Valve job tips?
Discussion in 'Dakar champion (950/990)' started by sailah, May 4, 2006.
  1. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    Doh! My bad. It says right in the Troy Honda add that these shims fit the TRX and CRF 450's.:komet
    Also: KFX400, KLX400, DRZ400, LTZ400, RMZ450, WR/YZ400/426/450, YFZ450
  2. positionsize
    positionsize Been here awhile
    Jan 16, 2007
    103
    Arizona, Florida and Philippines
    Greetings Everyone,
    I am checking the Valves on my new to me 2006 950A and have a few questions.
    When rotating the engine to TDC anti-clockwise via the Allen Head inside generator cover I hear a light clicking noise every full rotation of the engine. The sound is coming from the cam chain area of the front left cylinder. My SWA guess is its something to do with the cam chain tensioner. It sounds similar the clack of the auto-decomp on my 640 but much quieter. I don't think its a problem and I did not change anything on the motor but I would like some input. Does anyone know what it is??
    My second question:
    Is the re torque of the heads necessary on the later model 950's. I realize its wont hurt anything to re torque. But it is not mentioned in the maintenance schedule. My bike already has the new nuts from the factory So.........is it really necessary? Or just a carryover precaution from the earlier models service bulletin on gasket failures?
    Thx
  3. elljoh
    elljoh Gumby
    Apr 21, 2008
    18
    Melbourne, Australia.
    had the same question in this thread:
    http://www.advrider.com/forums/showthread.php?t=417180
    my '04 950a had 25K km's at the time so i was concerned about the cam chain... like my sound, yours is probably due to oil draining from the tensioner.
    /elljoh
  4. fmfpunk
    fmfpunk Hooligan in training
    Jun 3, 2006
    1,204
    La Verne, CA
    For those in the know: one of my exhaust valves is .001" out of spec on the loose side. Does valve lash tend to get greater or lessen w/ time?
    thx.
  5. Flying Naartjie
    Flying Naartjie One day Adventurer
    May 8, 2007
    97
    Cape Town, South Africa
    Just did my 07' 950SE, Intakes were tight down to zero (couldn't even get a 0.05 feeler in there), Exhaust were loose to just past the end of the range. I have heard that the Intakes tend to tighten up as the valves sink into their seats and the exhausts tend to loosen up as carbon residue builds up between the valve neck and the seat, but it seems not everyone has had that experience although that does look to be the case on my motor (now done 15000Km).
  6. ADVJake
    ADVJake ***** dweller
    Aug 16, 2004
    4,341
    Sydney, Australia
    not a good sign mate. i suspect your motor has been dusted to have the valves close up that early.
  7. positionsize
    Jan 16, 2007
    103
    Thanks For the link Mate!
    Exactly what I was looking for :thumb
  8. robbie c
    robbie c trail addict
    Apr 24, 2007
    678
    Hereford
    I've just checked the clearances on my 950SE with 10000 miles on the clock.
    Exhausts on the rear were 0.3mm on the front they were 0.35mm which appears to be outside spec and must have been set that way.
    inlets were 0.08, 0.10, 0.10 and 0.13, I took 0.05 off the 3 on the lower limit.
    This job was easier than I thought it would be.
    The two tips that I liked were looking in through the hole in the pump casing with a torch, this worked really well, the other was to get a long 8mm bolt and grind a point on to it.
    When you look in with the torch you can see the gap you need, if it's the rear cylinder then any long bolt would do as it goes straight through the crank but when at tdc on the front cylinder the bolt has to locate in a blind hole and so needs the point.
    I took my time and enjoyed it.
    Water pump next.
    Cheers
    Rob
  9. Bonova
    Bonova Adventurer
    Mar 23, 2012
    17
    South Africa
    Hey Guys. I know this is an old quote... but i need some advise please!
    Advise on H.O.W and here suggests the final torque for the head nuts is 38nm. But my manual says 46 Nm? is there a reason that most people are torqueing to 38 instead?
    thanks!
  10. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
    2004 Manual says 46Nm
    2011 Manual says 38Nm on interior nuts and 34Nm on exterior nuts.
    /Johan
  11. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,045
    East Med, Greece
    Hi there,
    I just did the valves and had the bridge bolts torqued at 10Nm and then the M8 bolts to 18Nm. However one bolt got stripped by the Alen bit and all of them seemed at their limit. Is there any lesser torque values announced on younger models, that do not endanger the bolts' heads, or is it my clampsiness only to blame?
    Cheers.
  12. rattis
    rattis Long timer
    Apr 3, 2010
    3,996
    East of the seas of Kattegat
    Yeah I found the allen heads to be on the soft side, new bolts next time.
  13. Katoom72
    Katoom72 Been here awhile
    Jun 3, 2012
    952
    Belgium
    Yup, soft as butter. Better to replace them every valve job.
    I stripped one of the allen bolts and had to play handyman with a EZ-out and a magnet to avoid metal chips in my valvetrain.
    Went out and bought 8 new ones, they torqued down without a sign of giving out.
