Viking oven broiler element
Discussion in 'The Garage' started by double_entendre, Sep 3, 2019.
  1. double_entendre
    double_entendre It's nothing personal; just your existence.
    Aug 11, 2008
    12,281
    Huntington Beach, CA
    So my oven's (VESO530TAR) broiler element has stopped working.
    Unfortunately, my friends at Viking won't send me a service manual, of course. (Insert right to repair rant here.)
    Damned if I can figure out how to remove the broiler element from the wires coming out of the back of the oven.
  2. bluestar
    bluestar sheep shagger
    Mar 14, 2014
    26,900
    sheep pen
    You use that to cook your Viking food?
    SmittyBlackstone likes this.
  3. double_entendre
    Aug 11, 2008
    12,281
    Vikings don't cook food, dumb dumb. They eat it raw like real men.
    SmittyBlackstone and bluestar like this.
  4. Zoef zoef
    Zoef zoef Long timer
    Apr 19, 2009
    1,168
    Finnøy Island, near Stavanger, Norway
    Hmm, I see two elements, one vertical (in front), and one horizontal (in the back). Which one do you want to remove?
    Horizontal: looks like loosen two screws and pull it out. Vertical one, looks like the box around it has to be removed.
  5. double_entendre
    Aug 11, 2008
    12,281
    Took me a minute to see what you're seeing.
    I need to disconnect the silver ribbon-like things from the connectors attached to the white wires.
  6. Zoef zoef
    Apr 19, 2009
    1,168
    Looks like the disconection is done somewhere else. Wires here appear to be spotwelded.
    You may have to follow the white wires.
  7. bluestar
    Mar 14, 2014
    26,900
    sheep pen
    Ah, you're cooking hot dogs. :thumb
    You really shoulda put this in JM. :lol3
    double_entendre likes this.
  8. double_entendre
    Aug 11, 2008
    12,281
    Fuck I hope not. If so, I need to pull the oven out of the wall. :baldy
    Hot dogs on a helicopter. :deal
    Yeah, I'll leave that for @Jim Moore. He likes taking it in the ass verbal abuse and mockery mixed in with his help. :lol3
    #8
    trumpet, Jim Moore and bluestar like this.
  9. Boomer343
    Boomer343 Been here awhile
    Apr 14, 2014
    736
    Calgary
    #9
  10. spafxer
    spafxer Long timer
    Mar 12, 2007
    3,371
    Have you put a VOM on it at those connections? Volts to see if it's getting 240V and ohms to see if there is continuity in the element itself...
    This will tell you which way to go in your troubleshooting.
    #10
  11. ydarg
    ydarg Miscreant
    Nov 11, 2015
    2,062
    Above the Equator
    Service manual is probably tucked inside oven behind control panel.
    Have a BlueStar range that was the same way, service manual was tucked up under the top once you opened it.
    #11
  12. double_entendre
    Aug 11, 2008
    12,281
    Fortunately I found it online.
    I did the installation, so I know there's no manual.
    Viking customer service told me to pound sand when I asked for a service manual. Only the user and install manual are public.
    When I got in there, it looked like one of the connections came loose. Don't know if I could reconnect it of not. I don't have equipment to spot weld. Would soldering work?
    #12
    ydarg likes this.
  13. double_entendre
    Aug 11, 2008
    12,281
    #13
  14. spafxer
    spafxer Long timer
    Mar 12, 2007
    3,371
    High temp solder (silver) probably won't suffice. About 1200 F depending on alloy
    Make a mechanical joint like a crimp, clamp, or bolt and washers with stainless steel..?
    #14
    HeavyMetal likes this.
  15. Steve_h
    Steve_h Been here awhile
    Sep 15, 2016
    789
    Spartanburg, SC
    I'll agree. The element gets much hotter than the air in the oven. A good physical joint is the way to go here. Even high temp solder might melt on you after a long while in operation. Looks and sounds like they really don't want you repairing that unit. Screw 'em. Fix it anyway.
    #15
  16. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    2,975
    Northern California
    It's already broken. It's your turn to either fix it or break it some more.
    #16
  17. double_entendre
    Aug 11, 2008
    12,281
    So bought this online from an authorized source. Box was open and the wires look like this. Install it or return it?
    #17
  18. bluestar
    Mar 14, 2014
    26,900
    sheep pen
    I'd use it. Doesn't look like you have bare wires. :dunno
    #18
  19. double_entendre
    Aug 11, 2008
    12,281
    Thank you. I just wanted to be sure before I went to the trouble of doing it.
    :thumb
    #19
  20. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,359
    VA Beach, VA
    I'm not sure what the issue is? Where the wires are bent a bit before the connector? Everything looks fine to me.
    #20
