VStrom Owners Thread
Discussion in 'Japanese polycylindered adventure bikes' started by Queen, Jan 16, 2006.
  1. twinpower
    twinpower 1200R Sportster
    Aug 15, 2008
    51
    Raleigh, NC
    RedEx, Thanks, that is what I thought after searching several places about it. I have a 23mm 12 pt socket, now need to locate a 19mm 6 pt.
    Mike
    RedEX likes this.
  2. blaustrom
    blaustrom Adventurer
    Apr 3, 2017
    97
    Western NY
    I have the Motion Pro tool and the 6 point 23 mm socket. If anybody wants them contact me. (12 point 23 mm socket does not work, the adjuster nut has rounded corners!)
    TreasureState likes this.
  3. twinpower
    Aug 15, 2008
    51
    Raleigh, NC
    Sent you a PM...
  4. jwumpus
    jwumpus standup philosopher
    Jan 28, 2007
    4,628
    Fredonia, NY
    I replaced the evil low seat with the Suzuki high seat. Also put on a Sit&Fly and 2 inch risers. A serious improvement in comfort. The problem now is that I'm a bit too high to comfortably put both feet on the ground, a problem I've never experienced and one that I seriously dislike. I've had a few moments of wondering if I was about to drop the bike. So I'm looking at adventuretech and trying to decide if I want to lower by 11/16 or 1 inch. I don't know how people ride bikes that are a bit too tall for them. I don't think I could ever get used to that unpleasant sensation of weightlessness and my brain going AAAAHHHHHH!!!
  5. keyzard
    keyzard Falls over a lot....
    Aug 14, 2007
    408
    Buffalo Area, NY
    @jwumpus , I didn't read backwards through this thread......what year/size is your Strom? I'm looking for a low seat for my wife's and we aren't that far apart (I'm in Cheektowaga). If it fits do you want to sell?
  6. jwumpus
    Jan 28, 2007
    4,628
    Fredonia, NY
    I have a 2014 Desert Khaki 1000. Not sure if that would work for you?
  7. jwumpus
    Jan 28, 2007
    4,628
    Fredonia, NY
    Latest picture
    Watercat, lwood10, CoopsDL and 2 others like this.
  8. keyzard
    Aug 14, 2007
    408
    Buffalo Area, NY
    Unfortunately, no. She has a 2006 650. But thanks for the reply!
    Very nice bike BTW!!
  9. blaustrom
    Apr 3, 2017
    97
    Western NY
  10. jwumpus
    Jan 28, 2007
    4,628
    Fredonia, NY
    My wife is in Spokane today picking up a 2006 DL650.
    RobG. likes this.
  11. keyzard
    Aug 14, 2007
    408
    Buffalo Area, NY
    That looks like a lot of fun! Unfortunately our summer weekends are generally spent at our land in Alfred Station. We have a lot of projects planned for this year, so free time is at a premium. Maybe next year?
    I'm so glad we bought that property so we would have a nice place to "camp and relax"........:imaposer
    ag_streak likes this.
  12. Gustavo
    Gustavo Motociclista Errante
    Jun 1, 2004
    5,090
    Sometimes in Hillsburrito
    Great, now you'll have a his and hers V-Stroms. :ricky:ricky
    BTW, is that one of Phil's bikes she is buying?
    Gustavo
  13. jwumpus
    Jan 28, 2007
    4,628
    Fredonia, NY
    It is, indeed. I mentioned it to my wife just now and she remembers you from the Wet Leather crowd.
  14. JonB85
    JonB85 Adventurer
    Mar 20, 2021
    70
    North Carolina
    I'm 5'6"...welcome to my life :rofl
    You could try just dropping the front end a little bit first. I had to do that on my 650 to make it manageable. I've got lowering links but haven't installed them yet. I've got a used kickstand coming that I need to have shortened before I lower the bike any more. After dropping the forks about a half inch, it can be a bit tricky trying to put the stand down on sloped or uneven pavement.
  15. EJJ
    EJJ Dog lover
    Sep 6, 2015
    61
    Land of Enchantment
    I took the time to R & R the adjusters cut castle drive slots which worked out fine. Kind of a PITA to do the upper if you have engine guards, patience is your friend...:-)
    wilddoktor likes this.
  16. twinpower
    Aug 15, 2008
    51
    Raleigh, NC
    Nice work... what Suzuki should have done! Since you just R&R your adjusters, can you confirm what sockets are necessary for the upper and lower adjusters?
    Lower: 19MM 6 pt
    Upper: 23MM 6 pt or 12 pt?
    Thanks - Mike
  17. EJJ
    EJJ Dog lover
    Sep 6, 2015
    61
    Land of Enchantment
    Hey Mike, yeah I use 6pt in metric when ever possible. I used 6 point on both, if I remember correctly I only used a 12 point at the bolt end of one of the rods in the snug up before torqueing. I found the upper adjuster a little loose but hard to get an accurate torque reading even with the "v" support tightened up. Those groves were cut with a chop saw, be careful with that deal....:yikes By the way I live in the southwest which is normally a dry climate, when I pulled the lower mount rod out it had 2" of rust at the tread end but not on the threads. I suggest if you are going to take the time to do any of this, when you pull that bottom rod and have a look see, check for rust. :nod
    I used a small floor jack where the oil drain is for support.
    warm regards, Ed
    RedEX likes this.
  18. RedEX
    RedEX NeverSatisfied
    Apr 25, 2007
    1,057
    S.E. Michigan
    Just a follow-up regarding the thrust adjusters:
    So I got everything torqued to spec- the top adjuster wasn't actually loose, but also wasn't tight, just snug. Got everything back together, skid plate, crash bars, etc., and the buzzing is gone!
    It was a little more involved because of the crash bars and skid plate, but without those accessories it would be a pretty quick, easy job. Definitely worth the time invested.
    rubline, OCLandspeeder and wilddoktor like this.
  19. twinpower
    Aug 15, 2008
    51
    Raleigh, NC
    Great to hear RedEx! JonB85 and I are planning to check/adjust ours this weekend, hopefully with the same results.
    RedEX likes this.
  20. EJJ
    EJJ Dog lover
    Sep 6, 2015
    61
    Land of Enchantment
    Finally got in a test ride this AM....no joy :baldy Buzz isn't as bad as it was but still there around 5500, not going to fret over it to much, I don't run that fast for long periods anyway, might check a few other things but I'd rather ride now than chase down the "what ifs".:hmmmmm At 75 I grabbed the Givi bars and they were singing the same tune as the handle bars. Once I get a trip already planned done I might dig into it again since I have the tool and now I'm more up on the procedure it shouldn't take near as long. I know the bottom ones right, just question if the torques right at the top.
