1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Victorian dirties (Berg FE570 for the high country)
Discussion in 'Australia' started by AUSSIEADV, Jul 18, 2016.
  1. shank
    shank Shank950
    Nov 7, 2006
    942
    Diddillibah, Qld, Australia
    Mine In adventure Trim, Its a good bit of gear. berg in adv trim. gatton forestry.jpg
    #81
    4x4family1, twotyred, Hoots and 2 others like this.
  2. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    12,073
    Ned and Wild’s fight site
    Yeah the blue tanks are nice
    #82
  3. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    14,681
    Northside Brisbane, Qld Australia
    Hey Shank, which bash plate is that? Does it make things a bit warm around the engine?
    #83
    Nobby2tires likes this.
  4. twotyred
    twotyred Practising Recedivist
    Feb 9, 2006
    5,723
    Bruthen Victoria
    I agree, the blue looks very nice, but I got the 'white' so I could see how much fuel I have in my tank. Never regretted thast decision.
    #84
    AUSSIEADV likes this.
  5. shank
    shank Shank950
    Nov 7, 2006
    942
    Cruz It Is a HYDE bash plate, I've had no issue with the engine getting to hot. It also has the HYDE left side case saver.
    I bought the bike from Dean Nuttall, he used it as his training bike for Dakar. He never had any issues with extra heat as far as I'm aware.
    http://www.hyderacing.com/store/dirtbike/husaberg.htm?pid=368
    #85
  6. Cruz
    Nov 3, 2008
    14,681
    Used to have the Hyde plate on my XCH. Nice and light.
    #86
    shank likes this.
  7. AUSSIEADV
    Sep 5, 2006
    12,073
    Cruz sent me an under seat tank that has some issues with a couple threaded inserts.
    Thanks heaps mate. :thumb
    I'll have a go at fixing these with some 3M DP8005 crossed link polyethylene 2part apoxy and some nut serts. The apoxy is $50 (that's cool) but the applicator gun is $150!!! Anyone got an applicator I can borrow?
    The Vortex ECU is fitted, the Cyclops LED headlight globe (bright), Steg pegs, phone ram mount. The Vapor speedo is all sorted.
    I'll fit the mounts for the Kriega bags soon and do a look/see for the luggage. The Giant Loop Fandango tank bag arrived. Nice size/shape for this bike. I'll see how the two Desert Fox bladders will work draped over the tank like tank panniers once they arrive.
    Will run something like 15/48 gearing.
    Yet to check where the current dampening settings are at, sag and all that.
    Haven't had much of a chance to do anything too major with the bike or go for a decent run with work and this bloody weather. Carn Spring!!!
    #87
    troy safari carpente and shank like this.
  8. Hoots
    Hoots Long timer
    May 16, 2011
    5,400
    I bought a repair kit from SuperCheap (or somewhere similar) that was designed for plastic fuel tanks
    It was after I holed one of the Rally Raid tanks, which they subsequently offered to replace
    It was very inexpensive from memory - few dollars - blurb on packet sounded confident, and you'd think there would have to have been some testing involved re' possible ramifications with a fuel tank ...
    That sort of thing wouldn't do the job?
    #88
  9. AUSSIEADV
    Sep 5, 2006
    12,073
    Depends on what the tank is made of Hoots.
    I did buy some guff from Supercheap to repair a busted chainsaw tank. Worked very well, but I have never smelt anything else so offensive. I looked into the specs of this stuff but it won't work on this tank. These are made of what's called 'crossed link polyethylene'. The only adhesive I've been able to locate that will work with the material is the 3M DP8005 due to its unique characteristics. It has a 6 month shelf life and you need to use within 10 seconds! If it wasn't for this product, I think this tank would be stuffed. So here's to hoping.
    #89
    Hoots likes this.
  10. Cruz
    Nov 3, 2008
    14,681
    The berg tanks have had a lot of people use many different products looking for a fix and repair and only one or two have been successful with the material used to make them.
    #90
  11. Hay Ewe
    Hay Ewe Just a Wannabe
    Jul 17, 2005
    7,112
    FNQ - AUS
    Got a link or picture of the $150 applicator gun?
    Some one may know of somthing or some one
    #91
  12. Cruz
    Nov 3, 2008
    14,681
    #92
  13. Gasman_ADV
    Gasman_ADV Long timer
    May 1, 2012
    1,081
    20160801_221237.jpg Man your not trying hard enough
    I just glued up part of the toilet using a glue more expensive than yours ....cheaper than a Acro slipon carbon fibre endcap
    Here's my applicater
    Screwdriver thingy ....push each tube down a bit ..mix with cotton buds ..
    Fixed
    #93
    hoorang likes this.
  14. AUSSIEADV
    Sep 5, 2006
    12,073
    I am mate. The brain box has been clunking away.
    One of the successes of this adhesive is getting the 10:1 ratio correct and I only have 10 seconds!
    The plungers at different ratio's can be purchased separately as can the mixing nozzle so that's a start.
    Maybe modify a caulking gun.
    #94
  15. hoorang
    hoorang .
    Feb 16, 2015
    1,017
    Curlewis NSW
    Some 6mm round black steel bar(the soft steel not bright), bent into a tight U shape, file the legs of the U the same length for even delivery?
    #95
  16. AUSSIEADV
    Sep 5, 2006
    12,073
    Hoorang, the plungers come separate in different ratio's so that's not a prob as is the nozzles. It was the applicator on it's own around the $150 mark.
    I found this - http://www.ebay.com.au/itm/50ML-AB-...b63e111&pid=100033&rk=1&rkt=8&sd=262488532283
    #96
  17. Hay Ewe
    Jul 17, 2005
    7,112
    FNQ - AUS
    ok, I have seen applicator nozzles / tubes like that.
    Yep, specific for the correct mix rate
    is it 10 secounds that you have after the two parts have been mixed?
    If so, you could get the amount by weight (50grams of part A, 5 grams of part B) mix up and apply, but yes, the 10 seconds is a problem.
    #97
  18. Hay Ewe
    Jul 17, 2005
    7,112
    FNQ - AUS
  19. Gasman_ADV
    May 1, 2012
    1,081
    Did I mention I used to be a farmer :)
    Just make up a stick with 2 different length dowls and push then mix
    I have the mixing nozzel as well but havent used it
    #99
  20. AUSSIEADV
    Sep 5, 2006
    12,073
