Valve job tips?
Discussion in 'Dakar champion (950/990)' started by sailah, May 4, 2006.
  1. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    If that includes undressing and redressing the bike then you are a freak. :D
    #61
  2. unkle_george
    unkle_george Been here awhile
    Aug 20, 2007
    107
    Portland, OR
    My dealer just quoted me 7 hours ... You should go work for them.
    #62
  3. rufus
    rufus We're burning daylight...
    Sep 26, 2004
    5,442
    Coweta Oklahoma
    Where can i get a service manual? Local dealer can't get info from KTM. (New seller )
    #63
  4. Seth S
    Seth S Will _____ for _____
    Jul 19, 2004
    5,510
    sanity?
    Just a note on the specs. The metric works out to about .004" - .007" for intake and .009" - .012" for exhaust. I find that my intake valves never need adjustment and my exhaust tend to tighten up. I have a had some degree of luck swapping shims around but I have bought a few from the dealer as well...as I have to do today. This time I am setting all of the exhaust valves on the .012" end of the spectrum....figuring they will be a bit safer on the loose side.
    As for putting the engine on TDC I don't think this is totaly necesary. I just rotate the cams until the lobes are pointing straight up then I measure the clearance and make notes. I then align the cams so they are not putting any pressure on the lifter buckets and I use a permanent marker or paint pen to mark the cam position. I remove the bridge and measure the shim thickness on the out of spec valves. I reassemble with my marks and go from there. After adjusting the valves 3 or 4 times in the last 18,000 miles I have not had a problem.
    #64
  5. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    PM me and I'll give you directions to the info you are looking for.
    #65
  6. Seth S
    Jul 19, 2004
    5,510
    sanity?
    I did some research on the hotcams shims. they cost $35 a for a box of 30 shims spanning about 2.5 mm. Here is a list I made up with the Hotcams part number and the metric and standard range they cover in shim thickness:
    a 9.48mm diam shim works out to .3732" diam vs the stock KTM shim which is 10mm in diameter. The .25mm difference per side should be fairly negligable with how the shim locates under the bucket and as posted above these should be a good alternative to the pricey KTM shims which run in the $3.50 to $5.00 per shim.
    hope this helps.
    the hotcams site is:
    http://www.hotcamsinc.com/index.cfm?fuseaction=cProducts.list&ipageno=2
    based on the shims I have swapped in my engine so far I would would order kits number 11 and 12.
    #66
  7. claferal
    claferal Been here awhile
    Aug 21, 2003
    157
    Madrid
    What happens when you need a shim under 2,30mm?
    #67
  8. Seth S
    Jul 19, 2004
    5,510
    sanity?
    are you refering to the hotcams shims or KTM? Hot cams sells them under 2.3. There may be some spec for when to replace the valve though...something I'd check with KTM. The valves stretch over time and perhaps there is a certain minimum shim thickness allowed before a valve is considered too stretched.
    #68
  9. StevenD
    StevenD Hmmmm, dirt!
    Aug 3, 2005
    1,511
    Holland, Amserdammed
    At what interval's are these shims and the original shim's available?
    I just did my valves, first adjustment now on 28000!! but only had .05 interval's to choose from! so now it's all around 0.30 exhoust and 0.15 intake. Would rather have been able to adjust to exactly .29 and .14
    What spec's do you guy's aim for?
    #69
  10. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,173
    Ventuna, CommieFornia
    I checked my valves at 8K miles and replaced 3 shims. The bike now has a bit over 20K, so it's due for another check. I'm wondering how good the clearances hold over time. Guess I'll find out when I open the bike up.
    #70
  11. crwmac
    crwmac Been here awhile
    Dec 19, 2004
    197
    Houston, Texas
    To re-torque these head nuts, do you just put the wrench on them as is with the proper torque setting, or is it necessary to loosten them slightly first, oil them, or anything?
    Mac
    #71
  12. cpmodem
    Nov 29, 2004
    7,130
    I remove them one at a time. Lube threads and washers (ARP), then torque to 25 nm. I repeat for all the nuts, working diagonally, until all are done. I then do a final torque to 38 nm. The important thing with the adapter is to keep it at a right angle (90 degrees) to the torque wrench handle. Then no conversion needs to be performed on the torque specs. Only takes about 1/2 hour, once in there doing the valve clearance checks.
    #72
  13. grom
    grom Adventurer
    Apr 12, 2007
    83
    Moscow
    I’ve just adjusted valves (actually they were almost OK after 25000km).
    I would like to add here a trick that I found for myself, and it was confirmed by two of my friends (mechanics), but I’ve never read about that in manuals.
    So, after you have changed/sanded shims and re-torqued cam bridge, rotate engine a couple of turns. This will give you much more correct clearence numbers.
    #73
  14. Meathead
    Meathead tin man
    Jun 10, 2004
    16,667
    Upstate SC
    AAAAAAAAAGGGGGHHH!!! :baldy :baldy :baldy
    I took a picture of the cam positions before removal rather than marking them, primarily because I didn't have a reliable way of marking them, but also because there's no reason referring to the picture wouldn't guarantee getting them back in the same position.
    Long story . . . pic got blitzed. :pep
    Is there a way to guarantee the cams are back in the correct position? :scratch I've got them where the lobes are oriented exactly 180<SUP>o</SUP> from each other, pointed "out," per the manual pages posted here, but I'm not quite positive that's where they were.
    Anyone? :ear
    #74
  15. cpmodem
    Nov 29, 2004
    7,130
    Just make sure you are at top dead center on the compression stroke for the cylinder you are doing, then check that the marks on the cams line up as it says in the manual. If you need the manual, PM me and I'll let you borrow mine to get your bike running.
    #75
  16. Meathead
    Meathead tin man
    Jun 10, 2004
    16,667
    Upstate SC
    As shown in the 2nd illustration here? :ear
    I had it at TDC on compression for disassembly. If I locate the cams that way, both lobes are pointed well down. :scratch Can that be right?
    #76
  17. Meathead
    Meathead tin man
    Jun 10, 2004
    16,667
    Upstate SC
    Crisis averted! :knary
    All hail the Doctor of Orange! :freaky :clap :super :beer
    #77
  18. Wayne Weber
    Wayne Weber why are we stopping?
    Aug 29, 2003
    3,855
    Golden CO
    The FRONT cams have a circle on the gear (really, a dot) and with the dot aligned with the valve cover gasket surface, the cams will point out at TDC, ref: page 6-20 of the shop manual
    The REAR cams have a cross mark to align with the surface, and will point IN at TDC. Make sure you set each cylinder at TDC before setting each cam. The rear cams won't point exactly to the center, they'll point up a little. The cross is the important mark. ref page 6-16 of the manual.
    Note that the marks don't exactly perfectly align with the flat surface, they will be just above if I remember.
    Does that help? let me know!
    #78
  19. Seth S
    Jul 19, 2004
    5,510
    sanity?
    You need to get a copy of the manual. You will be safest by just setting each cylinder at top dead center and putting the cams back in. I think there is another set of marks you can go by to line up the cylinder. I always just mark the cams and am super careful about it.
    #79
  20. neduro
    neduro Addict
    Jul 8, 2003
    12,296
    Colorado Springs, CO
    Just bolt 'em back in wherever, you can use the bolts on the cam caps to cinch the cams down if the lobes are contacting the lifters. Start it up and if you hear noises, try moving them a tooth.
    :deal
    :zilla
    #80
