Versys owners checkin
Discussion in 'Japanese polycylindered adventure bikes' started by pilot, Oct 17, 2007.
  1. mminob
    mminob MotoHolic
    Mar 24, 2011
    914
    Ocean Beach,California
    Yes , ABS brake line kits are much different and will be harder to find... Maybe just go with a set of HH sintered pads and a fluid flush with bleeding ?
    This is your 2014 ABS brake line system, good luck. :-)
  2. tomo8r
    tomo8r Long timer
    Oct 9, 2014
    1,944
    Bathurst
    HEL will do it, they'll just charge you for it.
    https://www.motospares.com.au/hel-performance-brake-line-kits-all-models/
    "Please Note: If you have an ABS bike please DO NOT ORDER!
    Fitting Braided Brake Lines to a bike with ABS Brakes requires more than just one brake line per caliper. Typically, if your bike has an ABS (Antilock Braking System), it will have around 5 to 7 brake lines. If you want to swap to braided lines all of these lines will need to be replaced in order for the ABS to function correctly. The downside of this is that the costs are higher for the brake line kit, usually around $300.00 - $600.00. Plus there are extra costs involved in fitting to consider. If your bikes has an ABS braking you will need to contact us or call is with your make / model / year for a quote."
