Versys owners checkin
Discussion in 'Japanese polycylindered adventure bikes' started by pilot, Oct 17, 2007.
  1. 16VGTIDave
    16VGTIDave Reaver made me do it...
    Nov 4, 2012
    1,394
    Drumbo, Ontario, Canada
    Seconded! I did exactly the same thing and it was a terrible experience. I haven’t had trouble changing tires like that, ever!
    Treat these tires like your mistress - get them hot and use lots of lube!
  2. Atalanta89
    Atalanta89 Been here awhile
    May 15, 2016
    154
    North Carolina
    Shock is on and man what a difference. I’ll be tuning it more, but honestly this is a refreshing upgrade.
  3. Veltins
    Veltins Adventurer
    Jun 24, 2019
    15
    Ohio
    New guy here.
  4. reddirtjoe
    reddirtjoe motorcycle addict
    Dec 21, 2007
    3,038
    Let's Ride some red dirt!!.... NorthCentOklahoma
    Help ......
    My......my wife's
    08 suddenly started randomly stalling
    It will normally restart and run a few second
    It has 30 k miles
    2 brothers exhaust and juice box
    I can't get any codes to show
    Advice ?
    Hints?
    Tey this next ideas ?
  5. jdrocks
    jdrocks Gravel Runner
    Jul 6, 2007
    7,657
    bad fuel or failing fuel pump. with the key on, do you hear the fuel pump pressurize the system?
    add some fuel conditioner to the tank, SeaFoam or equal.
  6. reddirtjoe
    Dec 21, 2007
    3,038
    Fuel pump seems to come on .
    I'll try some SeaFoam
  7. jdrocks
    Jul 6, 2007
    7,657
    1/oz gallon, but i'd be more liberal given the symptoms.
  8. Gustavo
    Gustavo Motociclista Errante
    Jun 1, 2004
    4,332
    Sometimes in Hillsburrito
    It's not enough that you hear the pump. You have to measure it has the right flow and pressure to actually deliver enough fuel to the cylinders. The manual has a procedure to test that.
    Have you been running it in hot conditions with a low fuel level by any chance? I know of several bikes that had issues due to really hot ambient conditions, not all of them were Versys, though.
    Gustavo
  9. Jeff B
    Jeff B Socially Awkward
    Feb 13, 2008
    9,489
    SW PA.
    I have always said, that the fuel in the bottom of the tank does not belong to you.
    It belongs to the fuel pump. :deal
    mminob likes this.
  10. reddirtjoe
    Dec 21, 2007
    3,038
    It has been over and around 100 degrees here lately .......
    Bike has one bar showing bar on the fuel gauge .
    I just tested it this evening .....93 degrees or so outside.......starts up then dies ....
    I'll dump some SeaFoam enriched fuel in it tomorrow.
  11. reddirtjoe
    Dec 21, 2007
    3,038
    Fuel.pump sounds.......different
    I dumped a can of SeaFoam in the tank
    Today its ....32 degrees less hot outside ( that's how the weatherman said )
    Bike now doesn't start ...cranks ..but no firing off
  12. mminob
    mminob MotoHolic
    Mar 24, 2011
    809
    Ocean Beach,California
    Your Two Bros Juice Box could have an issue with the ground and or connectors ? Have you tried disconnecting the Juice Box and just go with the stock injector plugs ? You will need to pull the gas tank ..
    Also check the Clutch safety switch and the Kickstand safety switch ? Or try a used e-bay fuel pump ? As with any motor , check for spark at the plugs and fuel at the fuel line... or buy her a new Versys :-)
  13. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,919
    Central Mn
    Quite often it's one's aftermarket stuff that is the root of surfacing problems. :augie
  14. Motogasoline
    Motogasoline Been here awhile
    Feb 8, 2018
    227
    Conway
    Atalanta89 and MoneySlide like this.
  15. Ridin'nFishin
    Ridin'nFishin Been here awhile Supporter
    Apr 18, 2009
    770
    San Antonio, Tx
    What seat is that?
  16. Jeff B
    Feb 13, 2008
    9,489
    SW PA.
    Lately sometimes when hitting the starter button .............. no clicky, no start.
    Press it again and it would fire up.
    After checking the battery terminals and the engine frame ground [good]
    I decided to remove the starter relay which also carries the main fuse and check it on the bench.
    When I used jumper wires and put 12V on the proper terminals it went click every time.
    So I cleaned all the connections and reinstalled it and it works fine now.
    So it was just the connections in the first place. Which is good cause a replacement was over a $100
    Just thought I'd share this for what it's worth.
  17. Atalanta89
    May 15, 2016
    154
    North Carolina
    It’s a Seat Concepts *Low Comfort* seat. Which is an inch lower, awesome product, I got it with the gripper top. I sent my seat to them, had them install it and sent it back. Less than $325 in it.
  18. Atalanta89
    May 15, 2016
    154
    North Carolina
    It’s crazy what troubleshooting can do, awesome that it was just that and nothing more serious. I had a similar occurrence troubleshooting wise with my heated grips. It ended up just being a fuse and saved me some coin. I always try to check fuses, connections etc before replacing items.
  19. Jeff B
    Feb 13, 2008
    9,489
    SW PA.
    But what cause the fuse to overload?
  20. Jeff B
    Feb 13, 2008
    9,489
    SW PA.
    Another possible cause of a starter working intermittently, is worn brushes and commutator bars.
    The starter is buried under the throttle bodies so I'm hoping it hangs in there for all eternity.
