VStrom Owners Thread
Discussion in 'Japanese polycylindered adventure bikes' started by Queen, Jan 16, 2006.
  1. motomem
    motomem Long timer Supporter
    Apr 25, 2011
    4,384
    Brighton, TN
    Another question -
    2011 DL650 - that has this skid plate and I want to put foot pegs like in the 2nd photo on.
    The upper of the skid plate is not flat all the way across. I am thinking of maybe bolting it in place on the first flat spot just before the bottom.
    Considering -
    Is that too low - it will mess with my ground clearance about just a'little but on curves would it drag?
    Will the front wheel touch it?
    Is the Aluminum skid plate hefty enough to support the foot pegs?
    Yep I am just full of questions. Hopefully someone that has been down the road with a 2011 DL650 will share your knowledge with me. I don't want to deal with trial and error when so many have been there done that.
    davyjones likes this.
  2. Gustavo
    Gustavo Motociclista Errante
    Jun 1, 2004
    4,768
    Sometimes in Hillsburrito
    Note that this top skid plate is not supported by crashbars like the one you showed below. IIRC, the front has a clamp around the header. Adding anything that sticks out to it would make it a real liability if you ever drop the bike, even a garage type drop could cause major damage.
    Gustavo
    davyjones, TreasureState and RedEX like this.
  3. motomem
    Apr 25, 2011
    4,384
    Brighton, TN
    The skid plate connects with a bolt that goes all the way through down low at the bottom of the oil pan. Then there are two separate connections near the back still down low. It doesn't connect at the header.
    The plate could get wrenched sideways pushing it into the header in a tip over if the pegs stick out far enough. Something about foot pegs being there even on the right plate just looks fragile. That set of pegs have been talked about on Vstormer. It may be that just wanting something to work isn't enough to assure it will.
  4. Psycho18th
    Psycho18th Been here awhile
    Dec 19, 2009
    898
    Phoenix, AZ
    https://www.ebay.com/itm/161585933237
    is what I used. Seems like the same metal used on an impact gun. 1/2 in ratchet size. At least 3” deep. It’s not a modified socket, just round with the teeth cut in. Makes it a much easier job. Hard part for me was getting the old bearings out. Takes a very long punch and lots of hammering.
    RedEX likes this.
  5. RedEX
    RedEX NeverSatisfied
    Apr 25, 2007
    747
    S.E. Michigan
    Thanks again for that information, Psycho18th. Very helpful, and I'm sure someone else will also find this useful down the road.
  6. RedEX
    Apr 25, 2007
    747
    S.E. Michigan
    Motomem, did you already buy this? What brand is that?
    What Gustavo said. Just my opinion but I would not use anything that didn't also tie in to a set of crash bars, for added strength.
    TreasureState likes this.
  7. Gustavo
    Jun 1, 2004
    4,768
    That's actually worse. That "skid plate" is designed to take some mild impacts in the vertical axis, not for any twisting motion. Imagine what would happen if your foot pegs on either side were to impact the ground and created a twisting motion that pulled the bolt out of or broke it and/or the oil pan... Bolting anything to that extends out of the plate seems like a Really Bad Idea (TM) to me.
    Gustavo
    LexLeroy likes this.
  8. motomem
    Apr 25, 2011
    4,384
    Brighton, TN
    No I haven't bought the foot rest/pegs. I think you are right. It's not a good place. I also contacted Happy Trail about it. He didn't think it was a good idea either. Oh well a comfortable farkle that got away. :-)
  9. Psycho18th
    Dec 19, 2009
    898
    Phoenix, AZ
    I have that skid plate. It’s from weld86. Good price and product. Glad to find something that didn’t need crash bars and such to bolt onto that would Still protect the pipes and oil filter from rocks.
    Here’s a link if anyone’s interested. http://www.weld86motoparts.com/prod...-Strom-Skid-Plate/p/33049319/category=8524604
    Rusty Shakelford and dp064 like this.
  10. NWRambler
    NWRambler Been here awhile
    Jan 11, 2013
    319
    Northwestest US
    I have one with the spring on. I see 53mm of shaft from top of bumper to the body. 78mm from bottom of spring to the body. I think the spring seat/spring bottom are about even with the base of the shaft, but I can't see that for certain. Let me know if you need more.
  11. JasonFL
    JasonFL Adventurer
    Mar 20, 2020
    69
    Fort Myers, FL
    I want the rear of my bike to be seen from space at night, I was thinking custom mounting 2 of these, one under each pannier. Question is, would it be possible as they're designed to be running and brake lights, just splice in I assume? Any thoughts or great ideas appreciated!
  12. motomem
    Apr 25, 2011
    4,384
    Brighton, TN
    It is very well made and the owner has been helpful even though I didn't buy it. It came on the bike.
  13. dp064
    dp064 Been here awhile Supporter
    Nov 11, 2019
    421
    Nashville
    Same, I'm on record expressing my satisfaction with this plate. I wouldn't, however, add peg bars to it.. My opinion only but I think that's asking for trouble. Send a quick email to Charlie at Weld86, he's a great guy.. he'll tell you for sure.
    Don
    Edit: You posted before me.. apparently you've already been in touch.
    RedEX likes this.
  14. Motor7
    Motor7 Long timer
    Sep 16, 2013
    1,618
    East Tennessee
    Mostly blue positaps on the strom, but for my cruise control I also used red. Buy in bulk off e Bay for around .50 cents ea. I use them for everything now so it's nice to have extras on hand.
    RedEX and motomem like this.
  15. Pollack
    Pollack Adventurer
    May 31, 2014
    1,249
    I have the Happy Trails skid plate with the same bar / foot rests and I don't have any clearance issues.
    Best regards,
  16. motomem
    Apr 25, 2011
    4,384
    Brighton, TN
    If I was going from the ground up I would be doing it the way you have it. My old chicken legs need a place to stretch out once in a while. The least expensive answer is to stop, get something to drink, pull my pants out of my ass and walk around.
  17. LexLeroy
    LexLeroy Socially Distant Supporter
    Jan 2, 2011
    15,769
    Lexington, KY
    Thx.
  18. macuaig
    macuaig Back in the Saddle
    Jul 26, 2015
    138
    Virginia/DC
    I took one of these off the 650 I just picked up. It’s free to anybody in the DC area.
  19. Gustavo
    Jun 1, 2004
    4,768
    Absolutely, I didn't mean to imply that it wasn't. I like that there are options for some protection to the oil filter, header and crankcase that don't involve a huge plate that needs to be connected to crashbars. My Wee has a Touratech plate that also uses some bolts in the engine case for the front mounts. For the riding I do, it's great. You just have to be sure that you know the limitations of that mounting system, so that you don't end up with more damage to the engine from the plate getting hit too hard or twisted in the wrong direction.
    Gustavo
  20. Gustavo
    Jun 1, 2004
    4,768
    Do you have footpeg lowering blocks? That one inch drop doesn't seem like much, but it sure helps a lot. Also, if your inseam will support it, a taller seat, giving you even more leg room and a more old-knee friendly angle. My Wee has the lowering blocks and a bead seat cover which effectively raises the seat about 1/2"
    Gustavo
    davyjones and RedEX like this.
