Using Routes on the Nav V
Discussion in 'Mapping & Navigation' started by davepen, Jun 21, 2020.
Tags:
  1. davepen
    davepen Just put your damned city in your profile.
    Mar 23, 2019
    614
    St. Paul, Minnesota
    How do you use a saved route without it recalculating?
    For example, I have a saved route from A to B that travels along highways 1, 2 and 3. I want to pick up the route somewhere along highway 2 between those points. I don't want the route to recalculate while I am driving it.
    I'm a little surprised I've never needed to do this until now, but it appears that the Nav V doesn't support this.
    I also have the corresponding track including shaping points, but you can't get TBT directions from a track.
  2. lkraus
    lkraus Long timer
    Dec 15, 2012
    2,310
    Central Ohio
    See https://advrider.com/f/threads/basecamp-tutorial.1054359/page-19#post-40223156, and the post following it. They very briefly answer what your Nav is doing when you want to start in the middle of a route (or should I say, why you can't?), and how to work around it. Reading the linked guide will explain much more fully what your Nav V is doing. It is written for the Zumo, but the Navigator handles routes the same way.
  3. Patch
    Patch Long timer
    May 4, 2011
    3,098
    Southwestern New England
    You could turn off recalculate function. But without a waypoint to navigate to the original route, you're still recalculating to get there.
  4. davepen
    Mar 23, 2019
    614
    St. Paul, Minnesota
    That's half the solution. There is a way to pick up a route at a specific waypoint, but I need to test it.
