VStrom Owners Thread
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by Queen, Jan 16, 2006.
  1. greywolf
    greywolf Unpaved road avoider
    Apr 2, 2006
    1,406
    Evanston IL
    I wouldn't do a TBS on a post 2007 650. 2004-2006 Wees and 2002-2012 Wees can benefit but later 650s have a different configuration due to emissions controls and a TBS is only an idle air screw adjustment. Even that is best done using a proprietary computer tool.
  2. gt7599a
    gt7599a neophyte
    Jun 25, 2015
    13
    BJ
    Long term storage
    In general, and specifically for a VStrom 650, how viable is it to store a bike un-riden for an extended period of time (3 years) and then add fluids back and ride? Are there components that would dry out, rot, tire deformation, etc? I'm a novice rider and novice mechanic (though I'm good at building/fixing things).
    My specific context is I hope to pick up a well farkeled late model VStrom, ride for 6 months and then moth ball and store in a barn in New England until the next time I have to ride (3 years later).
    I'm trying to avoid having to take time to buy on the front end and sell on the back end the next time I get to ride. Would this plan just mean I'll end up spending a lot of time on maintenance at the start of my next ride window or not? If so, what would I have to replace and how hard would that be? Genetic tools and work space wouldn't be an issue but I don't have specialized motorcycle tools (e.g. Motorcycle lift)
    I'm guessing the "wise" solution would be to sell and rebuy at my next riding opportunity but wanted to ask people with more experience.
    Ed
    Sent from my Nexus 6P using Tapatalk
  3. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    5,165
    Where it will be stored at? Would it be reasonably protected from elements (rain, snow, heat, etc). If it is guarage storage see no prob. Put a fresh tank of non-ethanol premium, add stabil, ride home, change oil/filter, pull battery and put it on tender. If you ridden in stow make sure to get salt off the bike prior good luck.
  4. gt7599a
    gt7599a neophyte
    Jun 25, 2015
    13
    BJ
    It would be in doors in a barn, out of the elements but not temperature controlled. It wouldn't get hot but it would get cold, easily 20°-15° F, occasionally 10°F, potentially 5°-0° F.
    Ed
  5. cyclopathic
    Dec 23, 2007
    5,165
    Cold usually not a prob, heat and moisture (condensate) is.
    Get a good tender or just count needing a new battery.
    gt7599a, Hi-De-Ho and DodgeOmni86 like this.
  6. Cryoman01
    Cryoman01 Been here awhile
    Feb 20, 2016
    155
    Portland Oregon
    Non-ethanol and stabilizer are only good for a year. Run a tank of it through the engine, then drain the tank completely. Remove the fuel pump and let the gas evaporate. Pull one plug from each cylinder and spray in engine fogger. Fog the tank too. Spray all metal and electrical components except brakes with acf50. Remove the battery. Keep the tires off the ground. Plug the muffler. Cover the moto. Figure out a way to keep mice from chewing on the wiring.
    Sent from my SM-G930V using Tapatalk
    DodgeOmni86, Wierdrider and gt7599a like this.
  7. greywolf
    Apr 2, 2006
    1,406
    Evanston IL
    The rule of thumb is one year for stabilized fuel. For much longer, I'd drain the tank and fuel lines and oil fog the tank and cylinders. Also drain the old oil and fill with new oil to the bottom of the fill hole.
    Wierdrider and Hi-De-Ho like this.
  8. cyclopathic
    Dec 23, 2007
    5,165
    Well the problem with having dry tank is moisture condensation, you want tank 90% full to avoid rusting.
    Fuel will last. I had bike with 10% ethanol stored for 5 years and the EFI bike started right away. Ran like crap at least until 2 gas stops flushed fuel out. That was in garage, so never got below freezing or above 100F
    @OP when you ready to restart bike, be ready to run a couple tanks to get old fuel out, and add Lucas or Seafoam to clean injectors good luck.
    EDIT: here is what STABIL mfg has to say about it:
    V-Tom likes this.
  9. refokus
    refokus Hmmmmmm
    Jun 7, 2007
    3,222
    North Phoenix
    Just sell the bike and if you still want to ride 3 years down the road buy another one. You will always be able to find a used strom for sale.
  10. Rusty Shakelford
    Rusty Shakelford Been here awhile
    Sep 1, 2015
    104
    South East Georgia
    Thanks Guywithchickens didn't realize it broke till it got dark outside.
  11. greywolf
    Apr 2, 2006
    1,406
    Evanston IL
    He said three years. Oil fogging the tank, like I said, will keep it from rusting.
    Cryoman01 and Hi-De-Ho like this.
  12. Cryoman01
    Feb 20, 2016
    155
    Portland Oregon
    Well, even it is was only for 2 years, it still depends on storage conditions, like a barn. Here's the last part of their FAQ answer…"However, any gasoline stored for more than 12 months will tend to lose volatility (ignitability), which could lead to hard starting or NO START conditions after this long storage period. NO additive, STA-BIL brand included, will prevent volatility loss in fuel.”
  13. Eyebooger
    Eyebooger One-man peanut gallery
    Jun 25, 2014
    964
    Land of the Bella Vistoners, NW Arkansas
    Can someone explain oil fogging procedure? Sounds like a good idea, but I’ve never heard of it. TIA
  14. Rorider
    Rorider Been here awhile
    Aug 9, 2012
    216
    Toronto, Canada
    I'm looking for a GPS/Phone mount behind the windscreen above the dash. Can anyone recommend something solid? Thanks.
    I have a '17 650 XT
  15. greywolf
    Apr 2, 2006
    1,406
    Evanston IL
    Eyebooger likes this.
  16. DodgeOmni86
    DodgeOmni86 Been here awhile
    Sep 20, 2017
    156
    Morgantown Indiana
    I use the rokform motorcycle mount and I love it, kinda on the steep side but solid and well worth it.
  17. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    2,908
    Long Island New York
    Perfect squeeze
    Best phone mount on planet
    Blows the ram x mount away
    Sent from my iPad using Tapatalk
  18. RedEX
    RedEX NeverSatisfied
    Apr 25, 2007
    243
    S.E. Michigan
    http://www.adventuretech.biz/over-the-dash-gps-mounts.html
    Rick is a stand-up guy and V-Strom owner, you can also find him over on Strom-troopers. I've had one of these for a while now, very sturdy and works great.
    Brutalguyracing likes this.
  19. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    2,432
    Beaverton, OR
    Rapid temperature changes creates most of the condensation. I've had good luck with an old sleeping bag. Breathable, but slows the temperature change, eliminating a lot of the condensation.
    But for years in storage I'd oil the inside as suggested, & find a home for it inside.
  20. cyclopathic
    Dec 23, 2007
    5,165
