Vintage KTM Forum
Discussion in '2 smokers' started by makazica, Jun 9, 2015.
  1. makazica
    makazica Been here awhile
    May 17, 2008
    865
    Zagreb, Croatia
    Could somebody recommend a good english vintage KTM forum?
    I'm looking for info on 1980-1990 two strokes.
    M.
  2. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    793
    Cantwell, AK
  3. makazica
    May 17, 2008
    865
    Zagreb, Croatia
    Thank you sir!
  4. AlpinaE24
    AlpinaE24 Long timer
    Nov 2, 2010
    1,129
    az
    I have a copy of the factory 250 1988/9 service manual and parts diagram if you need any info
  5. ukdirtdigger
    ukdirtdigger Adventurer
    Jan 31, 2017
    34
    Rhayader, Mid-Wales, UK
    Hi. I just bought an 88 250 enduro bike....would love to get my hands on a copy of that.....happy to pay for copying and your trouble.
  6. vsabbagh
    vsabbagh n00b
    Mar 30, 2020
    5
    Salisbury
    Hi, I have a 1984 KTM 125 MX, The clutch mechanism doesn't seem to be aligned with the clutch rod, any suggestions before I start disassembling the engine?
  7. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,314
    Summer: Kemiƶ, Finland; Winter: North Germany
    Mmh that is strange you should compare the items mounted to your clutch assembly with the explosion drawing of the part list, maybe something is missing, especially the small ball between rod and actuation unit.
    And yes KTMTalk is the Forum for KTM in general and for vintage / historic KTM'S of all ages in particular.
  8. vsabbagh
    vsabbagh n00b
    Mar 30, 2020
    5
    Salisbury
    Hi, I seem to be missing (2,3) all of these pieces, because the clutch rod doesn't seem getting enough leverage on the presssure plate. Any idea's for a part substitution, or where I could find these parts?
    Regards,
    #8
  9. PSchrauber
    Jan 3, 2011
    1,314
    That is a "Kupplungs Druckpliz Lager" should be available.
    In English a Clutch pressure mushroom bearing probably.
    I would use the part list number a ask a good KTM Dealer, in the US I can recommend KTM Munn Racing.
    #9
  10. vsabbagh
    vsabbagh n00b
    Mar 30, 2020
    5
    Salisbury
    Thanks, so it turns out I have those however, my push rod has signs of war so I'm going to remove the Black Arm and see if that's worn out too.
    #10
  11. vsabbagh
    vsabbagh n00b
    Mar 30, 2020
    5
    Salisbury
    So, I've gotten the entire clutch mechanism working. But I seem to have trouble finding the Carb Wiring, because I currently only have the fuel and another line from the Clutch casing going to one of the two ports, whereas the other port has no fuel line for some reason going to anything. I can get the bike started, but not running any suggestions? I've been dousing the carb with cleaner
    #11
  12. vsabbagh
    vsabbagh n00b
    Mar 30, 2020
    5
    Salisbury
    I'm currently have issues getting the clutch to fully engage in my 84' 125 MX do you have any suggestions? The rod and mechanism seem to be in great shape, but its not getting enough leverage to engage the clutch. Could it be that its not tight enough, but theres also a bit of wiggle room by the needle bearing washer the rod hits under the plate. It's also not the cable, anything would be greatly appreciated.
    Regards,
    #12
