Victorian dirties (Berg FE570 for the high country)
Discussion in 'Australia' started by AUSSIEADV, Jul 18, 2016.
  1. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    12,664
    Northside Brisbane, Qld Australia
    Just don't take a dive during your readers ride Al.
    AUSSIEADV likes this.
  2. Cruz
    Nov 3, 2008
    12,664
    Pull clutch in and nothing. Haven't had a chance to look at it yet. I am presuming slave cylinder seal again.
  3. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    11,527
    Ned and Wild’s fight site
    No leaking at the master? Fit an Oberon slave and be done with it.
    Kiwirich likes this.
  4. Cruz
    Nov 3, 2008
    12,664
    Yeah, plan is to do that, but a heap of other things around the house at the the moment. What did it cost?
    No sign of leak at the master cylinder.
  5. AUSSIEADV
    Sep 5, 2006
    11,527
    Sounds like the slave. About $160 from memory. The master can score also. Kit is about $45 from memory. A light hone and a new kit. You can remove the master and hold it up, pull it apart, look inside and reassemble without having to bleed.
  6. Cruz
    Nov 3, 2008
    12,664
    Will bleed it from the bottom and see what happens.
  7. richo360
    richo360 Long timer
    Sep 5, 2011
    4,028
    Melb Bayside
    Funny you should mention that Cruz... I fitted new bars on Sunday to the 570. All good.
    Looked at it this arvo. Nada, zero pressure at the clutch lever.
    Cruz likes this.
  8. AUSSIEADV
    Sep 5, 2006
    11,527
    Bruce, what i do is loosen the bleed screw a tad, remove slave and put a clamp on the slave. Ive seen slaves with the circlip land broken out. I reckon people have bleed then pulled on the lever without the slave fitted.
    Use a decent (60ml) syringe to back bleed.
  9. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    10,701
    Brisbane Northside, OZ
    I sprayed a bit of crc down my clutch cable sleeve today, didnt need any adjustment
  10. AUSSIEADV
    Sep 5, 2006
    11,527
    Too good mate. I could imagine theyd dry out from a lack of use.
    Dukehunt, Kiwirich and BygDaddee like this.
  11. Rob Keogh
    Rob Keogh Chuckles
    Jun 22, 2020
    11
    Tyers and also Shepparton region through the week
    A mate is offering to do me a set of stickers for the Husaberg.
    One thing....he insists on calling it the Hindenberg on account of my spectacular riding abilities. images.jpeg-7.jpg
  12. AUSSIEADV
    Sep 5, 2006
    11,527
    I think Richo is after some stickers if youre selling Rob!
  13. Rob Keogh
    Rob Keogh Chuckles
    Jun 22, 2020
    11
    Righto Al
    Ritcho PM me with your details and i'll sort it out mate.
    Not sure about quality yet.
  14. AUSSIEADV
    Sep 5, 2006
    11,527
    @richo360
  15. AUSSIEADV
    Sep 5, 2006
    11,527
    ADB mag want pics and a write up on Muff for their ‘readers ride’ segment. Best i can come up with with an old beat up Note 5.
    43DB3940-611A-459C-BC98-46B560628AEC.jpeg D6A21659-9D2F-4108-AE5D-868C13653BB5.jpeg 6E3D7BC0-079A-46D8-89D9-E9320DCA98F7.jpeg AE660D79-B3BC-444E-9BC3-7B1F451A6C3D.jpeg
    DeLewis, 4noms, Hoots and 7 others like this.
  16. mrsdnf
    mrsdnf Been here awhile
    Feb 8, 2019
    903
    Lost between the Dandenongs and Yarra Valley
    Pics look orsm. The bikes not bad as well. Makes me want to go riding.
    Kiwirich and AUSSIEADV like this.
  17. AUSSIEADV
    Sep 5, 2006
    11,527
    Are you in lockdown down there Moose? My daughter is in Seville East.
  18. mrsdnf
    Feb 8, 2019
    903
    Yep. Seville's about ten minutes away. Go through there often.
  19. AUSSIEADV
    Sep 5, 2006
    11,527
    Dukehunt likes this.
  20. anadel
    anadel Been here awhile
    Apr 16, 2006
    173
    Al
    so much better than the faded plastic! i assume the side covers were similar method
    graham
