Using a potentiometer at altitude
Discussion in 'Equipment' started by Red Bull, Aug 13, 2001.
  1. Red Bull
    Red Bull Been here awhile
    Jul 28, 2001
    803
    Sonoma, CA - USA
    I was wondering if anyone else has come up with an answer to making potentiometer adjustments in the field when changing altitude? Sure, a “sniffer” is the correct way, but they just do not seem to be available when your crossing a divide! I am considering hooking-up the O2 sensor (that I removed when I out the Remus exhaust on) so the fule injector can make the adjustment… but since it does not have a Cat converter, I was not sure how to set-up the Monotronic so it could make mixture adjustments with out also compensating for the Cat converter? Anyone else figure this out? If I could get a portable “sniffer” I would make marks on how far to turn the “pot” screw (BTW is leaner to right or left?) :confused:
