Vario case issue
Discussion in 'Parallel Universe' started by TwotterPilot, Feb 8, 2020.
  1. TwotterPilot
    TwotterPilot Adventurer
    Dec 15, 2018
    60
    Bend, Oregon
    Is anyone running the Vario top case with a different set of panniers? I was planning on doing this but after taking my panniers and racks off my bike to ship to their new home I found out can’t do just that. Is there some sort of adapter to be able to do this? I want to keep my top case along with my new set of panniers. Thanks for the help
  2. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,354
    Maryland
    Well, I am running the vario top case with the adventure pannier racks that hold Wolfmans expedition luggage. No issues.
    Can you be more specific?
    TwotterPilot likes this.
  3. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    I have the complete set of Vario cases on my bike right now but the Vario top case requires the Vario pannier racks to work. I purchased Happy Trails panniers and racks but haven’t received them yet. I didn’t ask HT if their racks will work with my Vario top case. So I’ll ask next week but After looking at the top case base plate it looks like it may work if I had some spacers or something for the baseplate. So pretty much just wondering if I can run my Vario top case with happy trailers racks and panniers.
  4. Dorito
    Jul 31, 2010
    7,354
    Maryland
    This is not true. You can install only the top case without any side panniers.
    Have you looked at the maxbmw.com parts fische to see how it is suppose to install?
  5. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    Never looked at that sight. Thank you! So it looks like I need the rear handle or call up HT and see if their racks will support the top case. The way it is right now, if I remove my Vario side racks then the top case will not work because part of the side racks is what the top case base plate attaches to. Sorry to be so confusing.
  6. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,876
    South Jersey... Close to the Pines
    What year bike are you dealing with? The 800 or 850... They are different.
  7. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    It’s a 2010 F800GS
  8. SnoDrtRider
    Mar 21, 2006
    6,876
    The vario top cases use their own separate (from the sides cases) mounting "plate" that does not attach to the vario side case mounts. If you have the mounting plate it attaches to the flat area behind the seat and does not attach to the side case racks so you can use any side racks you like.
    #8
  9. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    That’s what I thought as well. I tried that and it would need spacers for the front bolts in the picture you posted. Now I’m thoroughly confused. I’ll try to get a picture...
    #9
  10. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    #10
  11. SnoDrtRider
    Mar 21, 2006
    6,876
    I may be wrong but I would assume two things...
    1/ The top case mounting plate from BMW comes with spacers but they do not get used when installing the vario case racks and get binned at the dealer or factory when they install the full system because not everyone gets the full system.
    2/ Aftermarket rack manufacturers use the same mounting points as the factory and therefore they would serve as spacers for the plate.
    #11
  12. SnoDrtRider
    Mar 21, 2006
    6,876
    If you look at the HT web site you can see the racks mount to the same points as the Vario racks and have the spacers welded to them...
    #12
  13. TwotterPilot
    Dec 15, 2018
    60
    Bend, Oregon
    Great thanks for the help. I’m still learning all this.
    #13
  14. Morro
    Morro like a ship in the night
    Nov 7, 2008
    506
    Coastal NSW
    #14
  15. Morro
    Nov 7, 2008
    506
    Coastal NSW
    #15
