Vintagec Bronco sat fir 4 years. Startup
Discussion in 'The Garage' started by Lomez, Sep 3, 2019.
  1. Lomez
    Lomez Been here awhile
    Mar 27, 2011
    309
    San Francisco, CA
    Decided to just give it a shot rather than fully drain the tank and rebuilding the carbs. Went ahead and put a battery jumper on and cranked it for about 30 seconds while pumping the gas. Surprisingly, it sputtered to life ..... but only sputtered. It idled on about 5 or 6 cylinders while blowing copious amounts of black very very rich fuel smelling smoke. No matter what I did I couldn't seem to get it out of this condition.
    When I stopped to look under the hood there was a couple of cups of liquid gasoline sitting in all the galleys of the intake manifold as well as elsewhere. I should know what is going on but I don't. What is the problem? What should I look at cleaning up or fixing to see if I can get this sorted out? Thanks
  2. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    466
    Iowa, USA
    Float is probably stuck
  3. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    14,818
    the hills
    First place I'd look.
  4. ABHooligan
    ABHooligan The Flying Mythos
    Oct 2, 2008
    1,400
    Chattanooga
    Sometimes tapping on the bowl with a screwdriver (gently!) will unstick the float or free the trash holding it open. Also, try fueling it from a vessel of fresh fuel. Old stuff won't burn very well at all. The black smoke may be from a buildup of oil on the piston heads or valves.
  5. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    2,975
    Northern California
    When you tap the fuel bowl with a screwdriver, hit it with the plastic handle, not the tip.
    If I were you I'd smell the gas. Bad gas smells terrible, not like gas at all. If it smells like the gas in a running car, don't worry too much. I'd clean the carb. It's not that hard.
  6. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,377
    Anchorage, formerly Spenard (hub of the universe)
    you can be more aggressive than that on the tapping.... just don't hit it hard enough to break the casting. really
  7. jdrocks
    jdrocks Gravel Runner
    Jul 6, 2007
    7,651
    agree, stuck float, but if you continue to crank and no fire, excess gas can drain to the crankcase and dilute the oil, not good. when that happens, you can smell fuel on the dipstick, wouldn't hurt to check.
  8. JR356
    JR356 Long timer
    May 4, 2005
    6,948
    Way out West
    If you don't want a lot of problems,drain/flush tank,rebuild carb(s) and replace all the rubber fuel lines,including anything under the vehicle.Put a good quality fuel filter in line before the carb(s)
    Do a full tune up,oil and coolant change and do full brake flush/brake job and replace any rubber lines.
    Anything less and you will be asking for future trouble.
    All this assuming it is a viable vehicle you want to keep,or sell at a reasonable price.
    Early Broncos are collectable these days.
    JR356
    #8
    baldman1 likes this.
  9. Cogswell
    Cogswell Trying to live the new normal.
    Jan 3, 2005
    9,990
    Riding with my pal Richard Cranium
    Also the the air cleaner housing for a rodent nest. :deal
    #9
    JR356 likes this.
  10. groop
    groop So much to ponder
    Jun 5, 2007
    6,100
    oc, ca
    Please post photos of said Bronco
    And 4 year-old CA gas is the worst thing you can put into your carbs. I left some in a vintage VW for less than two years and the fuel pump was completely gummed up, almost as if someone dumped some gelling agent into the fuel tank
    (signed, an EB fan)
    #10
  11. scapegoat
    scapegoat Pushin forward back
    Dec 21, 2005
    3,173
    Northern AZ
    It does sound as if the float is hung up. That being said it would certainly be in your best interest to keep a watchful eye under the hood while you try to run it. If fuel if puking out of the carb or a bad gasket you could easily go up in flames. Personally Ive had nothing but problems with Holly 4 bbl carbs and leaky transfer tube seals, sticky floats etc if thats what on it. At any rate after 4 years of rotting Ca gas your likely in need of some fuel system rehab.
    #11
  12. concours
    concours WFO for 47 years
    Dec 2, 2008
    7,169
    Kensington, NH USA
    The “stuck float” is a romantic old tale. Way more likely is corrosion/deposits on the needle & seat, which do not seal properly, (and shut off the fuel flow as designed) even though the float is pushing it closed. Mechanical cleaning is the only option.
    If you choose to ignore my sage advice, have a good, big, fire extinguisher at hand.
    #12
    Zahnarzt, baldman1 and layinlow61 like this.
  13. layinlow61
    layinlow61 Been here awhile
    Dec 15, 2009
    237
    Salisbury
    Gave you a like for the word "romantic"! I didn't now that word still existed in today's society! Ahhhh well....maybe in my next lifetime I will be lucky enough to experience it??? *SIGH* :feelgood
    #13
  14. ohgood
    Sep 21, 2010
    9,679
    alabama
    dunno the old gas...
    then run an electric fuel pump from the ttnk to the carb with two fuel filters then back into the tank... full it up with fresh gas and let that circulate a few hours
    get the rust out
    #14
  15. Zahnarzt
    Zahnarzt Crashes Much
    Sep 10, 2009
    797
    Sierra Vista Arizona
    Had a similar situation on a 1978 CJ.
    Only other advice, if you haven't torn everything apart and cleaned it, is check to see if it is a stock carb.
    The CJ had a Holley and was dumping fuel from the front bowl and accelerator pump diaphragm. Quick change of those and fresh gas and she ran like a champ.
    #15
  16. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    2,990
    North of North Plains
    Since the OP hasn't given us any updates, perhaps his whatever year vintage Bronco caught on fire and is no longer?
    #16
    concours likes this.
  17. mtech1950
    mtech1950 Been here awhile
    Jun 9, 2008
    740
    Albuquerque NM, Guadalajara MX
    old gas can cause valves to stick in their guides
    #17
