironing clothes. It's just water in a spray bottle.
    :rofl
    #20
    NxtGoRnd, Strong Bad and Prmurat like this.
