Vern Worldbeater Panniers
Discussion in 'GS Boxers' started by tsiklonaut, Jun 26, 2008.
  1. Global Rider
    Global Rider Alps Adventurer
    Nov 26, 2001
    3,927
    Canada & the Alps - N 46° 31.714' E 010° 27.212'
    Certainly not 6061 and 7075 series in T6. I've worked with those. Of course your bend radii is based on the thickness and type of aluminium.
    Well you might use what is commercially available, but what GiVi had for the R1150 GS Adventure didn't catch my eye, so I made my own.
    I thought about using 6061 aluminium, but then I'd have to either powder coat it or clear anodize it, so I went with stainless steel (downside: weight) and glass beaded it to give it a finish near to the paint on my GS.
    Here is my BMW R1150 GS Adventure GiVi Custom Topcase Mount...
    Yes, the GiVi could have been mounted further forward if I removed the grab rail, but I wanted to maintain it for the times I move the GS about while parking it.
    More of my stuff for the R1150 GS Adventure...nothing that is rocket science, but if if someone can use the ideas, why reinvent the wheel.
    #41
  2. Global Rider
    Nov 26, 2001
    3,927
    Those are the type of mounts Grant Johnson (Horizons Unlimited) and others have made up for their motorcycles. Quite robust! One has to look at two aspects of durability: 1) general everyday use while on tour on rough terrain and 2) crashworthiness. While they may never fail while in use rubber side down, will they take a serious crash down a 10 foot ravine and if so, can they be easily fixed?
    Now for most of us, our luggage sees no more than cross country tours and some off roading...which is never an issue for the gear.
    #42
  3. MsLizVt
    MsLizVt pfft ...
    Jun 2, 2007
    1,642
    Killington, Vermont
    Alex,
    That Givi mount is beautiful! Who cares how far back it is really. Yes weight distribution is talked about a lot, but when everything is loaded up how much difference does an inch or two make, you know.
    I agree with you about the robustness of the Overland Solution racks. If we all were going to do a tour through the wilds of Africa or the Jungles of Southeast Asia, perhaps strongest is best.
    Thank you for sharing your information.
    Enjoy,
    Liz
    #43
  4. tsiklonaut
    tsiklonaut the (in)famous boxer perv
    Nov 21, 2004
    1,662
    semi-homeless
    Hi Liz and et al.,
    More or less everything is a compromise.
    IMO a very probable cons about Overland Solutions panniers are:
    • the weight those frame look very massive, a bit of an overkill to me(?)
    • overkill width of the frames alone - making it exposed to damages and additional weight when you want to ride offroad
    • not safe to ride offroad with those frames on - I can already see how the frames cut deep into my leg when I fall and my leg get's stuck under the bike
    I love to take off the boxes and do some more serious offroad or sand riding, even when I'm travelling.
    As told before - although Verns aren't Quick-Disconnect (which I personally don't like mainly because of the security and long term-reliability reasons) type of panniers they still come off relatively easy and what I really like is that frames are slim very close to the bike - you don't need to remove the frames to make the bike for more serious offroad spec for that decent sceneric trail ride:
    Although I did tested riding with Verns half-filled (the noise is the stuff hitting the walls inside the panniers), so the bike was like more than 250+kg, still was surprisingly managable if you take it a bit easier:
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/MZ8UHaCFbec&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/MZ8UHaCFbec&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    But still, for more serious offroad riding I rather remove the boxes and use the full potential of the bike in the lightest and the thinnest form.
    Just my 2c.
    #44
  5. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,723
    Beautiful Revelstoke BC
    They sure look nice.... did the signal light stalks have to be shortened? Looks like it in pic#4
    #45
  6. Boottrac
    Boottrac Been here awhile
    Aug 27, 2003
    483
    Easton, CT
    Just by looking at the bends they where done profesionaly at a sheet metal shop with an accurate pressbrake set up. Minimum inside bend radius for 316SS would be .5T (Thickness), so if he is using .09 material you would have a .045 Inside bend radius for standard die wipe, and a press break is nuetral or 50% stress loading in the bend.
    If you do not see any cracking or Orange Peel or cold spot from stretching the material is as strong as if it was flat.
    A good observation but lack of knowledge.
    #46
  7. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    Yes. And that is, in fact, a problem. Maybe not if you're riding in the jungle. But in traffic it is (IMHO).
    The problem is that even from a relative modest angle, the indicators are invisible.
    That is, if you are in the left lane and have a car behind you in the right lane, he will not (be able to) see your indicator as you are bliking to the right. I don't like that.
    As we speak I am adding two yellow LEDs to the lid of my panniers to rectify this situation.
    Yes, I will upload some pictures as soon as I am done.
    [TaSK]
    #47
  8. tsiklonaut
    Nov 21, 2004
    1,662
    semi-homeless
    Yes, you're correct, turn signals are shortened (the conversion kit comes with the panniers) since those panniers stick very close to the bike keeping the mass of the panniers more centralized (i.e. compare it to those panniers that, in comparison, are IMO waste of (width-) space and also more load stress to the frames when the panniers stick too far out).
    Never had any problems with those slightly shortened turn signals. Maybe because I'm too polite rider in the traffic and always give signs on the right time not to confuse other people? :lol3
    Ride safe!
    #48
  9. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    The problem isn't that they are shorter, but rather that the panniers are "too" long. The indicators are only visible from straight behind, not even from a modest angle.
    But don't get me wrong: I love mine. With the LEDs installed I'll love them even more. If at all possible :lol3
    [TaSK]
    #49
  10. Clay Spinner
    Clay Spinner Been here awhile
    Nov 6, 2008
    770
    Nova Scotia
    I should be getting my verns in a few weeks and like the idea of your mod.
    Would be really interested in seeing the results and maybe a list of things/ description of what one may require and do in order to do something similar.
    :ear
    #50
  11. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    A teaser:
    If you look carefully, you'll see the four LEDs installed in each lid. I'm done with the internal install.
    Now I need to get power from the bike. To yellow LEDs on each lid close to the bike and two red ones further out.
    Yes, I know it makes my GS look like a GoldWing :rofl
    Picture taken in Trento, Sud Tyrol (Alto Adige), on Saturday. It was -10 C (14F) when we left Bolzano an hour earlier.
    [TaSK]
    #51
  12. Dirtmoover
    Dirtmoover Just a big boy
    Nov 24, 2007
    90
    Dalby, Denmark
    Hello.
    Instead of reducing them, you could consider just to move them!
    I did that when I bought the rack and cases so I could get 1200ADV bags on my 1150 ...... but on my bike they are a little wide when there are no bags on it ....... but again it does nothing when the bags always are mounted on the bike as they will be on yours ? .........
    Safety before beauty :evil
    #52
  13. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    Hei til deg i Skandinavia :wave
    Absolutely.
    The panniers came with a "shortener" and I installed it. Moving them might have been a nice alternative.
    If my LED-approach fail for some reason I'll look into it.
    [TaSk]
    #53
  14. Dirtmoover
    Nov 24, 2007
    90
    Dalby, Denmark
    Tak for hilsenen fra Toscana :D
    Grazie per aver scelto di saluto dalla Toscana :D
    Does the Italien line make any sense ?
    #54
  15. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    It depends on what you wanted to say :rofl
    I didn't like the idea of making holes in the lids, but after some weeks of riding, there has been no leak what so ever. So I'm ready to start on the bike side of things.
    [TaSK]
    #55
  16. TarmacTraveller
    TarmacTraveller FastFossil
    Jan 11, 2008
    13
    Sydney Australia
    This is only the second time that I've posted anything on this site so please forgive me if I've put it in the wrong place.
    I'd just like to give Vern and his Worldbeater's a wrap.
    I scoured the internet and in particular this site and the ADV site looking for what I thought would be the best panniers to suit my 1100gs.
    I looked at several options some of them dearer and some cheaper. Fortunately a good mate of mine had ordered a set of Verns so I was able to see first hand the quality and workmanship in these fine boxes while I was still doing the reasearch.
    I will admit that there was a particular company down here in Australia that seemed to manufacture a fairly good product so I contacted them and they did come back to with information, the second time I contacted them ( via e-mail) I got no reply and to this day still don't have return corespondance from them.
    Talking with my mate who had purchased Vern's for his adventurer he said why don't we see if these will fit your bike... we did... and they didn't, the problem was that the Staintune aftermarket exhaust was some what longer than the standard pipe.
    So an email to Vern and we discussed the options I had, and while Vern suggested that I have the Staintune cut down in length it wasn't something that I was happy with . Another e-mail and I explained that I was pretty handy with a tape measure and could do drawings that said it was off the mates place once again, whip off the pannier frame from the exhaust side on his bike, hold the pannier in place make a couple of marks with a pencil and then produced a drawing , took a couple of photographs and another e-mail to Vern.
    I was pressed for time and explained that I was off to Tasmanian for a couple of weeks with four other mates and wondered if I'd get the boxes in time, that said I rang Vern and it didn't seem to be a problem.... and it wasn't.
    The boxes arrived the week before I was due to head off. An hour and half on a Friday night and we had them fitted.
    Now the real wrap here is that not only did I get the boxes in time it's the fact that Vern put himself out to make sure everything happened , he even had to do a round trip of 200 mile, in the snow, to get some extra plate for the construction.
    The other wrap is that I recieved a quality product , the welds are something to be seen, the hinges a work of art , the clasp are gutsy, and how on earth he gets into the folds inside the lids to bolt every together is beyond me !
    The stainless steel mounting brackets are something else again and another work of art. While I'm talking works of art... you should see how these boxes are packed for transport, it must take him as long to pack them as it does to make them. Delivery time from the UK to Australia.... 4 days and you can track them.
    Two weeks, 4600k's in which we had rain, covered some dirt roads that should have been classified as a nuclear dust zone and I can attest that the boxes didn't let in not one drop of water nor any dust that I assure you was finer than talcompowder.
    I can't recommend these boxes and the man that manufactures them highly enough. If your looking for panniers that are not only big enough to take everything you need and a product that will pobably last as long as your GS these have to be what you need.
    Drop him a line, give him a call, nothing seems to much trouble.
    And when you consider I'm still waiting for a return mail from another supplier.....
    A huge thanks Vern, thanks for all your efforts mate.
    Paul.
    <!-- / message -->
    #56
  17. Some-Young-Guy
    Some-Young-Guy Been here awhile
    Aug 4, 2007
    377
    I really like hearing stories like yours. It's always a pleasure dealing with good people and good businesses.
    Do you have any pictures that you can post?
    Thanks, SYG
    #57
  18. wolvertone
    wolvertone Save a mile-Kill a metre!
    Dec 3, 2007
    171
    Denham Springs, LA
    Just had to chime in. It seems most people only make an effort to bash a bad transaction.
    Rearely does someone take the time to say good things about a company. Sounds like from his efforts he deserved a positive write up, which you've clearly given him.
    Good on ya...
    Steve
    #58
  19. Kit_McConnico
    Kit_McConnico Regular Adventurer
    Jul 9, 2008
    308
    in the garage adjusting my valves
    +1 on the pics request. I really like the look of the world beaters and from everything I've read they're bulletproof. If you don't mind my asking what might one expect to pay for such a fine piece of kit?
    #59
  20. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,854
    Keepin' the love going in the existing Vern thread.. merged :thumb
    #60
