Villageidiot destroys a perfectly nice sportster.
Discussion in 'Some Assembly Required' started by villageidiot, Oct 26, 2018.
  1. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,114
    Villa Maria Sanitarium, Claremont, CA. USA
    Darn...we are in Utah then at the Royal Enfield Himalayan Spring Fling (I know weird eh?)
    JagLite and villageidiot like this.
  2. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,029
    Orange County, CA
    Did you get a Himalayan?
  3. TUCKERS
    Dec 23, 2005
    19,114
    NO. But we were looking for an excuse to take the Mad Max Motorhome out with the Yamaha XT225's on board and this came up! I am interested in the Himalayan. Also a nice opportunity to spend a week in Zion and race the TuTu5's against some Enfields! Its a small rally...maybe 15 bikes I heard.
  4. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    Very cool.
  5. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    took it out for a 50 mile rip in the local foothills.
    bike is nice. need to suss out a few things:
    gearing, it won't pull 5th
    seat, looks sharp, but its a torture rack, but ill keep it for short hops.
    mnmmike, Fast Idle, AK650 and 2 others like this.
  6. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    4,231
    Mid Wet Or A Gun
    Looking at post #1228 your front sprocket looks huge.
    So the bike started with belt drive, eh?
    I don't know HD's ..but why does the front sprocket ....area....look like it has a huge sproket?
  7. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    Stock was belt drive.
    Stock ratio would be 22/48, I went 23/48, forgetting that my tire is taller by about 5%
    It’s too overdriven.
    I’ll be going to 22/51 I think.
    As to the sprockets being big, the front spline is pretty big, the stock pulley is 27t front 61 rear.
    It also runs a 530 chain.
  8. Webman
    Webman Been here awhile
    Jan 5, 2016
    598
    Arizona
    Somebody far more knowledgeable than me probably has a better description, but looking at the belt and the size of the teeth, I'd guess there's a limit to how tightly it will bend around a pulley. HD probably used the minimum radius of the belt as a baseline for designing the pulley.
    HapHazard likes this.
  9. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,054
    Alaska
    Before you order any sprockets, let me check my stash....I may have something for you.
    villageidiot likes this.
  10. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    looks like I'm using
    2073SX -48t rear sprocket, steel with the larger hole for the hub (2000-2003)
    and
    283- 22t front sprocket which is 1/2" offset.
    these are what PBI recommended to me based on year etc. and they went on bang on with no issues.
  11. AK650
    Jun 26, 2013
    1,054
    Alaska
    Here's what I have on hand. All PBI part #'s......
    277-23 C/S Steel 23T Front
    2072-52 Aluminum 52T Rear
    If they'll do you any good, let me know. My bike is a '91 so these may not fit your '03??
  12. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    Appreciate the offer Jeff, but yeah, they’re for the earlier gen trans output shaft and hub.
    I’ll order up some new sprockets.
    AK650 likes this.
  13. AK650
    Jun 26, 2013
    1,054
    Alaska
    Yep, I suspected that would be the case.
  14. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    ordered up a new set of front and rear sprockets.
    22/51
    i gotta order another master link so i can splice in a section of links to make up the gear change.
    AK650 and Fast Idle like this.
  15. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    3,979
    Long Beach, California
    as long as you don't do 1/2 links...
  16. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    Nah, I’ll just splice in a link or 2 with 2 master links. It’s how I used to change gear on the speedway bike, chain for smallest sprockets, and then add links up to the biggest in the stack.
    Of course we weren’t running o ring chains, and chains got changed every 6 or so race nights, but the practice is sound.
    JagLite likes this.
  17. Kai Ju
    Jul 29, 2009
    3,979
    I was just yanking your chain...pun intended.
    Honda-50, JagLite, AK650 and 2 others like this.
  18. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    7,574
    Anchorage Alaska
    :imaposer
  19. villageidiot
    Apr 29, 2010
    11,029
    Orange County, CA
    Last nights build,
    Mom text me that her water heater was leaking, so I went to Home Depot on the way there and picked up what I thought she’d need, knowing I’d have to go back to get lines n shit, and copper for the pop off valve.
    Now, I’ve never installed a water heater, and I’m definitely no plumber, but my ass hangs outta my pants and that makes me certified.
    Got it all in, had to sweat a new fitting to the pipe in the wall, replace the ball valve, new lines, etc.
    No leaks, and she’s got hot water again. Much hotter water than she had before with the 10yr old unit.
    Took til 10pm by the time it was all said and done, but it’s done.
  20. sandsman
    sandsman Shut up and ride!!!!
    Jul 26, 2011
    1,355
    Greenville, Tx
    Clean looking install, done right. Hey, you can go to work now as a plumber's helper.
    Three rules of a plumber to live by:
    1. Poo runs down hill.
    2. Payday is Friday.
    3. Don't chew on your fingernails.
    :imaposer
    sealsam, AK650, Webman and 5 others like this.
