VStrom Owners Thread
Discussion in 'Japanese polycylindered adventure bikes' started by Queen, Jan 16, 2006.
  1. eakins
    eakins Butler Maps
    May 29, 2002
    34,867
    Fort Collins, Colorado
    Another shock rebuilt option
    http://daughertymotorsports.com/Backup/vstromsection.html
  2. eakins
    eakins Butler Maps
    May 29, 2002
    34,867
    I have a Givi tanklock quick detach on my 650.
    20L bag. Micro adjusts for and aft some.
    Best and easiest tank bag I've ever owned.
    Brilliant system!
    Kappa is also Givi luggage just with less visual bells and whistles. Built the same just not as sparkly.
    I have Kappa bags on my bike, built just like Givi only cheaper. Kappa has tanklock too.
    https://tourandride.com/
    Rollin' and Brutalguyracing like this.
  3. FrankThineTank
    FrankThineTank Adventurer
    Nov 9, 2016
    14
    Louisiana
    Part of the Wee Brigade now. Picked up an 06 for $1k off marketplace!
  4. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    11,036
    Southern Louisiana or Southern England or ...
    Good buy!
    FrankThineTank likes this.
  5. FrankThineTank
    Nov 9, 2016
    14
    Louisiana
    Now to find a cheapish set of crash bars and a skid plate for it. Lol
  6. RedEX
    RedEX NeverSatisfied
    Apr 25, 2007
    461
    S.E. Michigan
    Ha, yea "cheapish" - otherwise your farkles will end up costing more than the whole bike!
    Good luck and welcome to the club.
  7. snobear
    snobear Been here awhile
    Sep 18, 2010
    718
    Saskatchewan Canada
    It is a stand that slips over my frame slider to lift the back wheel off the ground, lighter than a centerstand
  8. jathkajoe
    jathkajoe Been here awhile
    Aug 12, 2009
    312
    E WA
    Cool!
    Jathkajoe
  9. Harrywho
    Harrywho Adventurer
    Feb 26, 2015
    44
    Wollongong NSW
    Snobear
    Are more photos of it if possible please.
    Harry
  10. DualDog
    DualDog Been here awhile
    Jan 12, 2007
    297
    Galesburg, IL
    I have a 2015 V-Strom 650 XT. I am wanting to purchase a center stand. Previous owner installed a GIVI skid plate. Does anybody know if the Suzuki OEM center stand fit with the GIVI skid plate? Or is anybody out there running a GIVI skid plate and have a center stand that fits without interfering with it.
  11. MuckSavage
    MuckSavage A Piney Irregular
    Jan 21, 2011
    874
    Turnersville, NJ
    I have a Givi Skidplate with a SW Motech Centerstand on my '12. No interference.
  12. Wezitar
    Wezitar Adventurer
    Jul 23, 2014
    55
    Southern Kansas
    Ok having a problem with the signal 15A fuse blowing. Seems to happen when i crank the bars to back into a parking spot. I took off the side panels and the tank, turn on the key, cranked the bars, could not get it to replicate. Anyone know what all is on that fuse? I noticed i couldn't get my grip heaters to come on. They are plugged into the factory connector. Are they only powered when the bike is running? I knew they where at least on the key. Also shook and wiggled all the wires attached to the handlebars while powered with no results. Any ideas? Hard to troubleshoot with it not replicating in the shop. It has happened twice this last week. I have replaced the fuse and ran for a couple of days with no problems and then boom.
  13. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    3,249
    Long Island New York
    SOUNDS LIKE A DEAD SHORT,trace all the wiring for said blinkers before you melt it down
  14. Krautwagen
    Krautwagen Adventurer
    Jun 14, 2018
    58
    St Paul, MN
    Pretty much everything runs on that fuse, incl the grip heater connector. Check out a wiring diagram for your year and model.
  15. Brutalguyracing
    May 15, 2013
    3,249
    I'd start near pinch points
    And individual blinkers if there is any indication they have been replaced
  16. TypeRated
    TypeRated Airborne Adventurer
    Feb 21, 2013
    365
    SW FL
    How’re you guys liking the 2017+ V-Strom 650s?
    Considering a 2019 650 XT as a replacement for my XSR900 and so I can do 2-up touring with the wife.
  17. Wezitar
    Wezitar Adventurer
    Jul 23, 2014
    55
    Southern Kansas
    Just an update on mine. I found a broken wire in the right heated grip. Not sure if that would cause the issue since it is the middle of summer and the grips have not been on in months. Time will tell if this fixed the issue.
    Brutalguyracing likes this.
  18. ag_streak
    ag_streak Tiene Ruta Cuarenta? Super Supporter
    Aug 9, 2006
    6,867
    Blue Ridge, GA
    I haven't ridden the XSR, but seeing that it's a naked bike, I think you'll find the V-strom 650 infinitely more comfortable and better suited for 2-up.
    However, if you and your wife are large and heavy, and plan to lug around a substantial load up steep, high speed mountain roads, you might find the power of the 650 marginal.
    TypeRated likes this.
  19. rickh123
    rickh123 Been here awhile
    Aug 15, 2010
    372
    ON, Canada
    Good point
    ag_streak likes this.
  20. husky390
    husky390 Long timer
    Sep 24, 2017
    1,150
    Colorado
    Do the first gen DL1000’s eat wheel bearings? I replaced the rear about 6-7,000 miles ago and just finished a 1,400 mile 2up trip with the bike loaded heavy and I’m hearing a whine thats pitch increases with speed. I installed Anakee 3’s before we left which are slightly cupping. Can the tires be the cause or do I have another wheel bearing going out?
    Front wheel has no movement, rear wheel had a tiny bit if I had my hands on the top and bottom of the tire and put some muscle into it. Rear brake is not dragging, chain slack was set per service manual.
    Also, what tools are required to swap the bearings?
