1. eNewsletter Sign Up
VStrom Owners Thread
Discussion in 'Japanese polycylindered adventure bikes' started by Queen, Jan 16, 2006.
  1. Georgios
    Georgios Been here awhile
    May 3, 2009
    430
    I haven´t done it by myself yet, but others have suggested to use a simple bolt/washer/nut-combination to pull the bearing. Or any shop can do it for little money. New bearing back in place should be easily performed by yourself. Good luck.
    DesertDonor likes this.
  2. DesertDonor
    DesertDonor Deep Sand and Mud Detector
    Sep 19, 2017
    265
    Albuquerque, NM
    Yes, but the approach given is impractical. Suzuki's solution is use of a special tool that retails for $559.
    davyjones and ag_streak like this.
  3. DesertDonor
    Sep 19, 2017
    265
    Albuquerque, NM
    Bolt and washer combination won't work. No way to get the bolt head under the bearing to pull/push it out. Mechanical seal's in the way.
    Mechanical seal can be pushed out...from the bearing side. Or, you can pry it out (and mar your crankcase cover a lot in the process), but then the bearings are still in place.
    The only comprehensive Vstrom water pump rebuild narrative I could find anywhere was for a DL650, which has some important differences (https://blacklabadventures.com/2012/02/22/rebuilding-the-water-pump/). Also the writer only replaced the mechanical seal, he didn't touch the bearings.
    Yesterday I took my crankcase cover to a shop, to have them do the job.
  4. BarryB
    BarryB Been here awhile Supporter
    Feb 16, 2004
    674
    Texas Hill Country
    What did they charge to remove it?
  5. LexLeroy
    LexLeroy Whiskey Tango Foxtrot Supporter
    Jan 2, 2011
    12,837
    Lexington, KY
    Too late to help you, but I suspect that a garden-variety pilot bearing puller that can handle 10mm ID bearings is what you needed. Here's a video that demonstrates how to use one -
    davyjones likes this.
  6. DesertDonor
    Sep 19, 2017
    265
    Albuquerque, NM
    Probably $50-ish in shop labor. I just wanted this to be done, so I brought all the parts and asked them to swap the works (bearings, mechanical seal, oil seal).
    A pilot bearing puller would have worked if anyone made one small enough. So far all I can find online will only go down to 1/2" inner diameter. The $559 Suzuki tool is, basically, a miniaturized pilot bearing puller.
    Hivernaut likes this.
  7. DesertDonor
    Sep 19, 2017
    265
    Albuquerque, NM
    Thanks for your wonderfully documented write-ups, BTW. Do you still ride that heavily-modified DL650?
  8. BarryB
    Feb 16, 2004
    674
    Texas Hill Country
    You must be thinking of someone else. I am just thinking about a DL. I have a R1200RT and want to downsize.
  9. DesertDonor
    Sep 19, 2017
    265
    Albuquerque, NM
    I stand corrected - there IS a miniature bearing puller available, apart from the $559 Suzuki one. Only $285 for this one from ReelSpeed:
    https://reelspeed.tools/products/2019-reelspeed-miniature-bearing-puller-kit-v-3
    However, it only does bearing inner diameters up to 8mm, so, not gonna work for DL1000 water pump bearings.
    You can go deluxe, with this SKF TMIP puller kit that covers inner diameters from 7 to 28mm, for the low low price of only $728:
    https://www.amazon.com/SKF-Skf-Tmip-7-28/dp/B01CKI9Y4M
    The Harbor Freight slide hammer kit might juuuuust work:
    https://www.harborfreight.com/slide-hammer-and-bearing-puller-set-5-pc-62601.html
    Smallest collet size listed is 3/8", which is about 9.5mm...just under the 10mm ID of the water pump bearings. So this one may be a winner.
    However, I wasn't super interested in paying $60-ish for a tool I'd use exactly once, yet again.
    Eventually I may need to swap wheel bearings, but I'll worry about that when the time comes. So far the original wheel bearings are just peachy.
  10. BigBrian
    BigBrian Been here awhile
    Mar 13, 2019
    209
    Eastern, PA
    I went down to the dealer yesterday to look at a leftover V-Strom 1000.
    Depending on what the dealer wants to give me for my Ducati, I might be adding it to my fleet.
  11. Woodsparrow
    Woodsparrow Been here awhile
    Aug 5, 2019
    121
    Texas
    Over here in the US. Looking to get some side bags aka saddlebags for my 2013 Vstrom 650.
    Really like the Kriega OS panniers, though 250$ per plus 90$ for the panels plus a frame is steep.
    Does anyone have a suggestion for a good frame to buy, today, that I could use for whatever bags I end up wanting? Probably going to buy a frame today, and 1 bag next month then another in November.
    Only limitation is no Shad. I bought a set for my Honda NC500X at one point, they shipped me the wrong frame entirely, refused to admit it and took 6+ months to refund part of my money (seriously, the frame was an inch out of spec for my never-dropped Honda).
  12. zxrider11
    zxrider11 Been here awhile
    Jan 11, 2010
    675
    West Michigan
    Looking for some inmate help - my riding buddy crashed his 2014 VStrom 1000 last June, and he has started the process of piecing it back together.
    One of the final pieces he needs to replace is his radiator - Part #17710-31J00. Cheapest replacement we can find is around the $500 price for a new one.
    Any fellow StormTroopers know where a used radiator can be found?
    Thank you for the assist!
  13. Gustavo
    Gustavo Motociclista Errante
    Jun 1, 2004
    4,369
    Sometimes in Hillsburrito
    Why do you need a frame? Just buy something like the Ortlieb saddlebags, that's what they are - saddlebags - you throw them over the seat, attach the straps and go. If you are worried about the left side making contact with the wheel, you could install a simple spacer on that side or buy one of those smaller soft luggage racks/spacers (AdventureTech, Givi, HT, SW-Motech, etc. make some options), but that sort of seems to defy the purpose of going with soft bags to save weight and bulk over a hard luggage option.
    There used to be a guy on the V-Strom forums named Dan Vesel who made these spacers for the left side:
    Can't find his contact info right now, but I am sure you can find it digging through Stromtroopes or vstrom.info.
    Gustavo
    davyjones and RedEX like this.
  14. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,405
    Middletown, PA
    Agree, and here's a possible alternative if you want to go with more generic (i.e., less expensive) dry bag alternatives (need to read this and a couple of follow-on posts): https://advrider.com/f/threads/mini...250cc-and-under.201349/page-676#post-38424959
  15. Woodsparrow
    Aug 5, 2019
    121
    Texas
    Apologies, my request wasn't clear. I'm not sure what I want to put on the bike yet, but it will either be a simple Kriega drypack, or a pannier system. In the former case, nothing else needed. In the latter, I'll be mounting bags of some flavor which means I need a frame.
  16. MTlost
    MTlost Been here awhile
    Aug 29, 2013
    137
    Southwest Montana
    I have an 06 DL650 that works great except that once it gets fully warmed up it does not like to idle and will miss on one cylinder till the revs come up to about 2500 rpm.
    Is this common, how do I fix this???
    Thank you for any help or ideas, this forum has been great for me to learn from!!!
  17. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    11,291
    Southern Louisiana or Southern England or ...
    Have the valves ever been inspected?
  18. DesertDonor
    Sep 19, 2017
    265
    Albuquerque, NM
    Got my crankcase cover back from the shop today, with new waterpump consumables (bearings, oil seal, mechanical seal) installed. They did a superb job. Only charged me half an hour labor, about $50 total. Well worth it.
  19. rdtrvlr
    rdtrvlr Long timer
    Oct 4, 2007
    1,072
    i bought a sit & fly, put it over my suzuki gel seat and while probably not the the best go everyone, it’s the best $27 i’ve spent yet. i’m no longer looking to replace the seat. makes 400 mi days much easier.
    side note: for those with buffering issues. i to suffered from my head bobbing around all day. a few rides i just took the windshield off an it was beautiful. i recently decided it was time to replace my old hjc modular. i was planing to get another hjc but the guy at the helmet shop. he suggested a scorpion. he even let me test ride it.
    i bought it and, for me, difference was amazing. so if possible borrow a different kind of helmet before spending a bunch on windshields
    RedEX and DesertDonor like this.
  20. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,067
    Beaverton, OR
    Intake leak somewhere?
