USB cable to hard wire bike cable possible?
Discussion in 'Mapping & Navigation' started by Rcrx21, Oct 2, 2018.
  1. Rcrx21
    Rcrx21 06 KTM 950SM, 04 WR250F
    Dec 4, 2005
    563
    Collegeville, PA
    Is it possible to just cut off the USB plug and find a red and black wire to tie into my electrical system on the bike?
    Can it be that simple?
  2. Hill Climber
    Hill Climber Been here awhile
    Feb 11, 2007
    909
    Kaslo BC summer, Yuma AZ winter
    I think Garmin has some proprietary wiring within the cable... you will probably be able to charge the GPS but functions will be disabled. Kind of like when you plug your unit into a computer.
  3. Rcrx21
    Dec 4, 2005
    563
    Collegeville, PA
    I only want it to power the unit on the bike so I guess i will give it a try as I have more than one cable. I can also leave enough that I can put it back if I need to.
  4. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,861
    Richmond, Va
    USB cables don't typically put out 12volts. More like 5 Volts.
    I think you will let the smoke out of anything that you plug that into.
    Chaostrophy, 250senuf and kwthom like this.
  5. kwthom
    kwthom Retiree apprentice - willing to learn
    Feb 12, 2012
    5,609
    Jaynes Station, AZ
    Chaostrophy likes this.
  6. Rcrx21
    Dec 4, 2005
    563
    Collegeville, PA
    so what i need to do is take apart a power socket cable and use one of those instead because that should have the step down built in.
  7. pckopp
    pckopp Aged Adventurer
    Feb 25, 2003
    1,468
    Seattle, WA
  8. ramz
    ramz Professional Trail Rider Supporter
    Dec 11, 2006
    2,558
    Salida, CO
    #8
  9. kwthom
    Feb 12, 2012
    5,609
    Jaynes Station, AZ
    No, just wire input for the converter direct to battery.
    What @ramz is showing is just a more 'professional' version of what I did.
    #9
  10. Rcrx21
    Dec 4, 2005
    563
    Collegeville, PA
    #10
  11. Retired and lovin it
    Retired and lovin it Been here awhile
    Aug 2, 2017
    628
    Central Michigan
    $13 and an SAE cable and your good I bought this for charging my Android phone. Has on/off switch and weather proof cap just buy the fused SAE cable with battery eyelet ends and easy peasy solution.
    #11
  12. ramz
    Dec 11, 2006
    2,558
    Salida, CO
    "Has on/off switch"
    I bought the one with the on/off switch also. It turns off the power to the end of the line which includes whatever you have connected. It does NOT turn off power to the 12v-to-5v converter part of the circuit. If they had only put the switch in the right place.....
    :ricky
    #12
    wbbnm likes this.
  13. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,650
    Central Mn
    Not quite plug and play, but I have good luck with these on the past several bikes. Has worked with any of the Nuvi rigs I have owned.
    Tap into an existing fuse that's switched with the key, some zip ties, done. It steps 12 volts down to the 5 volts you need.
    $15 and free shipping from ebay
    I like some of the other ideas too and bookmarked them! :clap
    https://www.ebay.com/itm/Hardwire-USB-Car-Charger-power-cord-Kit-for-Garmin-nuvi-2505-2508-2507-200-GPS/201078181744?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    #13
  14. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    6,999
    Washington, DC
    Many say the angled USB is the way to go for best connection and to prevent damaging the gps or phone port.
    #14
