Villageidiot destroys a perfectly nice sportster.
Discussion in 'Some Assembly Required' started by villageidiot, Oct 26, 2018.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    16,782
    Orange County, CA
    A1E66227-E185-4EA2-9280-194930138CAA.jpeg 64894268-64AD-4175-B1CE-387264387BEA.jpeg B78D27F0-DF4C-4D11-ACB7-6A9E873FCE8F.jpeg
    Hubs are back, bearings are in the freezer, I’ll get these mofos assembled this afternoon and hopefully drop the hubs and hoops off tomorrow on my lunch break.
    #61
    TonyKZ1, sealsam, Fast Idle and 2 others like this.
  2. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    20,941
    Villa Maria Sanitarium, Claremont, CA. USA
    Moving right along......you don’t mess around Man!
    #62
    villageidiot likes this.
  3. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    Pressed the bearings in after lunch, will bolt em up tonite before I take em in make sure it all feels good.
    #63
  4. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    I’m trying to do one task a day kind of a thing. This is not an incredibly hard build, or time consuming, I just wanna enjoy it and not get bogged down and too many steps ahead of myself.
    #64
    JagLite, JimVonBaden and Wkendwrench like this.
  5. TUCKERS
    Dec 23, 2005
    20,941
    Well you are doing great............................
    #65
    JimVonBaden and villageidiot like this.
  6. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    5,467
    Ah, Monsieur Tuckers weighing in, always the sign of a discerning build. Must be cooling off in Ca and the English ex-pats are waking up for the winter :thumbup
    #66
  7. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    FACK!!
    front wheel bearings work perfect, torques up, everything feels nice.
    i think the rear axle spacer between the bearings is borked. everything feels good, but when you tighten it, it binds and won't rotate. there was some gouging on the rear spacer ends that i filed flat, and its probably enough that the bearings load hard when torqued up. new set of bearings and an axle spacer on order.
    question is, should i take the hubs and rims in as it is for spokes and lacing? or wait and install the new bearings and spacer in the hub and check and make sure its all good before i lace up the wheels.
    its FIVE DAYS for the spacer....... shitty.
    #67
  8. WYO George
    WYO George I have no idea
    Sep 1, 2005
    6,972
    left of nowhere, WY
    I would verify that the hub is good with the new parts before taking it in myself, but if you feel confident that the hub is fine and all it needs are the new bearings nad spacer then by all means take it in now.
    #68
    JagLite likes this.
  9. Royce Cochran
    Royce Cochran was 2bold2getold
    Dec 10, 2011
    5,623
    Arlington, Texas
    Can you cut a little shim (brass, paper etc) and try again ??? Might just need a little file or hammer adjustment. :D
    #69
    JagLite likes this.
  10. TUCKERS
    Dec 23, 2005
    20,941
    70 F at 6pm. Sitting outside drinking cold Newcastle Brown.
    #70
    TonyKZ1, vector6 and JagLite like this.
  11. TUCKERS
    Dec 23, 2005
    20,941
  12. TUCKERS
    Dec 23, 2005
    20,941
    E40AB8C7-877F-4123-A313-DCD87EFC223D.jpeg G kids came over for Halloween. Made this helmet as. Busy fingers project. I’ll donate it to the villageidiot.
    #72
  13. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    Nah, those bearings are a motherfucker to remove/extract. The amount of force it takes to press out will (in my opinion) compromise the bearing. Axle spacers between the bearings is not something I wanna get wrong.
    #73
    JagLite likes this.
  14. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    See, if I verify it’s good, it will be.
    If I take it in and lace it up, it’ll be bad.
    That’s my luck.
    I’ll wait
    #74
  15. WYO George
    Sep 1, 2005
    6,972
    left of nowhere, WY
    Yep, that's how it would play out for me too. My luck can oftentimes suck. For instance, last night I was finishing up a repair on a customer's ATV. I was literally three bolts away from being finished with the job when he called me to ask how it was going. I told him it was basically done and that he could pick it up today. Right after hanging up the phone I discovered that I had two bolts and three bolt holes. I scoured the work bay and then the entire shop looking for the missing bolt. I then pulled the case covers off and checked inside the engine for the missing bolt. I finally had to call him back and tell him that it would be delayed 5 days while I waited on a replacement bolt. He laughed and said no worries as he doesn't need it for two more weeks, but damn it pissed me off. I wonder if I'll ever figured out what happened to the missing bolt.
    #75
    JagLite and villageidiot like this.
  16. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,876
    Anchorage Alaska
    My latest goof was ending up with one bolt left after everything was back together. :scratch
    (Changing the timing belt & water pump in my Miata).
    During disassembly I put the bolts for each part in a different compartment with a sticky note of what they're for.
    (Lately I've been using the clear plastic trays the good apples come in, works great)
    At the end of the job there was one 10mm bolt in the water pump compartment. :fpalm
    I had noticed it was left over when I installed the pump but there were no empty bolt holes so I decided I must have dropped it in that spot by accident and would discover where it went eventually... nope. :dunno
    All back together, fill the radiator and start it up only to discover a serious leak. :becca
    Drain the system again, remove the radiator, cam cover, belts, pulleys, alternator, power steering and AC brackets, timing belt coves, timing belt, and finally the water pump. No obvious cause for the leak so a careful reassembly ended up with no extra bolt left over. :confused
    I have no idea where that extra bolt went, I never found an empty bolt hole. :loco
    All back together, fill the radiator and fire it up...
    The stinking leak is the same.
    ARGH!!!! :baldy :devildog
    Third time taking it all apart, then a very close inspection of the new water pump showed one corner of the inlet flange was very thin and the factory gasket may not have sealed it. I cut a new gasket and made it full width of the flange and added gasket sealer to the skinny corner.
    All reassembled and filled I started it up...
    No leaking, finally. :thumb
    I hate working on cars! :dirtdog
    #76
    wee-twin, garfey, Webman and 5 others like this.
  17. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    Me too!!!! But I’ve done it daily for near 20 years. It’s a shame I’m good at it.
    #77
    WYO George and JagLite like this.
  18. fast1075
    fast1075 Not a Lemming
    Dec 28, 2013
    2,007
    Flaw'da
    V.I. if you were local and could stop by, I would turn you a new spacer. They are very easy to make if you have a lathe. All it takes to kill a spacer (and the bearings) is a gorilla with a breaker bar. You could pull a bearing with an inside puller and a jack screw to get it apart, but unless it is a special (read expensive) bearing it isn't worth saving. I owned and worked on several Buells. They used an aluminum spacer. Very easy to crush with overtorque.
    As for bearings, I have seen far too many killed in assembly. You are supposed to install them with a BFH, right? Can you say spalled on installation?
    #78
  19. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    Yeah, the spacer is $12 from Harley, it’s steel, I’m not worried about it.
    I have a lathe, and probably the tubing. I froze the bearings, warmed the hub, and a light press fit in. Then everything shrinks/expands and it’s a super tight fit.
    The spacer had some gouging on the ends, I filed it smooth, only takes a few thou. Shoulda stopped and got a spacer before install. But I didn’t.
    #79
    JagLite likes this.
  20. villageidiot
    Apr 29, 2010
    16,782
    Orange County, CA
    These showed up today, Mitas E-07
    #80
