Valve job tips?
Discussion in 'Dakar champion (950/990)' started by sailah, May 4, 2006.
  1. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    I'd leave 'em both alone and check again in 10k. They're all in spec.
    #41
  2. Louge
    Louge silence of the limbs
    Nov 22, 2005
    1,554
    yellow house 25 miles NW of the white house
    My best friend passed away almost 3 yrs ago ... I ground the shims on his picture to the top of the spec with wet 400 grit ... he would have approved.
    Here's too ya E :photog
    #42
  3. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,553
    Central Ohio
    +1 :thumb
    #43
  4. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    How many miles on the bike? At 600 miles my exhaust valves were set in the middle of the tolerance range. 4000 miles later they were a tad tight. I believe KTM recommends setting them at the loose end. So if the bike is new I'd go ahead and loosen them up since you have the valve covers off anyway. But I'm far from an expert in these matters.
    #44
  5. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    35,000 miles. This is the first time I have done them, so I dont have a history of what they've been do'n, or were they were set to last time.
    #45
  6. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    Brilliant; I think the tool guys at KTM had a laugh when they threw that one in there, but it works.
    #46
  7. PowerCell
    PowerCell Manufacture Super Supporter Supporter
    Sep 28, 2005
    2,606
    Southern Kalifornia
    For what it's worth, I've been using the 9.48mm shims available from HotCams for a while now. The fit is fine and there are no short comings. The valve stem is 7mm and the button under the bucket is 8, so the shim is not the weakest link by any means. It doesn't float around, nor is is able to cock one way or another.
    I think I paid $68 for a two box set with 3 of every size. Sure is nice having every shim size at my disposal. I can now adjust my valves in under an hour, start to finish...
    #47
  8. Doug Matson
    Doug Matson Long timer Supporter
    Aug 25, 2003
    3,214
    Torrance, Ca.
    But where are the pic's!
    #48
  9. PowerCell
    Sep 28, 2005
    2,606
    Southern Kalifornia
    Pic's of what?
    #49
  10. Doug Matson
    Aug 25, 2003
    3,214
    Torrance, Ca.
    The valve adjustment procedure, always nice to have pictures of procedures that people do.
    #50
  11. PowerCell
    Sep 28, 2005
    2,606
    Southern Kalifornia
    I think your best pix are right there in your service manual...
    #51
  12. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,461
    Andover, N.J.
    You can say that again. In fact a "how to video" like the GS guys made would sell and make someone (Pyndon, CP, Flanny & select others) (hint hint) some $$ !
    #52
  13. Doug Matson
    Aug 25, 2003
    3,214
    Torrance, Ca.
    Ya I have one and do all mine own work on all my bikes, but it is nice to see when people come up with ways to do things easier or better. I every time I have had my bike worked (warranty or TSB's) on at the dealer I find something they didn't do or did wrong and guess what they are using as a reference! I have one of the first 950's in SoCal and have gone through all the growing pains with the dealers, I trust the people here for information and ways the address problems and plus I just like pictures!
    #53
  14. crwmac
    crwmac Been here awhile
    Dec 19, 2004
    197
    Houston, Texas
    Is this a joke, right?
    Mac
    #54
  15. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    A joke? Maybe. ...BUT, it really does work!!!!!!! It fits the nuts, and a 1/2 in. drive fits tight in the bottle opener side. I checked my head bolts with it.:freaky
    #55
  16. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    I just want to double check myself on this.
    The AH screws that hold down the camshafts get torqued to 18 Nm / 23 Nm right??
    The book is a little confusing, I would guess the bigger bolt gets the 23 Nm torque?
    Thanks. Alaskas come'n quick, and My bike is still in peices.
    #56
  17. emelgee
    emelgee Been here awhile
    Jun 4, 2006
    870
    Sheffield, UK
    #57
  18. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    #58
  19. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,793
    Logan, Utah
    #59
  20. cpmodem
    Nov 29, 2004
    7,130
    For the "record"
    Here's the page from the Manual: Like emelgee says there's a stepped proceedure to installing the bridges (covered in detail in the Manual, again) :baldy
    #60
