Valve job tips?
Discussion in 'Dakar champion (950/990)' started by sailah, May 4, 2006.
  1. BLUE(UK)
    BLUE(UK) Long timer
    Dec 2, 2004
    3,442
    Cheers,have just looked to try and get one in UK,if not i may order one from US.
  2. ZenMoto
    ZenMoto Bikeslut
    Jun 30, 2005
    687
    Moorpark, CA.
    Just a few notes from my first (still in progress) self done valve adjustment.
    I've decided that from now going forward, any time my valves need adjustment I will also plan to perform a full coolant flush. It's so much easier to work on the bike with the radiator removed that it's a no brainer to do this. ...in fact, it's really easy to work on the bike with the radiator out of the way!!!
    I had 6 of my 8 valves out of spec at 20k. I have no idea where they were at at the last adjustment since I didn't do them, so I can't say how much they've moved, but as I will be doing them myself from now on so I can report back at the next interval. :) Both my rear exhaust valves were VERY tight, the left reading 0.076mm the right at 0.06mm. The intake on the rear were both the same, right on the tight side of in spec at 0.10mm.
    The front were all close, but just out; the actual numbers escape me at the moment though. I was able to get all but one shim I needed from a local HD dealership and the one they didn't have just happened to be one of the shim sizes I'm pulling from the rear exhaust! ...I love it when things work out ok!
    The "X" mark on the rear exhaust cam is very hard to see as the cam bridge gets in the way of a clear line of sight (though it is visible, just barely, by looking past the shock at an angle ...good light help a lot). This is only an issue for disassembly though, as obviously, when putting it back together the bridge is out of the way when placing the cam.
    I made sure, when putting the cams back into postion to look at them 1 tooth "out" in each direction to get a visual idea of how far out they were if done wrong and was glad to note that it is very obvious when they are in the wrong spot! :thumb Also, using a small LED flex-light you can see the groove where the engine locking bolt nests, so I made sure to get that groove exactly centered in the hole to make sure there was no chance of the engine turning while I worked on it.
    Another tip is turnign the engine using a breaker, vs. a socket wrench as it won't spin on you ...I have to do this with my XR since TDC falls at a spot where the compression will kick the engine past the mark. With a breaker you control exactly where the crank sits!
    With the bike torn this far apart (forks on their way to Precision Concepts in Riverside) it only made sense to replace the water pump shaft and bearings, a project for this coming weekend.
    I also took the opportunity to adjust the fork stops a little farther out for a better turning radius, making sure there was no contact elsewhere. Another thing to do was clean up the header pipe which has had red Baja clay caked to it for most of a year. It's now shiny clean and steel wooled.
    I don't know about others on here, but when I'm deep into the bike, I like to clean/lube/loctite/torque everything I can get my hands on! :D
    Thanks to all the tips on here (and other threads) I've found that working on the KTM, even in a cramped little corner like the one I have availalbe to me, is worth the effort. It's entirely likely that this will be the first time since the bike was new, that it has been adjusted, lubed and set up properly. ...I can't wait to ride!!!
  3. paochow
    paochow Bye bye desert
    Aug 19, 2005
    1,177
    MinneSota
    No worries... 990 valve adjustment
  4. tardypizza
    tardypizza n00b-like in consistency
    Jul 31, 2005
    110
    austin, texas
  5. Steverino
    Steverino Arrogant Horse's Ass #1
    Nov 16, 2001
    36,679
    Will somebody hold my hand, I'm scared.
    Rear valve cover off getting ready to find TDC and remove the bridge. :yikes
  6. Lost Again
    Lost Again Fresher Meat
    Jun 29, 2007
    274
    Orange,CA
    Just as a FYI, I found that the 14mm allen cap that you need to remove from the left side of the bike so that you can manually turn the engine,is kind of tight and might fool you into thinking it's a 13mm, which it's not. The cap is plastic and on my bike (2004 950 Adventure) I had to tap the allen into the hole with a rubber mallet. It was a tight fit.
  7. BLUE(UK)
    BLUE(UK) Long timer
    Dec 2, 2004
    3,442
    Good call....i tried for ages trying to buy a 13mm....D'oh!!:huh
  8. Steverino
    Nov 16, 2001
    36,679
    Ordered my kit last night. Thanks for the tip! :thumb
  9. Maineroads
    Maineroads Ridgerunner
    Jun 8, 2007
    842
    Peak of the Valley, Maine
    What kit are you guys ordering? Shim size varies by kit.
  10. Miguel
    Miguel off road junkie
    Jul 25, 2004
    590
    Vancouver Island, BC
    It's the "Hot Cams" shim kit from Dennis Kirk. It's part number 14-8752. There are two part numbered kits in 9.48mm. Just make sure to get the # above. I think the catalog will list it fitting the RC-51, ZX-10 etc.
    It's $85.99 :deal
  11. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
  12. Maineroads
    Jun 8, 2007
    842
    Thanks, ordered one.
  13. twistedmind
    twistedmind wrenching mostly
    Jul 21, 2002
    395
    Shenandoah Valley
    Isn't there a Honda that takes the same size shim? I've got a local dealer for that brand and it sure would make life easier. Anyone heard of this or know which model it is?
  14. cpmodem
    Nov 29, 2004
    7,130
    If you're talking about 10mm shims, I don't know of a Honda that uses them (doesn't mean there isn't one), butt I do know Aprillia, Harley Davidson V-Rod, and some Rotax powered machines use them.
  15. mynameis
    mynameis Been here awhile
    May 22, 2006
    239
    Somerset.United Kingdom.
    cpmodem - are you using the 9.48mm hotcam shims?They are the same size as the DRZ400S shims,which is what i originally bought the hotcams shims for.
    If it is ok to use the 9.48mm shims then it makes the valve check job so much easier,no waiting for dealers to get shims in stock.
  16. Mike955i
    Mike955i Future Escapee
    Jun 24, 2005
    1,109
    Phoenix, AZ
    Not CP, but I used the HotCams shims during my recent valve change and they fit perfectly. Side by side, the difference is minor and I can't see how there could be an issue. As always, YMMV! Good luck.....Mike
  17. cpmodem
    Nov 29, 2004
    7,130
    I haven't used the 9.48mm Hot Cam shims yet. My kit from Troy Honda just arrived today. Good price and quick service. I've always used the 10mm before, but will give these a try next adjustment. They also fit several of my other bikes, so should prove to be a good investment in the long run.
  18. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    Sheesh, CP. We were waiting with bated breath for you to hold forth on the theory of why shims .52 mm smaller than spec'd are or are not bad for your engine. I'm frankly disappointed. :rofl
  19. mynameis
    May 22, 2006
    239
    Good enough for me.cheers.:thumb
  20. neduro
    neduro Addict
    Jul 8, 2003
    12,296
    Colorado Springs, CO
    Believe (but please double check) that CRF450 shims can be used.
