Valve job tips?
Discussion in 'Dakar champion (950/990)' started by sailah, May 4, 2006.
  1. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    IIRK, it was a 14mm nut. Either way, its one of the two sizes that come on the adapter. This was the only tool, besides a standard torque wrench and socket, that I needed to torque all of the nuts.
    -cp
    #21
  2. emelgee
    emelgee Been here awhile
    Jun 4, 2006
    870
    Sheffield, UK
    Thanks for the info. After checking the engine parts catalogue it looks like the tool for the inner nuts is just a slimmed down 13mm socket - so I guess a standard 1/4", or maybe a 3/8" socket will fit in there. The external nut is listed as an M8, which should be a 13mm head as well (following normal metric sizing conventions).
    #22
  3. Motomedic
    Motomedic Over-caffeinated Raconteur Supporter
    Oct 4, 2004
    3,710
    Spokane
    Well, in addition to my earlier post regarding lapping shims, I thought y'all would like to know that the shims used in a Harley-Davidson V-Rod are the same 10mm dia. shims used in our KTMs, as well as the Aprilia RSV v-twins.
    So, once again, lapping shims is not recommended by ANY mfg., especially when swapping them out is the easier method.
    #23
  4. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,553
    Central Ohio
    Thanks for the info!
    Dave
    #24
  5. arroyoshark
    arroyoshark Needing some space
    Oct 9, 2003
    2,134
    Fin del Sendero, NM
    I don't have the threaded tool to lock the crankshaft at the valve timing marks. I just used a socket on a breaker bar and zip-tied that to the frame to hold it in place. Seems to work just fine.
    #25
  6. buckscreek
    buckscreek AUTODIDACTIC
    Apr 10, 2007
    3,493
    Vacy
    Hi All,
    just about to get my 03 950 off to the local mechanic for a number of jobs:
    - valve job
    - carb adjustments
    - removal of some (apparently) unecessary pollution hardware
    - oil change
    Much of which I am capable of doing myself, but with three cars, 3 bikes, 3 kids and two jobs in the family I don't have a lot of time.
    The bike has only 12,000kms, most of them are mine from the past 12 months, since I bought it with 2,000km on the clock (seriously! the previous owner rode it a few times and parked it, and crept into a corner, shaking with fear..... whereupon I bought it at a more than reasonable price).
    My local mechanic is a ducati specialist and a very fine mechanic, have known him 20+ years and trust him implicitly. I have no faith in local KTM branded mechanics or dealers. Said mechanic wants to know which other bikes (brands/models) the shims interchange with? Any clues apart from those already posted?
    Thanks in advance
    #26
  7. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,113
    Turning expensive metal into scrap
    Aprilia apparantly, and also Harley V Rod. Basically it. The individual shims are $5 at the KTM dealer so unless there isn't a dealer who can get them, why woud you use anything else?:ear
    #27
  8. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    ktmtalk.com has them for about $3.50.
    #28
  9. tn-steve
    tn-steve Addicted
    Jan 2, 2007
    1,611
    Clarksville, TN
    With the three that I've done, at TDC, the locking tool would engage in the indent and lock the engine, at which point the threaded tool would protrude about 1/3". I would have to conclude that if yours was going flush with the engine that you were not at TDC, or possibly you were on the other stroke...
    #29
  10. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    On mine, the tool protrudes with rear cylinder at TDC, is flush with front cylinder at TDC, and disappears otherwise.
    #30
  11. Rock_93
    Rock_93 Been here awhile
    Apr 14, 2005
    123
    You don't have to buy a torque wrench adapter that is what the beer opener in your tool kit is really for.
    #31
  12. KTMoto
    KTMoto Adventurer
    Mar 14, 2006
    98
    South Florida, Close to United States
    What size is the bolt/threaded rod tool? Is it the same size as the bolt removed, but longer?
    #32
  13. emelgee
    Jun 4, 2006
    870
    Sheffield, UK
    After seeing MotoMedic's post mentioning that Aprilia also uses 10mm shims I've done a little searching.
    Yes, they are 10mm in diameter, and better still they come in 0.025mm intervals, rather than the 0.05mm interval that KTM offer theirs in. So you can get your clearances closer to ideal spec by fitting the aprilia items instead of KTM.
    #33
  14. cpmodem
    Nov 29, 2004
    7,130
    .025mm = .001 inch. Can't ask for much more than that. Any leads on where to get them? Other than an Aprillia dealer? Mine's the same asshat that sells BMW's and KTM's in my area.
    #34
  15. KTMoto
    KTMoto Adventurer
    Mar 14, 2006
    98
    I got this tool, and it is 12 and 14 mm. My head nuts are 13. Are the original nuts the same size as the TSB replacements?
    #35
  16. Katoum
    Katoum Adventurer
    Feb 26, 2004
    760
    British Columbia, Canada
    I have used fine emery on glass to mill down many shims and never had one show any signs of wear because they do not move to create wear. What grinding allows you to do is get to the exact outer limit for maximum mileage between valve jobs as KTM recommends. Factory shims only come in 2.5 thousandth sizes, which only allow you to get in the ball park range. So I guess its just a matter of how fussy one is.
    #36
  17. emelgee
    Jun 4, 2006
    870
    Sheffield, UK
    See my post above regarding Aprilia shims which come in 0.025mm intervals - I can't see why you'd need to get closer than that. If you keep a record of the sizes you're currently using, then make up a list of the sizes you're likely to need on the next check, and get them by mail order before you start work.
    #37
  18. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    So weres the pics and play by play????? I thought I was ready to dive into this, but know I'm scared to death. I have the bike striped (and I had fun doing it), Its the first time I have had the carbs off (cant believe the amount of oil that gets dumped down there):huh .
    I can't read to good, where's the pics. I'm a scared.
    #38
  19. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,461
    Andover, N.J.
    :1drink
    #39
  20. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    OK, I dove right in, and here is were I an at.
    Front Cylinder
    Intake Clearance .18 Right and Left
    Exhaust Clearance .28 R & L
    Rear Cylinder
    Intake Clearance .12 R & L
    Exhaust Clearance .23 R & L
    So, what do you guy think?
    The rear is on the tight side of the clearances, so I'm plan'n on move'n them to the center of the clearances.
    Say: .17 and .28
    The front is on the loose side of the clearances. I was think'n of leave'n it alone. What do you experts think????
    #40
