Versys 300x adventure build
Discussion in 'Japanese polycylindered adventure bikes' started by michaelkozera, Dec 27, 2017.
  1. 79thunder
    79thunder Been here awhile
    Sep 16, 2017
    273
    Out West
    Thanks Samtech,
    I'll look into the Cerakote, the finish looks good to me. I don't think I've ever heard of it and don't know if I can get it locally.
    As long as the smell goes away once cured, that won't bother me.
    That reminds me of a friend I have who refinishes furniture, that when referring to urethane and water based finishes he feels that
    "If it doesn't stink, I don't trust it !!"
    So, I'm guessing that if it really stinks that bad, It must be good stuff!
  2. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,402
    NorCal
    It's mail order. A little goes a long, long way too. You don't cut it with anything and you just pour it in and shoot it.
    Thing is, you have to blast it first, keep it completely oil free (finger prints) and shoot it all in one coat. It's wicked thin and the coating thickness is very low. If you over do it it looks like shit and your back to blasting.
    79thunder likes this.
  3. 79thunder
    Sep 16, 2017
    273
    Out West
    Gotchya, Thanks!
  4. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,437
    calgary
    you can buy it in 10ft-25ft rolls. something like 20$ on ebay
    yes , tig. with stainless steel filler.
  5. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,070
    KC
    Do you use 312? Or straight SS 308 or 316?
  6. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    Can't speak for Mikey but I used 308 for 304 and Er-70 for transitions from mild steel to 304.
  7. totensiebush
    totensiebush re-tarded
    Feb 17, 2006
    347
    Alameda, CA
    The troll even suggested a ride height reduction instead. I guess he somehow didn't notice the ride height reduction, or thinks it should be lowered to where it has 2" ground clearance.
  8. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    It got flushed.
    ... I was hoping I was going to get to use the "Kiss your Momma-cousin-sister with that mouth" line on him...
    rrrnnn and 79thunder like this.
  9. 79thunder
    Sep 16, 2017
    273
    Out West
    Looks like I can find Cerakote at gun shops. We've got gun shops!!
    It looks like a couple in my area that carry/apply Cerakote.
    Thanks Samtech, I think that's worth looking into.
  10. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    got a skid plate mock up out of cardboard made.
    figured id go for maximum coverage and make it wide to protect everything including shift lever and brake lever.
    pardon the exhaust, as its not done yet, still has to be touched up , cleaned and polished.
  11. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    bike with skid plate sits at just about 5.6" ground clearance.
    but assuming i can skim it and get it to 6" of ground clearance should be enough for off roading.
    the important part is the skid plate is gonna be very substantial , so she wont have any issues with damaging it or the bike.
    the skid plate will also be mounting to the frame both in the back and front, thus it will act like a "pseudo" double cradle frame, helping frame rigidity when off roading.
    what you guys think?
    rrrnnn, quint7, Atalanta89 and 3 others like this.
  12. Atalanta89
    Atalanta89 Been here awhile
    May 15, 2016
    168
    North Carolina
    Looking forward to seeing more of that skid plate.
  13. Bt10
    Bt10 Long timer
    Dec 18, 2012
    2,172
    Saranac,MI
    Holes for oil filter, drain? Holes for exhaust - cat heat ventilation, oil pan cooling? Love the build.
    :*sip*
  14. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    there is enough room to remove both with the plate on, but it will be kinda a mess and tight squeeze with ur hand. best to just remove the plate as with most bikes.
    there will various drilled holes for ventilation, both for exhaust and oil pan.
  15. 79thunder
    Sep 16, 2017
    273
    Out West
    Skid plate looks good... Although I prefer to use cardboard from empty beer cases.
    The slope at the front should help get the bike up and over any big stuff.
    I like the wrap around side deflectors.
    I agree that removing the skid plate for oil changes isn't a concern, it should be removed once in a while
    to clean out mud, rocks and roadkill.
    I have no idea how many slots or holes to put in the plate for air flow.
    That's where I'm at with my skid plate, looking for that balance between adequate air flow and strength/protection.
    I've been drawing holes on the cardboard.
  16. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    skid plate is all done.
    weighs in a 2632g (5.8lb) including screws, pretty heavy for an aluminum skid plate i know but i wanted maximum protection/ coverage. and at 4.7mm (3/16") thick 6061 she can land the entire bike on a pointy rock and i am confident the plate will survive.
    ground down the welds/edges.
    next, sanded the entire plate smooth.
    3 bolts hold the entire plate on. two in the back and the front bolt is that long one that attaches the engine to the frame. ( so total of 4 mount points).
    reminds me of one of those dakar bikes with the massive skid plate
    exhaust shield flows nicely with the plate.
    oil changes will be a breeze, just take out both back bolts and the plate pivots forward. EZ
    William42, quint7, rrrnnn and 4 others like this.
  17. rockt
    rockt Long timer
    Oct 13, 2003
    3,231
    Canada
    Holy sh-t, man, you've outdone yourself! That thing is a work of art. Yeah it's heavy, but with the parameters you set out and met, you wouldn't be able to make it much lighter. And it's low on the bike so she won't even notice that weight.
    michaelkozera likes this.
  18. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    2,634
    Regina, SK, Canada
    What he said!
    ...ken...
  19. HeadinSouth
    HeadinSouth Adventurer
    Jan 13, 2006
    374
    N Vancouver BC
    Wow love the skid plate, nice work!
  20. rideforzen
    rideforzen Long timer
    Feb 26, 2016
    1,684
    N.W. Oregon
    We used 309 to join stainless to mild.
    Great job on the build !
