Vegan Diet for a 90' BMW K75S
Discussion in 'Some Assembly Required' started by Jessper, Oct 1, 2018.
  1. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    Why a Vegan Diet? I'm stripping down the k75 and the direction of the bike will be a somewhat trendy street scrambler-ish K75.
    I picked the bike up on the other side of Atlanta for a seemingly great deal. The seller was a nice guy going through some crap and his bike had been sitting in his buddy's garage for years without being ridden. He gladly accepted my cash offer and after a quick chat and loading it into the truck it was mine!
    The day it came home:
    I have since learned the bike was originally blue. Somewhere along the line it was painted white. Probably the cheapest single stage white one could find because it started flaking off long ago
    The tear down continues:
    That's a pretty heavy exhaust....not like a cx500 crossover though...
    If you have followed the k100/k75 custom movement at all you know that the original sub frame does not make a tasteful modification easy. Some people have gotten away with hiding the sub frame. i decided quickly i would cut it off and start fresh.
    My buddy helping me clear the area for cutting
    and.......its gone
    The k75 has an aluminum tank, which means they look great stripped of their paint and brushed
    The stripping process is always a PITA no matter your technique.
    And now we are caught up. Lots and Lots more to do but for a couple weeks worth of work it is really starting to shape up.
  2. Foxed101
    Foxed101 Monkeywrench
    Aug 1, 2015
    441
    Holland
    That’s not a snip, that’s a proper chop!:war
    Keep up the good work!:thumb
    AK650, scot_douglas and Jessper like this.
  3. r60man
    r60man Long timer
    Mar 14, 2013
    1,567
    Robesonia PA
    How is the rear shock going to be mounted? Looks good so far.
    Jessper likes this.
  4. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    As r60man asked...I was also wondering how the shock was going to be mounted. I think I got that figured out Today.
    Here's the inside bent to the correct angle
    And then both bent and welded up.
    Further support may be necessary. I'll have to see if it flexes with some force on it.
    scot_douglas likes this.
  5. r60man
    r60man Long timer
    Mar 14, 2013
    1,567
    Robesonia PA
    I was thinking the same. I could see a gusset above the mount before the bend. Then one from the gusset to the frame in front of the mount to sturdy up front/rear forces.
    JimVonBaden likes this.
  6. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,368
    NorCal
    Gusset that shit... that has break written all over it.
    I'd probably box it, the esthetic is nice though.
    Since we got you here.... where exactly is planet Vego? And why can't y'all eat food?
  7. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    1,741
    Adelaide,South Oz
  8. scot_douglas
    scot_douglas Dirt Harley Lovin' Supporter
    Nov 22, 2008
    1,286
    Howell, MI
    Boy Howdy.
    You need to take the back plate off the subframe and then make plates that slide over the tubes and extend to the shock mount. This still won't address the twist it's going to put on your subframe, but it'll keep the shock from breaking your leg if you hit a pothole.
    I've attached some lovely crayon-fab. :D
    #8
    r60man likes this.
  9. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    #9
  10. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    #10
  11. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,074
    Your imagination.
    Seems that a few have got on your ass. The upper shock mount will be fine.
    You may want to review your sub-frame geometry and its attendant mounting, though.
    Outta curiosity, now that you've sliced off the VIN # how are you going to address that issue?
    #11
  12. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    And off with the Speedo/ tach monstrosity
    The piece of the old sub frame with the vin on it will be recycled into the new sub frame somewhere.
    Disclaimer: this is not a rolling riding project. I'm not commuting on this thing with tabs and mounts loose and merely tacked. I'm well aware it isn't road ready at the moment.....I did pick "some assembly required" right?
    #12
  13. JimVonBaden
    Feb 11, 2005
    81,026
    Alexandria, VA
    I think you have it right now! :deal
    #13
  14. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,074
    Your imagination.
    Cheers.
    #14
  15. Samtech79
    Feb 27, 2014
    1,368
    NorCal
    Some assembly required indeed.
    One question; not about planet Vego. Why welded and bolted subframe?
    #15
  16. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    Haha I'm not a vegan, I'm making fun of myself for being trendy doing a somewhat cliche build. Trendy like a millennial vegan? Sorry my humor didn't transfer.
    With the mounts welded to the frame and the sub frame bolted to the mounts, the sub frame is completely removable. This will make routing electrics easier. It's also nice welding and painting off the bike so overspray and sparks aren't finding their way to everything else on the bike.
    #16
  17. Samtech79
    Feb 27, 2014
    1,368
    NorCal
    No no, it is. I also enjoy poking some fun at the picky little neck beards and their "cafe racers". So far I haven't seen one come back before their gluten free double frufru fluffy mocha latte with oak meal scrub was served up which makes me question the "racer" aspect some but it's all good. Most dont even understand the game or think I'm a mad man for burning ass to the corner of 6th and nowhere and back before my steak arrives but hey, we all can't be motorcycle demigods... Just me... but they still look cooler with their greased up beards with little cruelty free beads hiding up in there. Chic's seem to prefer that over my metal leg so I guess they win without even starting their bikes.
    It looks like the top is welded and the bottom mounts are bolted. Is the top bolted too? Just hard to see?
    #17
    Jessper and JimVonBaden like this.
  18. Bigeyedfish
    Bigeyedfish Adventurer
    Aug 19, 2018
    10
    Missouri
    Top mount is shown about halfway through the first post. I think I would add some redundancy to that mount. Those bolts are pretty small. Not sure I'd be able to trust it as is.
    #18
    FR700 and Jessper like this.
  19. Bt10
    Bt10 Been here awhile
    Dec 18, 2012
    397
    Saranac,MI
    You could probably swiss cheese that cross brace, but consider adding a strut that comes from the bottom of the bike similar to the pic of the other bike. 859327971_mhzkc-xl.jpg
    Would stop the twisting moment others were describing.
    #19
    Dino de Laurentiis and Jessper like this.
  20. Jessper
    Jessper Adventurer
    Mar 15, 2012
    52
    Northeastern GA
    I think I figured out the exhaust today, and the final seat mounts.
    Figured out why my front master was leaking....threads are stripped where the banjo bolt threads in. Someone must have went a bit hulk in the past.
    #20
