    Dismiss Notice
Utah BDR in May help
Discussion in 'Americas' started by Crotch Rocket, Apr 11, 2019.
  1. Crotch Rocket
    Crotch Rocket "if you get off the couch, shit happens"
    Feb 23, 2018
    235
    CA
    A few buddies and I are trying to figure out a way to do the Utah BDR without slabbing it 500 miles back to the start. We did the AZ BDR and started in the middle of it which worked well.
    We'd like to stay toward the center of the Utah BDR and/or where we can ride a few days South, head back to center home base, then go a few days North. I understand that the Northern part is the best? most scenic?
    What would be a good home base to start from if anyone is familiar with the area?
    Thanks All !
  2. Oh2RideMore
    Oh2RideMore Long timer
    Oct 26, 2007
    1,758
    St Louis MO
    Depends on what kind of riding you like. The southern bit with monument valley is stunning, and full of sand. Northern bit in mountains is full of aspens, mud, rocks, and scenic views. I prefer the north.
  3. Crotch Rocket
    Feb 23, 2018
    235
    CA
    If you had to pick a town towards the center, to start North and South loops from, that has hotels, what would it be?
  4. stormdog
    stormdog Long timer
    Feb 19, 2006
    1,817
    Almost Southern Oregon
    I started at Coalville near the north then rode in the dirt across to Wyoming down the Colorado BDR then north back to the truck on the Utah BDR.
    If that area had the same snow year we did in the west, I doubt either route will be open before the forth of July
  5. Crotch Rocket
    Feb 23, 2018
    235
    CA
    Ahh yes. Snow could be a factor in May. Using Colorado BDR for a loop. I like it!
  6. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    8,145
    Southern Illinois USA
    So are you saying you'd ride one way from the middle and slab 250 back to the start, twice? That's OK? Can't you just look at a Gazetteer or a map program and find your way back on other lesser roads? Utah has so many roads similar to what the UBDR uses that it seems easy. We did that on the MABDR and the roads we found were better than the BDR.
    If starting somewhere in the middle, I'd just look for the spot closest it home so I wouldn't have to trailer so for, Evanston if coming in on I80, Green River if coming in on I70. I've stayed at the Green River KOA they have room to leave a truck and trailer. And not far from Arches and Canyon Lands if you'd want "drive" over to check them out too.
  7. Oh2RideMore
    Oct 26, 2007
    1,758
    St Louis MO
    yes, that is usually what we do. Cobdr and utbdr big 2k mile loop. Timing is key.
