Victorian dirties (Berg FE570 for the high country)
Discussion in 'Australia' started by AUSSIEADV, Jul 18, 2016.
  1. Simosez
    Simosez go ride your bike.
    Oct 13, 2010
    1,260
    eternally sunny lithgow
    Cheapest brand new bike I've ever bought.
  2. Catz
    Catz Been here awhile
    Jul 26, 2014
    719
    Vic
    Obviously not enough time. Otherwise we’d be still riding.
    That 610 is a weapon, so much power down low, sounds great,
    Just need a stronger hub to support all that torque at the back wheel
    :lift
    Dukehunt and BygDaddee like this.
  3. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    6,896
    Brisbane Northside, OZ
    The Yamaha didnt break down ? :D
    darren70 and Catz like this.
  4. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    1,771
    Gippsland
    Not enough gears to break the bearings:lol3
  5. AUSSIEADV
    AUSSIEADV Long timer
    Sep 5, 2006
    7,469
    Ned and Wild's fight site
    Fairdinkum Paul you troll! :lol3
    BygDaddee and Dukehunt like this.
  6. AUSSIEADV
    Sep 5, 2006
    7,469
    Dallas was out motarding in the dirt getting some practice. He went great out in the bush. A great day for ridinng.
    dunc, jardine, darren70 and 3 others like this.
  7. AUSSIEADV
    Sep 5, 2006
    7,469
    I swapped out the back wheel. The hub init has flogged out the seal seat. I’ve ordered another hub. I could have a go at 2 part epoxy to build up where the seal sits.
    It flogged out the chain working on angles. Not a biggy as the chain looked to be on its last legs. Changed the sprockets from 15/51 to 14/46 to give the 610 some breathing space between gear changes and gain a little traction.
    The Beauty of the bent Berg being built out of a lot of Toom parts means there are plenty of aftermarket parts avail. The light switch block was shagged so I was able to source one off EBay for $30. Complete plug and play and now the headlight works. Getting around to working on the little things. Shame I missed the wheel brgs but argh, you get that. This bike was very poorly maintained, actually not maintained at all. I’ll get it at least trail registered.
    LivingdeadCamo and BygDaddee like this.
  8. bigbrad
    bigbrad Been here awhile
    Feb 3, 2015
    943
    Margate Beach
    Better check them front ones too
  9. AUSSIEADV
    Sep 5, 2006
    7,469
    That’s in the morning. I may swap out the wheel yet.
  10. Paul124ac
    Paul124ac Long timer
    Apr 28, 2015
    1,826
    NE Vic
    Where were ya? Looks dry, Pilot? We went up Mt Murra, pretty sloppy initially and some chewed up 4by shit, up the top was just about perfect with wet tracks but heaps of grip.
  11. Bluetonguejak
    Sep 16, 2009
    1,771
    Gippsland
    Seals are over-rated, they keep more shit in than out!
    Packing the bearings full of grease (and regular repacking) is a better moisture barrier. (They don't spin fast enough to cause heat issues from being over-packed)
    The seals are only handy to hold the spacers in place:nod
    Keep the hub and I'll machine/bush it for you as a spare.:thumbup
  12. AUSSIEADV
    Sep 5, 2006
    7,469
    I have the same view re seals. The bearings are sealed as is.
    Thanks mate. :thumb
  13. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    8,965
    Snowy Mountains Oz
    Here's my real '98 FE501, not a wannabe
    Still in the container, gets run every now and then. Probably the most fit for purpose, reliable, toughest bike I've ever owned
  14. AUSSIEADV
    Sep 5, 2006
    7,469
    Some more work done to the 610. Oil/filter change, mirror, lead acid battery back in as the lithium out of the 450 just wouldnt start it. Removed the speedo to put away in storage. The working switch block has given the headlight some power. The back wheel with 14/46 gearing is ideal. Idle adjust.
    Trying to get info on wrist pin weight is turning out to be a challenge. You wouldnt think so considering weight is extremely important. I need to find the lightest pin avail then reduce some piston material.
    hoorang, bigbrad, Dukehunt and 2 others like this.
  15. AUSSIEADV
    Sep 5, 2006
    7,469
    Hey Paul, sorry mate, forgot to respond.
    In between Beechworh and Yack. It was great out there. Dal and I are going out again wensdy arvo.
  16. darren70
    darren70 I don't own a KTM
    Sep 11, 2013
    2,739
    Hunter Valley
    Al???[​IMG]
    DeLewis, LivingdeadCamo and Paul124ac like this.
  17. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,493
    Narre Warren Victoria
    Why would Al write penis on the wall?
  18. darren70
    Sep 11, 2013
    2,739
    Hunter Valley
    Because he's too polite to swear
  19. AUSSIEADV
    Sep 5, 2006
    7,469
    He’s a good bloke that Penis.
    So who’s cooking c**t stew?
  20. LivingdeadCamo
    LivingdeadCamo Long timer
    Feb 6, 2016
    1,166
    Woongarrah, NSW, Australia.
    AUSSIEADV likes this.
